No-Code Automation
Technical complexity: No-code
Platforms like n8n, Zapier, or Make provide powerful visual editors that support thousands of connected tools, with triggers and actions that integrate Mattermost to external services, enabling teams to build complex workflows without writing code. Admins migrating from tools like Slack Workflow Builder can recreate familiar automations in Mattermost using these platforms.
When used in combination with outgoing webhooks or custom slash commands, users can trigger complex workflows and automations without leaving Mattermost. By pointing a webhook or slash command at the unique URL these automation tools provide, any message or keyword in Mattermost can initiate a workflow. This allows you to capture context from conversations and pass it into external systems — for example, creating tickets, updating records, or starting multi-step automations.
Choosing the best platform for your team depends on your specific integration requirements, hosting preferences, and technical capabilities. Learn more about the capabilities of each platform below:
n8n is ideal for organizations prioritizing data residency and security, since it is self-hosted and can be supported in air-gapped environments where cloud solutions like Zapier and Make might not be feasible.
Additionally, n8n supports both no-code and low-code approaches, making it flexible for technical and semi-technical users. Being open source means there’s a large community of people sharing their custom workflows and automations that can either be used directly or iterated on to meet your specific requirements.
n8n stands out for offering rich AI integration, enabling you to combine automation with AI-powered workflows. Its native AI Agent node lets you integrate large language models, vector databases, and other AI services directly into your automations. This means you can build workflows in Mattermost that not only react to events but also analyze context, summarize discussions, or make decisions based on AI output.
Explore building workflows with the Mattermost n8n integration.
Supported Triggers​
  • MattermostTrigger (community node): Listens for Mattermost events via WebSocket events, such as new post and users added.
You can also use outgoing webhooks or slash commands in Mattermost as triggers using the Webhook node.
Supported Actions​
  • Channels
    • Add a user to a channel
    • Create a new channel
    • Soft delete a channel
    • Restore a soft deleted channel
    • Get statistics for a channel
  • Messages
    • Post a message into a channel
    • Post an ephemeral message into a channel
    • Soft delete a post
  • Reactions
    • Add a reaction to a post
    • Remove a reaction from a post
    • Get all reactions to one or more posts
  • Users
    • Create a new user
    • Deactivate a user (archive, revoke sessions)
    • Invite user to a team
Supported Searches​
  • Search for a channel
  • Get a user by email
  • Get a user by ID
  • Retrieve all users
  • Retrieve members of a channel
