Code review
All changes to the product should be reviewed. Every team will have its own workflow, but in general:
  • User experience changes should be reviewed by a product manager or designer.
  • Code changes should be reviewed by at least two core committers.
  • Documentation changes should be reviewed by a product manager or technical writer.
Staff should consult the internal organization chart as needed when finding the right reviewer.
If you are a community member seeking a review​
  1. Submit your pull request.
  2. Wait for a reviewer to be assigned.
    • Product managers are on the lookout for new pull requests and usually handle this for you automatically.
    • If you have been working alongside a core committer, feel free to message them for help.
    • When in doubt, ask for help in the Developers channel on our community server.
    • If you are still stuck, message Jason Blais (@jasonblais on GitHub) or Jason Frerich (@jfrerich on GitHub).
  3. Wait for a review.
    • Expect some interaction with at least one reviewer within 5 business days. (Business days are typically Monday to Friday, excluding statutory holidays.)
    • Keep in mind that core committers are geographically distributed around the world and likely in a different time zone than your own.
    • If no interaction has occurred after 5 business days, at-mention a reviewer with a comment on your PR.
  4. Make any necessary changes.
    • If a reviewer requests changes, your pull request will disappear from their queue of reviews.
    • Once you've addressed the concerns, re-request a review from any reviewer requesting changes.
    • Avoid force pushing.
  5. Wait for your code to be merged.
    • Larger pull requests may require more time to review.
    • Once all reviewers have approved your changes, they will handle merging your code.
If you are a core committer seeking a review​
  2. Immediately add the 1: UX Review, 2: Dev Review, and 3: QA Review labels.
    • Your pull request should not be merged until these labels are later removed in the review process.
  3. Apply additional labels as necessary:
    • CherryPick/Approved: Apply this if the pull request is meant for a quality or patch release.
    • Do Not Merge/Awaiting PR: Apply this if the pull request depends on another (e.g. server changes)
    • Setup Test Server: Apply this to create a test server with your changes for review.
    • See labels for additional documentation.
  4. Assign a milestone as necessary.
    • Most pull requests do not require a milestone, but will simply ship once merged.
    • Some reviewers may prioritize reviews for known upcoming milestones.
    • The milestone is mandatory for bug fixes that must be cherry-picked.
  5. Request a review from a Product Manager and/or a Designer.
    • The choice of Product Manager or Designer is up to you.
      • In most cases, choose the individual embedded with your team.
      • If your change primarily touches another team's codebase, assign the individual from that team.
      • If in doubt, assign any Product Manager or Designer and comment about the uncertainty. They may reassign as appropriate.
    • Wait for their review to complete before continuing so as to avoid churn if changes are requested.
    • Remove the 1: UX Review label only when these reviews are done and they accept the changes.
    • If your changes do not affect the user experience, you may remove 1: UX Review immediately.
  6. After UX review, request a review from two core committers.
    • The choice of core committers is up to you.
      • When picking your first core committer, consider someone with domain expertise relative to your changes. Sometimes GitHub will recommend a recent editor of the code, but often you must rely on your own intuition from past interactions.
      • When picking your second core committer, consider someone who may have expertise in the language you're using or the problem you're solving, even if they aren't intricately familiar with the codebase. This can provide a fresh set of eyes on the code to reveal blindspots that are not biased by hitting deadlines, and helps expose the team to new parts of the code to help spread out domain knowledge. This may not make sense for every pull request but is a practice to keep in mind. If you don't have someone specific in mind, consider using the @core-reviewers group to assign an available reviewer automatically.
      • Don't be afraid to pick someone who gives "hard" reviews. Code review feedback is never a personal attack: it should "sharpen" the skills of both the author and the reviewers, not to mention improving the quality of the product.
      • Try to avoid assigning the same person to all of your reviews unless they are related.
      • When in doubt, ask for recommendations on our community server.
    • Remove the 2: Dev Review label only when these reviews are done and they accept the changes.
  7. After Dev review, assign a QA tester.
    • Ensure that your PR includes test steps or expected results for QA reference if the QA Test Steps in the Jira ticket have not already been filled in.
    • The choice of QA tester is up to you.
      • If in doubt, assign any QA tester and comment about the uncertainty. They may reassign as appropriate.
    • Wait for their review to complete before continuing.
      • It is the QA tester's responsibility to determine the scope of required testing, if any.
    • Remove the 3: QA Review label only when their review is done and they accept the changes.
    • In the rare event your changes do not require QA review, you may remove 3: QA Review immediately.
      • Comment on the pull request clearly explaining the rationale.
  8. Merge the pull request.
    • Do not merge until the labels 1: UX Review, 2: Dev Review and 3: QA Review labels have been removed.
    • Add the 4: Reviews Complete label if the last reviewer did not already add it.
    • Do not merge if there are outstanding changes requested.
    • Merge your pull request and delete the branch if not from a fork.
      • Note that any core committer is free to merge on your behalf.
      • If your pull request depends on other pull requests, consider assigning the Do Not Merge/Awaiting PR label to avoid merging prematurely.
  9. Handle any cherry-picks.
    • There is an automated cherry-pick process.
    • As the author of the pull request, you should make sure the cherry-pick succeeds.
    • Check here for details.
  10. After a pull request is merged (and cherry-picked where needed), update the Jira ticket.
    • Resolve the ticket for QA from "Ready for QA" button with QA test steps (or "No Testing Required" if no QA testing is needed).
If you are awaiting a review​
  1. Wait patiently for reviews to complete.
    • Expect some interaction with each of your reviewers within 2 business days.
    • There is no need to explicitly mention them on the pull request or to explicitly reach out on our community server.
    • Core committers and QA testers are expected to have the GitHub plugin installed to automate notifications and to trigger a daily review of their outstanding requested reviews.
  2. Make any necessary changes.
    • Once you've addressed the concerns, assign them as a reviewer again to put your pull request back in their queue.
If you are a core committer asked to give a review​
  1. Respond promptly to requested reviews.
    • Assume the requested review is urgent and blocking unless explicitly stated otherwise.
    • Try to interact with the author within 2 business days.
    • Configure the GitHub plugin to automate notifications.
    • Review your outstanding requested reviews daily to avoid blocking authors.
    • Prioritize earlier milestones when reviewing to help with the release process.
    • Responding quickly doesn't necessarily mean reviewing quickly! Just don't leave the author hanging.
  2. Feel free to clarify expectations with the author.
    • If the PR adds a substantial feature, check that a feature flag is included. Please see criteria here.
    • If the code is experimental, they may need only a cursory glance and thumbs up to proceed with productizing their changes.
    • If the review is large or complex, additional time may be required to complete your review. Be upfront with the author.
    • If you are not comfortable reviewing the code, avoid "rubber stamping" the review. Be honest with the author and ask them to consider another core committer.
  3. Never rush a review.
    • Take the time necessary to review the code thoroughly.
    • Don't be afraid to ask for changes repeatedly until all concerns are addressed.
    • Feel free to challenge assumptions and timelines. Rushing a change into a patch release may cause more harm than good.
  4. Avoid leaving a review hanging.
    • Try to accept or reject the review instead of just leaving comments.
    • If you are the last developer to approve the changes, consider requesting a review from the appropriate QA tester to speed up the process.
  5. Run the E2E tests against the PR code
    • After the PR has been reviewed, the reviewer should trigger an E2E test run on it by using one of the available mechanisms. The E2E Test result will be posted back to the PR as a comment.
    • It's the PR author's responsibility to address the E2E test failures, with the assistance of the reviewers.
    • Core committers can refer to this Confluence page for additional informations on E2E testing and related processes.
  6. Merge the pull request.
    • Do not merge if there are any Do Not Merge labels applied.
      • When in doubt, leave the merging of the pull request to the author.
    • Merge the pull request, and delete the branch if not from a fork.
  7. Handle any cherry-picks.
    • There is an automated cherry-pick process and the author of the pull request should make sure the cherry-pick succeeds. Assume this is the case unless you are explicitly asked to help cherry-pick.
