Migrate from Slack
Overview
Mattermost provides a reliable migration path from Slack, enabling you to bring your organization’s collaboration history into a secure, self-hosted Mattermost environment. The migration process supports full workspaces, including users, channels and message history, direct messages, and threads so your teams can continue working without losing valuable context.
This process generally involves preparing your environment, exporting data from Slack, converting that data into a compatible format, and then importing it into Mattermost. Migrating from Slack is a multi-step process that can be complex, particularly for larger organizations or those with multiple Slack workspaces.
Additionally, please consider that Slack's data control policies or export capabilities may change at any time, or they may charge fees to customers for exporting data stored in Slack. Support for negotiating export of customer IP from Slack Enterprise can be requested by contacting a Mattermost Expert.
  1. Preparations:
    • Answer key scoping questions.
    • Gather environment and export details.
    • Validate Mattermost server capacity and configuration.
    • Back up your Mattermost environment before importing.
  2. Export Slack data:
    • Generate an export from Slack.
  3. Transform the export for Mattermost:
    • Validate the Slack export using mmetl check slack.
    • Use the mmetl tool to parse and transform Slack exports.
  4. Import into Mattermost:
    • Upload and process transformed archives with mmctl.
  5. Validate and test:
    • Confirm channel and user data imported correctly.
    • Run database queries to fix any unread states.
  6. Go live:
    • Communicate the cutover plan to users.
Migration timeline
These instructions outline a best effort migration path designed to preserve the majority of your messages, files, and workspace structure. Mattermost provides tools and guidance to help streamline the process, but manual adjustments during the data transformation and import steps are often required. Successful migration depends on careful planning and dedicating sufficient time, technical resources, and technical skills to the effort.
Depending on the size and complexity of your Slack environment, a full migration can take anywhere from several days to multiple weeks of dedicated effort. Larger organizations with multiple workspaces, extensive message history, and many files should expect the process to require significant iteration and testing before completion. It’s important to plan for this timeline in advance by allocating the necessary resources, scheduling time for trial imports in a development environment, and coordinating across teams. Building in extra time for adjustments during the transformation and import steps will help ensure a smoother transition and reduce disruption to your users.
Scoping the migration appropriately during the preparation step can significantly reduce processing time and allow for faster iteration. Before beginning, carefully consider what data is essential to bring over to Mattermost. Many organizations find that not every channel or file needs to be migrated, and focusing only on what is truly needed can save substantial processing time and manual effort. By setting clear boundaries early, you’ll minimize the amount of data that requires manual intervention and testing, which in turn shortens the migration timeline and helps avoid unnecessary complexity.
Migrations Steps
1. Preparations
Before beginning the migration, it’s important to properly prepare your environment. Careful preparation helps reduce processing time, allows for faster iteration, and minimizes the chance of running into avoidable issues during the import.
This document assumes you already have a Mattermost Server deployed that is ready to accept your Slack data. If not, consider the recommendations in this section in conjunction with the appropriate deployment documentation to make informed decisions about your supporting database and file storage infrastructure.
Scope definition
Start by defining the scope of your migration:
  • Slack edition: Migrating from Slack Enterprise Grid involves additional steps and planning.
  • Data history: Decide how much history is necessary to import. Importing a smaller time window (e.g., the last six months) can significantly reduce complexity and processing time.
  • Export size: Consider the size of your Slack export file as you progress through this guide. File size directly impacts how long the import will take - for example, files under ~25 GB often complete within a day, while exports over 100 GB can take several days, significantly lengthening the time between iterations and the overall timeline to complete the migration.
  • File attachments: Consider whether you can exclude very large or non-critical attachments (for example, public software download packages, videos, or outdated media assets) to reduce import size and speed up processing.
Infrastructure considerations
The environment where you run the import can significantly affect performance:
  • Test environment: Always run the migration in a development or staging environment first. Most migrations require multiple iterations before a production import is successful.
  • Operating system: The mmetl tool is supported on Linux and macOS. Windows is not supported, and we do not recommend using Windows Subsystem for Linux (WSL) since the file system is not performant enough for the heavier processes involved in migration.
  • Storage requirements: Ensure your server can store both the Slack export archive and the fully unpacked data. As a best practice, plan for at least three times the size of your Slack export in available server storage.
  • File Storage: Imports into S3 file storage typically complete faster than imports into local storage or NFS. For large imports, we recommend using AWS S3 or another S3-compatible storage service for best performance.
Mattermost server considerations
Carefully preparing your environment and making these adjustments up front will help ensure the migration proceeds smoothly and reduces the need for repeated trial-and-error.
  • Fresh server: The most reliable imports happen on a fresh Mattermost installation. If importing into an existing server, never import over an existing team.
  • Server version: Make sure you are running the latest supported version of Mattermost to benefit from the most up-to-date functionality and fixes.
  • Backups: When importing into an already existing Mattermost environment, back up both the Mattermost database and the data directory before starting. If an import fails, you’ll need to roll back or reset.
    • If merging multiple Slack workspaces into a single team is the desired end-result, we recommend completing the import to separate teams, validating the results, then using mmctl to move channels between teams.
  • Configuration settings: Adjust the following settings before starting the import:
    • TeamSettings.MaxChannelsPerTeam: Set this to a number much higher than the number of channels you are migrating.
    • TeamSettings.MaxUsersPerTeam: Set this to a number much higher than the number of users you are migrating.
    • Team Settings > Allow any user with an account on this server to join this team: Ensure this is enabled for the team receiving the import.
    • EmailSettings.EnableSignUpWithEmail and EmailSettings.EnableSignInWithEmail: Both must be set to true
    • FileSettings.MaxFileSize: Set this higher than the largest file in your Slack export.
    • ElasticsearchSettings.EnableIndexing, ElasticsearchSettings > EnableSearching and ElasticsearchSettings.EnableAutocomplete: All must be set to false during the import to prevent performance issues. After the import, you can purge and reindex before enabling Elasticsearch.
Slack offers two ways to export your data from their product.
  1. Public channels export - Contains only public channel messages and file links. Available on all Slack plans. Generate this from Slack > Admin > Workspace settings > Security > Import & export data > Export.
  2. All channels and conversations export - Contains all messages including public channels, private channels, DMs, and group messages. Available on Business+ (requires application approval from the workspace primary owner) and Enterprise Grid plans.
You will receive a zip file containing the following contents:
  • Channels (channels.json)
  • Users (users.json)
  • Direct messages (dms.json) (All channels export)
  • Private channels (groups.json) (All channels export)
  • Group direct messages (mpims.json) (All channels export)
  • App activity logs (integration_logs.json)
  • Folders containing posts for every public channel
  • Folders containing posts for every private channel (All channels export)
Now that you have a Slack export file, let's convert it into Mattermost's bulk import format using the import preparation tool mmetl.
Download the latest release of mmetl for your OS and architecture. Run mmetl help to learn more about using the tool.
Before transforming, validate the integrity of your Slack export using the mmetl check command:
./mmetl check slack --file <SLACK EXPORT FILE>
This checks for structural issues in the export archive and reports any problems that may cause the transform or import to fail.
Run the transform
Run the command below to create a Mattermost bulk import file. Replace <TEAM-NAME> with the name of your team in Mattermost. Note that the name needs to be one word and lowercase (i.e. if you named your team My Team, <TEAM-NAME> would be my-team).
./mmetl transform slack --team <TEAM-NAME> --file <SLACK EXPORT FILE> --output mattermost_import.jsonl
The tool outputs a .jsonl file containing all of your users, channels, and posts. It also creates a data folder that contains all of your attachments. It doesn't matter what you name the .jsonl file. You can name it what you want with the --output flag as shown above. It just needs to be a .jsonl file.
Useful transform flags
The mmetl transform slack command supports several optional flags that can help with common migration scenarios:
  • --skip-attachments / -a: Skip copying attachments from the import file. Useful for faster iteration when testing the import process before including attachments.
  • --allow-download / -l: Allow downloading attachments from URLs.
  • --default-email-domain <DOMAIN>: When a user's email is missing from the export, generate one from their username and the provided domain (e.g., --default-email-domain example.com).
  • --skip-empty-emails: Allow users with empty email addresses to be included in the output. Note that this results in invalid import data that will need to be manually corrected before importing.
  • --discard-invalid-props / -p: Discard posts with invalid properties. By default, such posts are kept but imported without their properties.
Debug transform
The mmetl transform process produces a transform-slack.log file that records INFO level output by default.
If you run the import commands with the --debug flag, the log will include additional DEBUG level entries. These entries provide more granular detail on each phase of the process, which can help identify where the transformation may be slowing down or failing.
MMETL parsing phases
When parsing a Slack export file with the mmetl tool, the process runs through four phases. You can track progress by monitoring the log output during each phase. Understanding these phases helps set expectations for how long the parsing step may take.
1. Reading the import file
In this phase, mmetl reads through the Slack export file. Example log line:
&#123;"file":"parse.go:359","level":"info","msg":"Processing file 1 of 10335: aluminum-white-lightbulb/","time":"2024-03-11T20:41:09-04:00"&#125;
This step usually takes 5–10 minutes depending on the size of the export archive.
2. Converting user mentions
During this phase, mmetl converts Slack user mentions into Mattermost-compatible format. Example log line:
&#123;"file":"parse.go:224","level":"debug","msg":"Slack Import: converting user mentions for channel touchscreen-headphones-sleek. 1 of 400","time":"2024-03-11T20:41:10-04:00"&#125;
This step can be time-consuming on large imports and may take several hours.
3. Converting channel mentions
In this phase, channel references are updated. Example log line:
&#123;"file":"parse.go:259","level":"debug","msg":"Slack Import: converting channel mentions for channel robust-smart-home-device-matrix. 95 of 400","time":"2024-03-11T20:41:48-04:00"&#125;
This step typically completes in about half the time required for user mentions.
4. Converting post markup
Finally, Slack message formatting is converted into Mattermost-compatible Markdown. Example log line:
&#123;"file":"parse.go:330","level":"debug","msg":"Slack Import: converting markdown for channel vertex-robust-vacuum. 120 of 400","time":"2024-03-11T20:41:58-04:00"&#125;
This is the fastest step and usually completes quickly.
4. Import data into Mattermost
You can upload the export through Mattermost's API from the server or from another computer using mmctl commands. The server will save the import in its file store before running the import (e.g. AWS S3), so there will be time spent uploading/downloading the file in this case.
The migration is idempotent, meaning that you can run multiple imports that contain the same posts, and there won't be duplicated created posts in Mattermost. Each post is imported with the correct user/author and created_at value from your Slack instance.
Ensure you have the Mattermost command line tool mmctl installed. This allows you to perform different tasks that communicate to Mattermost's API. You'll also want to configure authentication for the tool.
To prepare our files to be uploaded to the server, we need to put both the .jsonl file and data folder together into a zip file.
zip -r mattermost-bulk-import.zip data mattermost_import.jsonl
Validate the import file locally before uploading. This checks the file structure and content without needing to upload it to the server:
mmctl import validate ./mattermost-bulk-import.zip
Then we can upload the zip file to our Mattermost server. These files can be very large, so getting them onto the server can be challenging. You have two primary options for this step:
  • You can use the mmctl tool:
    mmctl import upload ./mattermost-bulk-import.zip
  • Alternatively, you can move the file directly to the data directory under data/import and give it a unique name.
Run this command to list the available imports:
mmctl import list available
Run this command to process the import. Replace <IMPORT FILE NAME> with the name you got from the mmctl import list available command:
mmctl import process <IMPORT FILE NAME>
Finally, run this command to view the status of the import process job. If the job status shows as pending, then wait before running the command again. The --json flag is required to view the possible error message. Replace <JOB ID> with the id you got from the mmctl import job list command:
mmctl import job show <JOB ID> --json
Debug imports
You can use the mmctl import job show command to view any relevant errors that may have occurred.
Fixing unread channels and threads
After importing, all messages may appear as unread for users. To resolve this issue, run the following SQL queries directly against the Mattermost database:
begin;
UPDATE channelmembers
SET
msgcount = channels.totalmsgcount,
lastupdateat = channels.lastpostat,
lastviewedat = channels.lastpostat,
msgcountroot = channels.totalmsgcountroot
FROM channels
WHERE channelmembers.channelid = channels.id;
INSERT INTO preferences (UserId, Category, Name, Value)
SELECT
cm.userid,
'channel_approximate_view_time',
cm.channelid,
cm.lastupdateat
FROM
channelmembers cm
ON CONFLICT (userid, category, name)
DO UPDATE SET
Value = EXCLUDED.Value;
update preferences
set value = false
where category = 'direct_channel_show';
update preferences
set value = false
where category = 'group_channel_show';
commit;
Address placeholder emails
During the import process, the emails and usernames from Slack are used to create Mattermost accounts when no existing account is matched. If emails are not present in the Slack export archive, then placeholder values will be generated and the system admin will need to update these manually. We recommend administrators search the final import jsonl file for user lines with @example.com in the email property to address and resolve the missing information prior to import.
Email verification behavior
The email verification process during Slack import depends on who performs the import:
System administrator imports:
  • Email addresses are automatically verified during the import process.
  • Users can immediately use the Password Reset feature to set their password.
  • No email verification steps are required before password reset.
  • If a Slack user's email address matches an existing Mattermost account, that user is added to the existing account instead of a new one being created.
Non-administrator imports:
  • Email addresses remain unverified after import.
  • Users must first verify their email addresses before they can reset their password.
  • Additional email verification steps are required before account access.
  • If a Slack user's email address matches an existing Mattermost account, that user is not imported.
Account activation
  • Slack users activate or access their Mattermost accounts by using Mattermost's Password Reset screen with their email addresses from Slack to set new passwords for their Mattermost accounts. See the instructions on how to migrate user authentication to LDAP or SAML.
    • For imports performed by System Admins: Users can immediately use the Password Reset feature (no email verification is required).
    • For imports performed by non-administrators: Users must first verify their email addresses, then use the Password Reset feature.
  • Once logged in, Mattermost users will have access to previous Slack messages in the public channels imported from Slack.
FAQ
What additional considerations are there for Slack Enterprise Grid? ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Slack Enterprise Grid combines multiple workspaces under a single management plane and the associated export reflects that complexity. An Enterprise Grid export is a single archive containing all workspaces and shared channels.
Mattermost does not support shared channels between teams, so Slack Shared Channels must be mapped to a single team in Mattermost. We can create this mapping by determining the originating teams in Slack and creating a team.json mapping file for use with mmetl. Because of the manual effort required to identify and map team IDs, Enterprise Grid migrations are typically more time-consuming than single-workspace migrations. Plan additional time and resources to complete this step successfully.
Export structure
At the root level, you’ll see shared channels that span across Slack workspaces, and under /teams/ you’ll find per-workspace data such as channels and users files. A typical structure looks like:
Enterprise Grid Export/
├── channel1/
│ ├── 2023-01-01.json
│ └── 2023-01-02.json
├── channel2/
│ ├── 2023-05-01.json
│ └── 2023-05-02.json
├── teams/
│ ├── team1/
│ │ ├── channel3/
│ │ │ ├── 2023-05-01.json
│ │ │ └── 2023-05-02.json
│ │ ├── channels.json
│ │ ├── mpims.json
│ │ ├── dms.json
│ │ ├── users.json
│ │ └── groups.json
│ └── team2/
│ ├── channel4/
│ ├── channels.json
│ ├── mpims.json
│ ├── dms.json
│ ├── users.json
│ └── groups.json
├── channels.json
├── org_users.json
├── mpims.json
├── dms.json
└── groups.json
Mapping shared channels to Mattermost teams
  1. Download the full Enterprise Grid export from Slack.
  2. To determine where each shared channel belongs in Mattermost, look for a team attribute on the first post in each shared channel. These team values map the channel back to its originating workspace in Slack. This is where each shared channel will live in Mattermost once imported.
&#123;
"client_msg_id": "",
"type": "",
"text": "",
"user": "U1",
"ts": "1695219722.430309",
"blocks": [ ],
"team": "team1",
"user_team": "team1",
"source_team": "team1",
"user_profile": &#123; &#125;
&#125;,
  1. Create a teams.json file that maps Slack team IDs to each team attribute you found above. For example:
&#123;
"T0001" : "team1",
"T0002" : "team2"
&#125;
  1. Run the mmetl grid-transform command to split the Enterprise Grid export into per-team files:
./mmetl grid-transform -f slackexport.zip -t teams.json
This process outputs a new archive for each team defined in teams.json. Once split, you can continue the standard Mattermost import process on each file.
Are there features of Slack that are not supported for migration to Mattermost?
The Slack import process focuses on preserving core collaboration data such as messages, files, channels, and users. However, certain Slack features are not supported by the Mattermost product and thus will not be migrated using the import tools in this document:
  • Slack apps and integrations: Installed apps, bots, slash commands, webhooks, workflow builder and other integrations do not migrate. Most integrations supported by Slack can be recreated using the integration and automation options in Mattermost.
  • Starred conversations: Starred conversations are not preserved.
  • User groups: User groups from Slack are not preserved, however they can be recreated in Mattermost using the Custom Groups feature.
  • Threaded conversations: Slack threads are mostly supported, however some threading relationships may not always be preserved given the differences in how Mattermost and Slack threading works.
  • Canvases: Canvases are not supported in Mattermost and will not be migrated.
  • User presence and profiles: User status (online/away), profile pictures, and custom profile fields do not carry over. Users will need to update their profiles in Mattermost.
  • Channel memberships for deactivated users: Deactivated or deleted Slack users are not migrated to Mattermost.
Because of these limitations, some manual reconfiguration is typically required after the import, especially for workflows and integrations. Support from a Mattermost expert is available for your Slack migration.
