Secure Command and Control
Expanding adversarial risk across cyber and kinetic domains requires faster, more secure, and better-informed coordination across mission environments. Traditional communication systems often fall short in high-stakes operational contexts—where minutes matter, information must remain contained, and decision advantage is critical to mission success. In an age of contested networks, personal device sprawl, and fragmented toolsets, organizations need a unified, secure platform to bridge communication and coordination gaps.
Mattermost provides a secure, extensible Command & Control platform that accelerates decision advantage through real-time collaboration and mission-aligned workflows. It enables operational units, contractors, and mission partners to work together in tightly controlled environments—whether connected, disconnected, or degraded. With support for secure mobility, ChatOps, classified deployment models, and sovereign AI integrations, Mattermost empowers organizations to act faster, coordinate securely, and maintain operational resilience across the full mission lifecycle.
Secure, Mission-Focused Collaboration to Enable Faster, Informed Decision-Making across Environments.
The following mission-ready coordination capabilities are available:
Mission-Critical ChatOps​
In high-stakes missions—including classified operations—real-time collaboration and secure workflows are essential for operational success. Mattermost unifies teams, toolchains, and decision-makers into a single secure environment.
Benefits
  • Surface essential context faster for decisive action using threaded messaging, file previews, and channel-based discussion to consolidate signals and reduce noise.
  • Integrate mission tooling and automation via the Mattermost integrations platform—connecting alerting, workflow engines, and tactical systems directly into operational channels.
  • Strengthen mobile communication channels through enterprise mobility security that reduce reliance on personal messaging apps, control data exposure, and ensure secure, compliant access.
  • Coordinate operations with structured workflows using Collaborative Playbooks that standardize task execution, streamline decision-making, and maintain continuity across teams and mission roles.
  • Deploy sovereign AI for operational intelligence using air-gapped and private AI operations to power decision support and automation in disconnected or classified settings.
Disconnected, Intermittent, and Low-Bandwidth (DDIL) Collaboration​
Disconnected environments demand resilient tools that work without cloud access, persistent connectivity, or conventional device infrastructure.
Mattermost's Self-Hosted Kubernetes-based Collaborative Workflow platform installs on edge, cloud and custom data center platforms.
Benefits
Bring Your Own Device (BYOD) with Sensitive Information Protections​
Modern operations often require users—such as field personnel, mission partners, or remote contractors—to access critical communication tools from personal or unmanaged mobile devices. However, this flexibility introduces new risks when sensitive information or other protected data is involved. Without strong protections, mobile access becomes a liability in contested or regulated environments.
Mattermost provides enterprise-grade mobile protections to enable secure BYOD access without compromising security or compliance. From mobile application management and encryption enforcement to biometric authentication and jailbreak detection, Mattermost ensures that data remains protected, access is governed, and sensitive information stays within authorized boundaries.
Benefits
  • Mitigate unauthorized access with biometric authentication and jailbreak/root detection, ensuring only secure and uncompromised devices can access mission data.
  • Control information sharing with screenshot and screen recording prevention, blocking unauthorized capture of sensitive content during classified or time-sensitive discussions.
  • Protect data at rest and in motion using encrypted mobile storage, secure sandboxing, and ID-only push notifications that never expose message content to third-party cloud services.
  • Segment mission access by role or project with attribute-based access controls (ABAC) and scoped channel access, ensuring users only see data aligned with their permissions and operational role.
  • Ensure continuous mobile compliance with secure SDLC practices and proactive vulnerability management baked into the Mattermost mobile application lifecycle.
Mission-Partner Environments​
Coordinating across departments, agencies, and external stakeholders—especially in multinational or coalition contexts—requires secure boundaries, role separation, and deployment flexibility.
Benefits
  • Unify mission stakeholders on a common-use platform that supports hybrid deployments across private cloud, edge environments, and air-gapped infrastructure.
  • Maintain data sovereignty and mission alignment with deployments that avoid consumer infrastructure and retain control over all communications and file transfers—even in classified operations.
  • Apply role-based separation of access through advanced permissions and channel-level controls to protect mission integrity across organizational boundaries.
  • Enable secure real-time collaboration across entities using Connected Workspaces to synchronize discussions, files, and reactions between teams without compromising internal governance.
  • Reduce personal device risk by offering secure enterprise communication options that eliminate the need for unauthorized messaging apps.
Get Started​
Talk to an Expert to explore how Mattermost supports secure, real-time Command and Control collaboration. Whether you're coordinating joint operations, managing disconnected mission environments, or securing tactical communications in classified settings, Mattermost provides the control, scalability, and resilience your teams need to operate with speed, confidence, and compliance.
