Configure SAML with Keycloak
The following process provides steps to configure SAML with Keycloak for Mattermost.
Set up Keycloak for Mattermost SSO​
  1. Log in to Keycloak as an administrator.
  2. Select Clients, then Create client. You'll use this client ID in a later step.
  • Client type: SAML
  • Client ID: mattermost
  1. Click Next and update the following values:
  • Root URL: http://your-mattermost-url.com
  • Home URL: /login/sso/saml
  • Valid redirect URIs: /login/sso/saml
  1. Save the client.
  2. Under the Settings tab, update the following values:
  • Enabled: On
  • Name ID format: email
  • Force Name ID format: On
In Keycloak, create the Mattermost client, specify the Client ID and Client Protocol, then save your changes.
  1. Under the Signature and Encryption section, update the following values:
  • Sign Documents: Off
  • Sign Assertions: On
  • Signature Algorithm: RSA_SHA256
  • SAML signature key name: NONE
  • Canonicalization Method: EXCLUSIVE
  • Encryption Algorithm: AES_256_GCM
  • Key Transport Algorithm: RSA_OAEP_MGF1P
  • Digest method for RSA-OAEP: SHA1
In Keycloak, configure the Signature and Encryption settings for the Mattermost client.
Note
Earlier versions of this documentation recommended RSA_SHA1. Use RSA_SHA256 instead. NIST SP 800-131A set December 31, 2013 as the deadline after which SHA-1 is disallowed for digital signature generation. Revision 2 of that publication, published in March 2019, allows SHA-1 signature generation only where NIST protocol-specific guidance specifically permits it. A Keycloak server running in FIPS mode returns a 500 error when it tries to sign the assertion with RSA_SHA1. Mattermost validates RSA_SHA256-signed assertions, and Keycloak derives the signature digest method from the signature algorithm you select here.
Warning
Mattermost FIPS builds from v12.2 reject SHA-1, so the RSA_OAEP_MGF1P and SHA1 settings above fail at login. If you run a FIPS build, use these values instead:
  • Key Transport Algorithm: RSA_OAEP_11
  • Digest method for RSA-OAEP: SHA256
  • Mask generation function: MGF1_SHA256
Changing only the digest to SHA256 isn't enough. Keep RSA_OAEP_MGF1P and decryption fails, because that algorithm always uses MGF1-SHA1. See SAML encryption methods for the algorithm URIs. Non-FIPS builds aren't affected.
  1. Navigate to the Keys tab.
  • Client signature required: Off
  • Encrypt Assertions: On
    1. Click Generate
    2. Download the private.key file.
    3. Click Confirm
    In Keycloak, on the Keys tab, generate new keys for encryption.
    Warning
    Leave Client signature required off, as shown above. Mattermost does sign its authentication requests when you enable Sign Request in step 4 of the Mattermost section below, but Keycloak validates those signatures only if you also import the Mattermost service provider certificate as a signing key on this tab. Turning Client signature required on without importing that certificate causes Keycloak to reject Mattermost's authentication requests.
    Note
    If your Keycloak server runs in FIPS mode, the Archive Format list offers only BCFKS, because PKCS12 and JKS are unavailable. Export the BCFKS keystore, then convert it to PKCS12 before you continue:
    keytool -importkeystore -srckeystore keystore.bcfks -srcstoretype BCFKS -providerclass org.bouncycastle.jcajce.provider.BouncyCastleFipsProvider -providerpath /path/to/bc-fips-<version>.jar -destkeystore keystore.p12 -deststoretype PKCS12
    Point -providerpath at your Bouncy Castle FIPS JAR. keytool prompts for the source and destination store passwords. The converted keystore.p12 then works with the extraction commands in step 4 of Configure SAML in Mattermost below.
    Convert the whole keystore as shown above rather than looking for a way to export the key on its own, because keytool has no command that exports a private key by itself.
    As an alternative, generating the keypair locally and importing only the certificate into Keycloak avoids the keystore conversion entirely, and works on FIPS and non-FIPS servers alike:
    openssl req -x509 -newkey rsa:2048 -nodes -days 1095 -subj "/CN=mattermost" -keyout mattermost.key -out mattermost.crt
    Keep -nodes, because Mattermost can't read a passphrase-protected private key. Set -days explicitly, because it defaults to 30. Keep -keyout and -out, because without them the certificate goes to standard output and the private key goes to a configuration-dependent default filename.
    Import only mattermost.crt into the encryption keys section of this tab, then upload both files in step 4 below and skip the openssl pkcs12 extraction commands, since you already have the files those commands would have produced.
    Next, click Export and update the following values and download the keystore.p12 file.
    • Archive Format: PKCS12
    • Key Alias: mattermost
    • Key Password: mattermost
    • Store Password: mattermost
    In Keycloak, on the Keys tab, generate new keys, export using the values documented, then select Download.
  1. Navigate to the Client scopes tab.
    First we add the predefined mappers for email, first name, and last name.
    1. Select mattermost-dedicated
    2. Click Add predefined mapper
    3. Select the X500 email, X500 givenName, and X500 surname attributes.
    4. Click Add.
    Next, we add the mappers for username and id.
    1. Select Add Mapper -> By Configuration -> User Property.
    2. Set Name to Username.
    3. Set Property to username (This is case sensitive and must be lowercase).
    4. Set SAML Attribute Name to username.
    5. Select Save.
    In Keycloak, on the Mappers tab, create a protocol mapper, then save your changes.
    1. Repeat the above steps and use the custom property of id to create the ID Attribute.
    In Keycloak, on the Mappers tab, create a protocol mapper for the ID attribute, then save your changes.
Once done your Mappers should look like this:
Example of protocol mapper configuration.
  1. Get the metadata URL from Keycloak:
    1. Within your Realm, select Realm Settings.
    2. At the bottom of the General tab you should see a SAML 2.0 Identity Provider Metadata endpoint. Right-click and copy this URL. Store for the next step.
    Within your Realm, select Realm Settings. At the bottom of the General tab, you should see a SAML 2.0 Identify Provider Metadata endpoint. Copy this URL for the next step.
Configure SAML in Mattermost​
  1. In the Mattermost System Console go to Authentication > SAML.
  2. Set the Identity Provider Metadata URL to the value you copied from the step above and select Get SAML Metadata from IdP. The metadata import will populate fields related to your Keycloak configuration.
    If you have any issues with this import, you can check the mattermost.log file for more information. Enable debug logging and try again.
    In Mattermost, configure SAML in the System Console by going to Authentication &gt; SAML. Set the Identity Provider Metadata URL to the value you copied in the previous step. When you select Get SAML Metadata from IdP, fields related to your Keycloak configuration are populated.
  1. Set the below fields:
    • Verify Signature: false
    • Service Provider Login URL: http://your-mattermost-url.com/login/sso/saml
    • Service Provider Identifier: mattermost
    The Service Provider Identifier will match the Client ID that you configured in the second Keycloak step.
    In the System Console, configure SAML as documented, where the Service Provider Identifier matches the Client ID you configured in Keycloak.
  2. Configure the Encryption using the key you downloaded in step 6 of the Keycloak config.
    1. Generate the .crt file from the .p12 file.
    openssl pkcs12 -password pass:mattermost -in keystore.p12 -out mattermost.crt -nodes -legacy
    1. Generate the .key file from the .p12 file.
    openssl pkcs12 -password pass:mattermost -in keystore.p12 -out mattermost.key -nodes -nocerts -legacy
    1. Upload both of these files within the Mattermost System Console. Make sure to select Upload.
    • Service Provider Private Key: mattermost.key
    • Service Provider Private Certificate: mattermost.crt
    • Sign Request: true
    • Signature Algorithm: RSAwithSHA256
    • Canonicalization Algorithm: Exclusive XML Canonicalization 1.0 (omits comments)
    In the System Console, upload both the Service Provider Private Key and the Service Provider Private Certificate.
  3. Set attributes for the SAML Assertions, which will update user information in Mattermost.
    The attributes below are from steps 7 and 8 above. These values must be the SAML Attribute Name within Keycloak. See documentation on SAML configuration settings for more details.
    • Email Attribute: email
    • Username Attribute: username
    • Id Attribute: id
    Set attributes for the SAML assertions which updates user information in Mattermost.
  4. Select Save.
To confirm SAML is working correctly, log out of Mattermost or open Mattermost in a new Incognito Browser Window and select Sign in with SAML on the login page and login with an existing Keycloak account.
If you have existing users in Mattermost that are going to be migrated to SAML login, make sure to plan for user migration and update your users accordingly.
You may also configure SAML for Keycloak by editing config.json. Before starting the Mattermost server, edit config.json to enable SAML based on SAML configuration settings. You must restart the Mattermost server for the changes to take effect.
Configuing a SAML user as a Guest in Keycloak​
  1. In Mattermost, go to System Console > Authentication > SAML.
  2. Set the Guest Attribute to designate which SAML users are guests.
    In Mattermost, configure the SAML guest attribute
  3. In the Keycloak administration interface, add a user attribute mapper for guests.
  1. Select Clients from the LHS menu.
  2. Select mattermost from the list.
  • Select the Client Scopes tab
  • Select mattermost dedicated from the list of scopes
  • Click the Add mapper drop down and select By configuration
  • Select User Attribute on the model that opens
  • Add values for Name, User Attribute and SAML Attribute Name as shown
&lt;Add attribute mapper&gt;
  1. In Keycloak specify which users are guest by adding the attribute under User details
  1. Select Users from the LHS menu.
  2. Select the username of the desired user.
  3. Select the Attribute tab and select + add an attribute.
  4. Add the key and value.
An example of adding an attribute to a user.
To re-activate the account:
Override SAML data with AD/LDAP data​
What encryption options are supported for SAML?​
How to bind authentication to Id attribute instead of email​
Why does login fail with "one of the attributes is incorrect" / "<attribute> attribute is missing"?​
To resolve this:
Can SAML via Microsoft ADFS be configured with Integrated Windows Authentication (IWA)?​
Can I provision and deprovision users who log in via SAML?​
How do I migrate users from one authentication method (e.g. email) to SAML?​
How is SAML different from OAuth 2.0 and OpenId Connect?​
:start-after: :nosearch:
