System Console
Add fields to the configuration​
In order to add fields to the configuration, you need to modify model/config.go in the server by adding the desired field to one of the structs such as ServiceSettings and setting its default value in the corresponding SetDefaults method.
Note that some of the configuration values are collected as telemetries. The telemetry definitions are defined in the services/telemetry package. Once a configuration is added, it should be added to the telemetry package. If the configuration value is not going to be collected as a telemetry, a // telemetry: none comment must be added to prevent the configtelemetry check from failing.
Also we use struct tags to identify access level for configuration values. If the value requires a restriction, please use this tag accordingly.
Expose settings in the System Console​
To expose the newly-added field in the System Console, you need to add that same setting to the AdminDefinition JS object in webapp/channels/src/components/admin_console/admin_definition.jsx. This object defines most of the settings in the System Console.
Make settings available for non-admin users​
To make the newly added setting accessible to non-admin users in the apps, you'll need to add it to the GenerateClientConfig method in config/client.go in the server. Note that this always encodes the setting as a string, so anywhere that you would want to use this value in the client, you have to look for a string.
