Enterprise search
Mattermost database search starts to show performance degradation at around 2 million posts, on a server with 32 GB RAM and 4 CPUs. If you anticipate your Mattermost server reaching more than 2.5 million posts, we recommend enabling Elasticsearch or AWS OpenSearch Service for optimum search performance before reaching 3 million posts. Both tools are highly capable and can handle enterprise-scale workloads. The choice between them depends on the following factors:
  • Licensing and cost: AWS OpenSearch may be preferable for organizations avoiding proprietary licensing or opting for cost-effective solutions.
  • Feature requirements: Elasticsearch's proprietary features (e.g., advanced analytics, security suites) may be preferred by organizations needing powerful out-of-the-box functionality.
  • Infrastructure alignment: AWS OpenSearch aligns well with AWS-centric environments, while Elasticsearch offers broader integrations.
Elasticsearch​
Elasticsearch is a well-established and widely used search engine with a large ecosystem and community support that provides enterprise-scale deployments with optimized search performance, dedicated indexing, and usage resourcing via cluster support for fast, predicable search results.
Mattermost's implementation uses Elasticsearch as a distributed, RESTful search engine supporting highly efficient database searches in a cluster environment. Learn more about setting up and configuring Mattermost for an Elasticsearch server.
AWS OpenSearch Service​
AWS OpenSearch Service is the official path forward from Elasticsearch v7.10.x for AWS customers. It's a fully managed service that makes it easy to deploy, operate, and scale OpenSearch clusters in the AWS Cloud to provide a simple and cost-effective way to search, analyze, and visualize data in real time.
The AWS OpenSearch Service is built on the open-source OpenSearch project, which is a community-driven fork of Elasticsearch. Learn more about setting up and configuring Mattermost for an OpenSearch server.
Supported paths​
Review the following support paths for enterprise search based on the version you're using:
Elasticsearch v9 is supported from Mattermost v11.7. We recommend upgrading to Elasticsearch v9 for the latest features and security updates. See the Elasticsearch upgrade documentation for upgrade details, and see the Elasticsearch setup documentation for details on configuring your Mattermost deployment to use Elasticsearch.
Frequently asked questions (FAQ)​
Do I need to use Elasticsearch or AWS OpenSearch?​
No. Enterprise search engines are designed for large Enterprise deployments to run highly efficient database searches in a cluster environment. The default Mattermost database search starts to show performance degradation at around 2.5 million posts, depending on the specifications for the database server. If you expect your Mattermost server to have more than 2.5 million posts, we recommend using Elasticsearch or AWS OpenSearch for optimum search performance.
Should I install Elasticsearch or OpenSearch on the same machine as Mattermost Server?​
No. We strongly recommend that you install Elasticsearch or AWS OpenSearch on a dedicated machine that's separate from the Mattermost server.
What types of indexes are created?​
Mattermost creates three types of indexes: users, channels, and posts. Users and channels have one index each. Posts are aggregated by date, into multiple indexes.
Can I pause an search indexing job?​
Yes. From Mattermost v6.7, the search indexing job is resumable. Stopping a server while the search indexing job is running puts the job in pending status. The job resumes when the server restarts. System admins can cancel an indexing job through the System Console.
Can an index rollover policy be defined?​
The AggregatePostsAfterDays configuration setting defines a cutoff value. All posts preceding this value are reindexed and aggregated into new and bigger indexes. The default setting is 365 days.
Are there any new search features offered with Elasticsearch?​
The current implementation of Elasticsearch matches the search features currently available with database search. The Mattermost team is working on extending the Elasticsearch feature set with file name and content search, date filters, and operators and modifiers.
Are my files stored in Elasticsearch or OpenSearch?​
No, files and attachments are not stored.
How do I monitor system health of an Elasticsearch server?​
You can use this Prometheus exporter to monitor various metrics about Elasticsearch: justwatchcom/elasticsearch_exporter.
You can also refer to this article about Elasticsearch performance monitoring. It's not written specifically for Prometheus, which Mattermost's performance monitoring system uses, but has several tips and best practices.
What form of data is sent to Elasticsearch or OpenSearch?​
Mattermost communicates with Elasticsearch or OpenSearch through its REST API using JSON messages for indexing and querying entities.
How much data is sent to Elasticsearch or OpenSearch and when?​
Every time a message is published, a channel is created, or a user changes, (either because their properties change e.g.: change of the first name or because they join/leave a channel), the data associated with that event is sent to Elasticsearch or OpenSearch.
If search via Elasticsearch or OpenSearch is enabled, every search will generate a query. If autocompletion is enabled, every user or channel autocompletion associated with writing a message or user search will generate a query.
How do I know if a search job fails?​
Mattermost provides the status of each Elasticsearch or OpenSearch indexing job in System Console > Environment > Elasticsearch. Here you can see if the job succeeded or failed, including the details of the error.
Failures are returned in the server logs. The error log begins with the string Failed job and includes a job_id key/value pair. Search job failures are identified with worker name EnterpriseElasticsearchAggregator and EnterpriseElasticsearchIndexer. You can optionally create a script that programmatically queries for such failures and notifies the appropriate system.
How do I diagnose enterprise search connection issues?​
From Mattermost v11, Support Packet generation automatically tests the connection to your configured Elasticsearch or AWS OpenSearch server and includes any connection errors in the Support Packet. This provides valuable diagnostic information including server version, installed plugins, and specific error details if the connection fails.
The enterprise search connection test results appear in the Support Packet and can help identify configuration issues such as network connectivity problems, authentication failures, or server availability issues. If connection errors are present, they will be clearly documented with specific error messages to aid in troubleshooting.
How does Mattermost handle Elasticsearch or OpenSearch outages?​
From Mattermost v11.7, the server includes an automatic health monitor for Elasticsearch and OpenSearch connections. The health monitor runs periodic health checks and automatically manages the connection lifecycle:
  • Health checks: The server checks the health of the search engine cluster every 60 seconds. After 3 consecutive health check failures, the engine is stopped and search falls back to the database.
  • Fast-fail on first failure: On the very first health check failure, the engine is immediately marked as unhealthy and search requests are routed to the database. This happens before the consecutive failure threshold is reached, so users experience minimal disruption.
  • Automatic retry: When the search engine is unavailable, the server retries connecting with exponential backoff, starting at 15 seconds and doubling up to a maximum of 5 minutes between attempts.
  • Automatic recovery: When the search engine becomes available again, the server automatically reconnects and resumes using it for search queries. No manual intervention or server restart is required.
  • Configuration changes: Changes to Elasticsearch or OpenSearch configuration settings, or license changes, immediately trigger the health monitor to re-evaluate the connection state.
  • Monitoring: A mattermost_search_engine_status Prometheus metric reports the health of the search engine (1 = healthy or not configured, 0 = configured but unavailable). Use this metric to set up alerts for search engine outages. See performance monitoring metrics for details.
During an outage, you may see the following log messages:
LevelLog messageMeaning
ErrorSearch engine health check failed repeatedly; stopping engineThe failure threshold was reached and the engine has been stopped. Search falls back to the database.
WarnSearch engine health check failedAn individual health check failed. Includes a consecutive_failures count.
WarnSearch engine health check failed: it is now marked as unhealthyA previously healthy engine failed a health check and has been marked unhealthy. Search requests will fall back to the database immediately.
ErrorSearch engine watcher: Start() failed, will retryA reconnection attempt failed. Includes a next_backoff field indicating the time until the next retry.
InfoSearch engine health check succeeded: it is now marked as healthyThe engine passed a health check after being unhealthy and is now handling search requests again.
InfoSearch engine watcher: engine started successfullyThe engine has recovered and is active again.
InfoSearch engine watcher: engine disabled, parkingThe health monitor is idle because the search engine is disabled in configuration.
My search indexes won't complete, what should I do?​
If you have an search indexing job that's paused, it's likely your Elasticsearch or OpenSearch server has restarted. If you restart that server, you must also restart Mattermost to ensure jobs are completed. If restarting the Mattermost server does not resolve the issue, customers with a Mattermost subscription can contact Mattermost Support for assistance.
Do I need to purge first then bulk index each time?​
Yes. Every time you choose to remove old data (purge), you must follow it up with a bulk index operation to repopulate them with new data. When you purge (delete) indices, you are removing the existing data from Elasticsearch. After purging, if you want to repopulate the indices with fresh data, you perform a bulk index operation to rebuild the indices efficiently. The bulk API allows for indexing, deleting, or updating multiple documents in a single request, which is faster and more efficient than processing documents one by one.
Required Permissions For Mattermost Service Account​
In "least privilege" environments you may need to further constrain the service account permissions to limit the access your Elasticsearch or AWS OpenSearch service account has.
The following JSON provides an example of a "least privilege" permission set that allows Mattermost to operate correctly with Elasticsearch or AWS OpenSearch:
"cluster_permissions": [
"cluster:monitor/*",
"indices:admin/template/put",
"indices:data/write/bulk"
"index_permissions": [
"index_patterns": [
"\<IndexPrefix\>*"
"allowed_actions": [
"indices:admin/get",
"indices:admin/create",
"indices:admin/delete",
"indices:admin/mapping/put",
"indices:admin/mappings/fields/get*",
"indices:data/read*",
"indices:data/write*"
&#125;
&#125;
A simpler, more flexible, and resilient variant of the above would be:
"index_patterns": [
"\<IndexPrefix\>*"
"indices:*"
