Build a component
This page describes how to build a new React component in the Mattermost web app. A new component must meet the following requirements:
  1. Is pure, meaning that all information required to render is passed in by props.
  2. Has no direct store interaction. Use connect to wrap the component if needed.
  3. Has component tests.
  4. Is generic and re-usable when possible.
  5. Has documented props.
If none of those make any sense to you or you're new to React and Redux, then check out these links:
These requirements are discussed in more detail in the following sections.
Design the component​
The most important part of designing your component is deciding on what the props will be. Props are very much the API for your component. Think of them as a contract between your component and the users.
Props are read-only variables that get passed down to your component either directly from a parent component or from an index.ts container that connects the component to the Redux store.
How do you decide what props your component should have? Think about what your component is trying to display to the user. Any data you need to accomplish that should be part of the props.
As an example, let's imagine we're building an ItemList component with the purpose of displaying a list of items. The props for such a component might look like:
type Props = {
* The title of the list
title?: string;
* An array of items to display
items: ListItem[];
The title prop is a string that's displayed as the title of the list, and items is an array of objects that make up the contents of the list. Note that items is required while title is optional.
Make sure you add brief but clear comments to each prop type as shown in the example.
Our ItemList component would live in a file named item_list.tsx.
Use a Redux container component​
The next question to ask yourself is whether you're going to need a container component. This is the index.ts file mentioned above. If your component needs either of the following, then you'll need a container:
  1. Needs some data injected into its props that the parent component doesn't have access to
  2. Needs to be able to perform some sort of action that affects the state of the store
Continuing the ItemList example above, maybe our parent component doesn't care about our list of items and doesn't have access to them. Let's also imagine that we want to let the user remove items from the list by clicking on them. This means our component now needs a container for both criteria above and our props will change slightly:
type Props = {
title?: string;
* An array of item components to display
items: ListItem[];
actions: {
* An action to remove an item from the list
removeItem: (item: ListItem) => void;
Note that the type definition for actions passed from Redux won't include the any reference to Redux's dispatch or Redux Thunk's getState. This is intentional as connect hides those details from the component.
The container will then handle getting data from the Redux state in mapStateToProps and passing Redux actions to the component using mapDispatchToProps. Note that either of these are optional if only one is needed.
import {connect} from 'react-redux';
import {bindActionCreators, Dispatch} from 'redux';
import {removeItem} from 'mattermost-redux/actions/items';
import {getItems} from 'mattermost-redux/selectors/entities/items';
import {GlobalState} from 'types/store';
import ItemList from './item_list';
function mapStateToProps(state: GlobalState) {
return {
items: getItems(state),
function mapDispatchToProps(dispatch: Dispatch) {
return {
actions: bindActionCreators({
removeItem,
}, dispatch),
export default connect(mapStateToProps, mapDispatchToProps)(ItemList);
If the selectors and/or actions you need don't yet exist in Redux then you should go add those first by following the guide to adding actions and selectors.
Your index.ts and item_list.ts files will live together in an item_list/ directory.
Implement the component​
With the props defined and, if necessary, the container built, you're ready to implement the rest of your component. For the most part, implementing a component for the web app is no different than building any other React component. While older code tends to use class components which extend React.PureComponent, most newer code should use functional components.
Our ItemList example might look something like this:
type Props = {
title?: string;
items: ListItem[];
actions: {
export default function ItemList(props: Props) {
const title = this.props.title ? <h1>{this.props.title}</h1> : null;
const items = this.props.items.map((item: ListItem) => (
<Item
key={item.id}
item={item}
removeItem={this.props.actions.removeItem}
return (
<div className='item-list'>
{title}
{items}
</div>
To test your component, follow the guide here.
