Mobile apps FAQ
Can I connect to multiple Mattermost servers using the mobile apps?
Yes, using Mattermost mobile app v2.0. Mobile v1.x only supports connecting to one server at a time.
What data is stored?
The data that can be found on the device depends solely on whether or not the user is logged in to the Mattermost server, and is independent of the state of the device's connection or the state of the app. While logged in, anything that the user is normally allowed to see is eligible for storage on the device, which includes the following content:
- Messages
- Files and images that are attached to messages
- Profile pictures, usernames, and email addresses of people in the currently open channel
In addition, metadata that the app uses for keeping track of its operations is also cached. The metadata includes user IDs, channel IDs, team IDs, and message IDs.
Currently, cache cannot be reset remotely on connected mobile devices.
What about push notifications?
Push notification storage is managed by the operating system on the device. Mattermost can be configured to send limited amounts of information that does not include the message text or channel name, and it can also be configured to not send push notifications at all.
Where is the data stored and how is that data protected?
The data is stored in the app's local storage. It's protected by the security measures that a device normally provides to the apps that are installed on it.
How long is the data stored?
Data is stored until the user logs out, or until it is purged during normal cache management. Deactivating a user account forces a logout and subsequent purging of data from the device.
How is data handled after a user account is deactivated?
App data is wiped from the device when a user logs out of the app. If the user is logged in when the account is deactivated, then within one minute of deactivation the system logs the user out. Thereafter all app data is wiped from the device.
If file attachments are enabled on the server, users can download files that are attached to messages and store them on their local file system. After they are downloaded, the files are outside the control of the app and can remain on the device indefinitely.
Are messages pre-loaded?
No. Messages are sent to the device on demand. They are not pre-loaded in anticipation of users scrolling up or switching channels.
Do I need to compile the mobile apps to host my own push notification server?
Yes. To host your own push notification server, you'll need to compile the mobile apps. See documentation to learn how to compile your own mobile apps.
How do push notifications work?
Your Mattermost server sends push notifications to a hosted push proxy server, which relays them via mobile push notification services provided by Apple and Google.
To ensure push notifications are coming from a trusted source, Apple and Google only allow push notifications sent from a service using a key or signature corresponding to a secret compiled into the mobile app itself.
The full process is outlined below:
- An action triggering a push notification is detected in the Mattermost server running in your private network.
- Your Mattermost server sends a push notification message to a Mattermost Push Notification Service (MPNS), either self-hosted in your private network, or publicly hosted by Mattermost, Inc.
- MPNS sends a push notification message to either Apple Push Notification Service (APNS) or to Google’s Firebase Cloud Messaging (FCM) service over a TLS connection.
- If sent to Apple, the message has a signature corresponding to a secret compiled in the iOS app.
- If sent to Google, the message uses a key corresponding to a secret compiled in the Android app.
Regardless of whether you're using iOS or Android, the MPNS needs to have access to the appropriate secret compiled into the mobile app.
This means if you use the Mattermost apps from the Apple App Store or Google Play Store, you need to use the hosted push notification service from Mattermost, Inc. If you compile the apps yourself, you must also compile and use your own MPNS with the corresponding secret.
- Either APNS or FCM receives the push notification message from MPNS over TLS, and then relays the message to the user's iOS or Android device to be displayed.
Is TLS v1.3 supported?
Yes. Mattermost mobile app v2.0 supports both TLS v1.2 and TLS v1.3 for websocket connections.
What post metadata is sent in mobile push notifications?
The following post metadata is sent in all push notifications:
Team IDChannel IDPost IDUser ID(post author)Username(post author or webhook override username)Root ID(only if the post is in a thread)Type(create or clear push notification)Category(iOS only, determines if the notifications can be replied to)Badge number(what the notification badge on the app icon should be set to when the notification is received)
Additional metadata may be sent depending on the System Console setting for Push Notification Contents:
- Generic description with sender and channel names:
Channel namemetadata will be included. - Full message content sent in the notification payload:
Post contentandChannel namemetadata will be included. - Full message content fetched from the server on receipt (available in Mattermost Enterprise):
Post contentandChannel nameare not included in the notification payload, instead thePost IDis used to fetchPost contentandChannel namefrom the server after the push notification is received on the device.
How can I use ID-Only Push Notifications to protect notification content from being exposed to third-party services?
When it comes to mobile data privacy, many organizations prioritize secure handling of messaging data, particularly when it may contain mission-critical or proprietary information. These organizations may have concerns about using mobile notifications because data must pass through third-party entities like Apple Push Notification Service (APNS) or Google Firebase Cloud Messaging (FCM) before it reaches a device.
This poses a potential risk for organizations that operate under strict compliance requirements and cannot expose message data to external entities. To solve this, we offer an option for greater protection for Mattermost push notification message data by only sending a unique message ID in the notification payload rather than the full message data (available in Mattermost Enterprise). Once the device receives the ID, it then fetches the message content directly from the server and displays the notification per usual.
External entities, such as APNS and FCM, handle only the ID and are unable to read any part of the message itself. If your organization has strict privacy or compliance needs, the ID-Only Push Notification setting offers a high level of privacy while still allowing your team members to benefit from mobile push notifications.
The following payload shows an example of the json that is transmitted to the push notification service when using the ID-Only setting:
123;"ack_id": "nnfbqk5bnffe5karxuzs8o5rec","platform": "apple_rn","server_id": "aoej8izzfffr9e67d6uz3g387h","device_id": "32f198dbdd7427be7e6f03ba721ffdceba58c3f0bfa9c4655a6e7cc8271ba539","post_id": "77d9cs9aq3b1fpoepbdbmqfs4c","category": "CAN_REPLY","message": "You've received a new message.","badge": 3,"channel_id": "et3ghiycm7g7bb41ihg85pqgah","type": "message","sender_id": "g774dzud4tgaxgphso4wm8xrxe","version": "v2","is_id_loaded": true125;
where the following definitions are applied:
ack_id: An ephemeral identifier generated per notification that determines whether the notification sent was received by the device (using same method that generates identifiers to the rest of the models in the server). This information is available in thenotifications.logfile on the Mattermost server. Theack_idis only used for receipt delivery from the mobile app to the Mattermost server to confirm whether the notification sent was received.server_id: A server identifier created on the server, calledDiagnosticId. In the future, this value will be used in the mobile app (for multi-server support) to identify which server the notification belongs to.device_id: The token that APNs and FCM return when you allow the device to receive notifications. So when the user logs into Mattermost, Mattermost sends thisdevice_idto attach it to the session. If the session is terminated, thedevice_idis no longer present in the server database because the session record is removed. When the user logs back in, thedevice_idis registered again with the same value because the identifier is specific to the device. This value won't be the same across apps or devices owned by the same person, but will be the same for each session the user creates from the same app on the same device.version: Tells the mobile app how data is structured so it can parse it properly. Current value isv2.is_id_loaded: (Mattermost Enterprise only) When true, the mobile app look for the contents of the notification on the server because those details are not part of the payload.
What are my options for securing the mobile apps?
The following options for secure mobile app deployments are available:
- Securing network connection to mobile apps
- Use HTTPS and WSS network connections to encrypt transport.
- Use of a mobile VPN client on mobile devices to establish secure connection to Mattermost server within private network.
- Use multifactor authentication options
- If a VPN client with multifactor authentication is not in use, it's highly recommended that MFA is required on authenticating into Mattermost, either within Mattermost itself or via your SSO provider.
What are my options for securing push notifications?
The following options are available for securing your push notification service:
- Protecting notification contents
- You can choose what type of information to include in push notifications, such as excluding the message contents if your compliance policies require it. Default server settings have message contents turned off.
- Disabling push notifications
- Push notifications can also be disabled entirely depending on security requirements. Default server settings have push notifications disabled.
- Encrypting connections for apps you compile yourself:
- When using a privately-hosted Mattermost Push Notification Service (MPNS), use encrypted TLS connections between:
- MNPS and Apple Push Notification Service (APNS)
- MPNS and Google’s Firebase Cloud Messaging (FCM)
- MPNS and your Mattermost server
- Securing apps installed through the Apple App Store and Google Play:
- When using Mattermost mobile apps from the App Store and Google Play, purchase an annual subscription to Mattermost Enterprise or Professional to use Mattermost's Hosted Push Notification Service (HPNS).
Why do I sometimes see a delay in receiving a push notification?
Apple Push Notification Service (APNS) and Google Fire Cloud Messaging (FCM) determine when your device receives a push notification from Mattermost. Thus, a delay is usually as a result of those services.
The technical flow for the device to receive a push notification is as follows:
- User posts a message in Mattermost.
- Mattermost server identifies if notifications need to be sent.
- If yes, Mattermost server sends a payload containing the push notification to the push proxy.
- The push proxy parses the notification and relays it to APNS and FCM.
- APNS and FCM informs the relevant devices that there is a push notification for Mattermost. This usually happens almost immediately, but may be delayed by a couple of minutes.
- Mattermost processes the notification and displays it on the user's device.
How do I deploy Mattermost with Enterprise Mobility Management (EMM) providers?
Mattermost enables customers with high privacy and custom security requirements to deploy mobile app and push notification services using keys that they alone control.
Learn more about using AppConfig for EMM providers.
How do I host the Mattermost push notification service?
First, you can use the Mattermost Hosted Push Notification Service (HPNS). Organizations can also host their own push proxy server instead. This is applicable when you want to:
- Customize the Mattermost mobile apps;
- Deploy your own push notification service, or
- Repackage the mobile apps with BlueCedar or AppDome (both of which are not officially supported but have been successfully deployed by some organizations).
How do I white label the app and customize build settings?
All files in the /assets/base folder can be overridden as needed without conflicting with changes made to the upstream version of the app. To do this:
- Create the folder
/assets/override. - Copy any files or folders that you wish to replace from
/assets/baseinto/assets/override. - Make your changes to the files in
/assets/override.
When you compile the app or run make dist/assets, the contents of those two folders will be merged with files in /assets/override, taking precedence in the case of any conflicts. For binary files such as images, an overridden file will completely replace the base version, while JSON files will be merged so that fields not set in the overridden copy use the base version.
For a more specific example of how to use this feature, see the following section.
How do I preconfigure the server URL for my users?
You can preconfigure the server URL and other settings by overriding default config.json settings and building the mobile apps yourself.
- Fork the mattermost-mobile repository.
- Create the file
/assets/override/config.jsonin your forked mattermost-mobile repository. - Copy and paste all the settings from
assets/base/config.jsonto the newly-created/assets/override/config.jsonfile that you want to override. - To override the server URL, set
DefaultServerURLto the server URL of your Mattermost server in/assets/override/config.json. - (Optional) If you want to prevent users from changing the server URL, set
AutoSelectServerUrltotrue. - (Optional) Override any other settings you like.
After the above, your /assets/override/config.json file would look something like this:
123;"DefaultServerURL": "my-mattermost-instance.example.com","AutoSelectServerUrl": true,"ExperimentalUsernamePressIsMention": true125;
- Finally, compile your own version of the Mattermost mobile app and Mattermost push proxy server.
How can I get Google SSO to work with the Mattermost mobile app?
The apps on the Apple App Store and Google Play Store cannot support Google SSO out of the box. This is because Google requires a unique Google API key that's specific to each organization.
If you need Google SSO support, you can create a custom version of the app for your own organization. Fork the mattermost-mobile repository and add support for Google SSO before compiling the app yourself. If this is something you’re interested in, please file an issue in GitHub to start the discussion.
How do I configure deep linking?
The app checks for platform-specific configuration on app install. If no configuration is found, then the deep linking code sits silently and permalinks act as regular links.
Set up for iOS
- Create an
apple-app-site-associationfile in the.well-knowndirectory at the root of your server. It should be accessible by navigating tohttps://<your-site-name>/.well-known/apple-app-site-association. There should not be a file extension. - In order to handle deep links, paste the following
JSONinto theapple-app-site-associationfile. Make sure to place your app ID in theappIDproperty:
{ "applinks": { "apps": [], "details": [ { "appID": "<your-app-id-here>", "paths": ["/pl/*", "/channels/*"] } ] } }
- Add the associated domains entitlement to your app via the Apple developer portal.
- Add an entitlement that specifies the domains your app supports via the Xcode entitlements manager.
- Before installing the app with the new entitlement, make sure that you can view the contents of the
apple-app-site-associationfile via a browser by navigating tohttps://<your-site-name>/.well-known/apple-app-site-association. The app will check for this file on install and, if found, will allow outside permalinks to open the app.
Official documentation for configuring deep linking on iOS can be found here.
Set up for Android
Please refer to the the App Links Assistant in Android Studio for configuring deep linking on Android.
How do I connect users across internal and external networks?
By setting up global network traffic management, you can send a user to an internal or external network when connecting with a mobile app. Moreover, you can have two separate layers of restrictions on internal and external traffic, such as:
- In the internal network, deploy on a private network via per device VPN.
- For web and desktop access from the external network, you can validate client certificates using mutual TLS with an NGINX proxy. SSL client certificates are not supported by the Mattermost mobile apps.
Many services such as Microsoft Azure provide options for managing network traffic, or you can engage a services partner to assist.
How do I receive mobile push notifications if my IT policy requires the use of a corporate proxy server?
When your IT policy requires a corporate proxy to scan and audit all outbound traffic the following options are available:
Deploy Mattermost in a proxy-aware configuration with a pre-proxy relay
The Mattermost push notification service is designed to send traffic directly to the Apple Push Notification Service (APNS) and Google Fire Cloud Messaging (FCM) services.
In a proxy-aware configuration, a pre-proxy relay accepts messages from the Mattermost Push Proxy and forwards them to a corporate proxy enforcing your internal IT requirements, before transmitting to their final destination.
See a sample architectural overview below:
This enables the pre-proxy relay to act as the APNS and to forward the request to its final destination via your corporate proxy, not requiring the APNS traffic to be proxy-aware. The APNS traffic is redirected to the pre-proxy relay via /etc/hosts entry. The entry uses a trusted CA that signs a certificate for the Mattermost Push Proxy to trust the pre-proxy relay. See the Apple Developer documentation on user notifications for more information.
Google's FCM traffic is proxy-aware via environment variables, so no actions are required for it.
Moreover, APNS traffic requires HTTP/2, so your corporate proxy server must support HTTP/2 requests in order to send the push notifications to Apple devices. HTTP/2 support for the pre-proxy relay is also required.
Deploy Mattermost with connection restricted post-proxy relay in DMZ or a trusted cloud environment
Some legacy corporate proxy configurations may be incompatible with the requirements of modern mobile architectures, such as the requirement of HTTP/2 requests from Apple to send push notifications to iOS devices.
In this case, a post-proxy relay can be deployed to take messages from the Mattermost server passing through your corporate IT proxy in the incompatible format, e.g. HTTP/1.1, transform it to HTTP/2 and relay it to its final destination, either to the Apple Push Notification Service (APNS) and Google Fire Cloud Messaging (FCM) services.
This post-proxy relay can be configured using the Mattermost Push Proxy installation guide with connection restrictions to meet your custom security and compliance requirements.
In place of a DMZ, you can also host in a trusted cloud environment such as AWS or Azure depending on your internal approvals and policies.
Whitelist Mattermost push notification proxy to bypass your corporate proxy server
Depending on your internal IT policy and approved waivers/exceptions, you may choose to deploy the Mattermost Push Proxy to connect directly to Apple Push Notification Service (APNS) without your corporate proxy.
You will need to whitelist one subdomain and one port from Apple for this option:
- Development server:
api.development.push.apple.com:443 - Production server:
api.push.apple.com:443
Run App Store versions of the Mattermost mobile apps
You can use the mobile applications hosted by Mattermost in the Apple App Store or Google Play Store and connect with the Mattermost Hosted Push Notification Service (HPNS) through your corporate proxy.
How the deviceId behaves
The deviceId is a identifier provided by a push notification service, such as Apple Push Notification service (APNs) and Firebase Cloud Messaging (FCM), that identifies the relationship between device, app, and the notification service.
When the app starts, if the push notification permissions are enabled, the app will try to connect with the corresponding notification service (APNs for iOS, FCM for Android) to get the deviceId. If there is any change to the deviceId, the app will notify any connected server about this change.
Based on the Apple Developer Documentation on registering apps with APNS and the Google Documentation on FCM, the deviceId only will change in the following cases:
- The app is restored from a backup from a different device
- The user clears the app data
- The user reinstalled the app
- The user installed the app on a different device
If the device has a deviceId, when the user logs into a Mattermost server, an audit log entry login will store the deviceId, and the deviceId will also be added in the session data in the database. However, it's possible the deviceId isn't available, due to several reasons including:
- The device is not connected to the network
- The notification service is not reachable for any reason
- The app is not properly signed
- The device has not been granted the needed permissions
In these scenarios, the login audit log won't have the deviceId, and the session data won't have the deviceId. If the app receives the deviceId later, the device will send the new deviceId to the server, generating an attachDeviceId audit log, and adding the deviceId to the session data in the database.
Since the deviceId relates to the application, connections through the web browser, even on mobile, won't have a deviceID.
Where can I find mobile message notification logs?
Notification messages are logged to the notifications.log file. System admins must enable notification logs in the config.json file by setting EnableFile to true, and specifying an optional file location via FileLocation. When no location is configured, the notifications.log file is stored in the default Mattermost directory. See the logging configuration settings documentation for details.
The team members / users can access their notification logs based on their device platform. Android users can view the logs using logcat. iOS users can acess the logs in the console app on their MacOS.
How do I gather mobile app logs?
See the Mattermost Support Knowledge Base article on gathering mobile app logs for details.
