Unlisted page
This page is unlisted. Search engines will not index it, and only users having a direct link can access it.
  1. (Optional) Enter Server Username used to access the enterprise search server.
  2. (Optional) Enter Server Password associated with the username.
  3. Set Enable Cluster Sniffing (Optional). Sniffing finds and connects to all data nodes in your cluster automatically.
  1. Optional CA and client certificate configuration settings are available for use with basic authentication credentials or to replace them. See the Enterprise search configuration settings documentation for details.
  2. Select Test Connection and then select Save. If the server connection is unsuccessful you won't be able to save the configuration or enable searching with Elasticsearch or AWS OpenSearch.
Build the post index of existing messages
Select Index Now. This process can take up to a few hours depending on the size of the post database and number of messages. The progress percentage can be seen as the index is created. To avoid downtime, set Enable Elasticsearch for search queries to false so that database search is available during the indexing process.
Enable enterprise search
Ensure bulk indexing is complete before enabling enterprise search, otherwise search results will be incomplete.
Set Enable Elasticsearch for search queries to true, and setting Enable Elasticsearch for autocomplete to true. Save your configuration updates and restart the Mattermost server.
Once the configuration is saved, new posts made to the database are automatically indexed on the Elasticsearch or AWS OpenSearch server.
Enterprise search limitations​
  1. Elasticsearch and AWS OpenSearch use a standard selection of "stop words" to keep search results relevant. Results for the following words will not be returned: "a", "an", "and", "are", "as", "at", "be", "but", "by", "for", "if", "in", "into", "is", "it", "no", "not", "of", "on", "or", "such", "that", "the", "their", "then", "there", "these", "they", "this", "to", "was", "will", and "with".
  2. Searching stop words in quotes returns more results than just the searched terms (ticket).
  3. By default, search results are limited to a user's team and channel membership. This is enforced by the Mattermost server. The entities are indexed in Elasticsearch or AWS OpenSearch in a way that allows Mattermost to filter them when querying, so the Mattermost server narrows down the results on every Elasticsearch or AWS OpenSearch request applying those filters. From Mattermost v11.6, admins can allow searching public channels without membership so that users can find messages in public channels they haven't joined, scoped to teams they belong to.
  4. User search and autocomplete served by Elasticsearch or AWS OpenSearch match on username, nickname, and first and last name only. Email addresses aren't indexed, so no user can be found by email address, including system admins. User searches served from the database continue to match on email address. For channel and team member searches, system admins always match on email address, and all other users also require Show email address to be enabled. The System Console > User Management > Users list always matches on email address, independently of that setting.
