Active/passive DR deployment on AWS
Before you begin, ensure the following are in place:
- AWS account access with IAM permissions to manage RDS, S3, and OpenSearch resources in both regions
- A chosen primary and secondary AWS region pair for failover
- An existing, healthy Mattermost primary deployment
- DNS control over the domain used to reach Mattermost, so you can redirect traffic during failover
- Required RDS Aurora PostgreSQL global cluster permissions and a verified, restorable database backup
- OpenSearch 2.x with fine-grained access control available in both regions
- Network connectivity between the primary and secondary regions confirmed
Enterprise customers who use Mattermost for mission-critical operations must ensure continuous availability and operational resilience. A robust disaster recovery strategy is essential to mitigate risks associated with data center failures, ensuring that users can access Mattermost seamlessly, even in the event of unexpected outages.
This page details the steps needed to set up Mattermost in an active/passive disaster recovery configuration on AWS, and how to fail over from one data center to another.
Set up in one data center
As a first step, set up Mattermost in a single data center. The following diagram illustrates a basic single data center architecture:
The diagram above has a single proxy, forwarding traffic to 2 nodes. There's also a database with single writer + n readers and an S3 bucket and ES/OS using AWS OpenSearch service.
At this stage, we are ignoring other details like LDAP/SAML, SMTP etc.
Replicate database
The next tasks include creating a global AWS Cluster.
- Select the RDS instance in the AWS Console, and expand the Actions menu to select Add AWS Region.
- Choose the secondary region and enter the other details.
You should now have a global cluster with the primary cluster in us-west-1, and the secondary cluster in us-east-1:
Replicate S3 bucket
- Create a new S3 bucket in the secondary region.
- Back in the original bucket, go to the Properties tab, and enable Bucket versioning.
- Go to the Management tab, scroll down to Replication Rules, and create a new replication rule.
- In the rule, select the source bucket, and then choose Apply to all objects in the bucket to replicate everything in the bucket.
- Choose the destination bucket.
- For the IAM role, select Create new role.
- Select Save.
- Select Yes when prompted to start a job to replicate any existing objects to the secondary bucket or not.
- Perform these same steps on the secondary bucket.
Now you have bi-directional replication working between these S3 replica and source buckets.
Replicate ES/OS storage
- To replicate ES/OS storage, set up CCR (cross-cluster replication) for AWS OpenSearch with the following requirements:
- Elasticsearch 7.10 or OpenSearch 2.x
- Fine-grained access control enabled
- Node-to-node encryption enabled
- You also need to add the
CrossClusterGetpermission on the IAM policy for the OS cluster set under the Security Configuration tab for your OS domain. We recommend the following as per AWS, but feel free to fine-tune as necessary:
123;"Version": "2012-10-17","Statement": [123;"Effect": "Allow","Principal": 123;"AWS": "*"125;,"Action": "es:ESHttp*","Resource": "arn:aws:es:<region>:<acc_num>:domain/<domain_name>/*"125;,123;"Effect": "Allow","Principal": 123;"AWS": "*"125;,"Action": "es:ESCrossClusterGet","Resource": "arn:aws:es:<region>:<acc_num>:domain/<domain_name>"125;]125;
To recap:
- Use OpenSearch 2.x.
- Enable fine-grained access control.
- Create the master user, and note the server credentials.
- Set the IAM policy as above.
- Create a new OS cluster in the secondary region. Follow the same steps again for this cluster.
Warning
At this stage, ensure that you have all indices populated with data in the primary region. Run a bulk index to do that if you haven't already.
- Begin replication from the primary to secondary region.
- First, create a connection from secondary to primary. Note that replication in OS works in a "pull" model, so the secondary site pulls data from the primary.
- In the Amazon OpenSearch Service console, select the secondary domain, go to the Connections tab, and choose Request.
- For Connection alias, enter a name for your connection.
- Choose connect to a domain in another AWS account or region, and enter the ARN of the primary domain.
- Select Request to send a permission request to the primary domain.
- Open the primary domain to see and accept the incoming request under the Connections tab.
- Now set up the replication rules for indices.
SSH into an app node in the secondary region to set up an auto-follow rule for the
posts*indices because of the daily naming scheme and monthly aggregation.For the other indices, replicate each of them. You can also set up a rule with
*to replicate everything, but that would also include the hidden and system indices which you don't want.Set up the auto-follow for
posts*indices:curl -XPOST -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/_autofollow?pretty' -d '{"leader_alias" : "<LEADER_ALIAS>","name": "autofollow-rule","pattern": "posts*","use_roles":{"leader_cluster_role": "all_access","follower_cluster_role": "all_access"}}'
Check the status of the auto-follow rule:
curl -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/autofollow_stats?pretty'{"num_success_start_replication" : 2,"num_failed_start_replication" : 0,"num_failed_leader_calls" : 0,"failed_indices" : [ ],"autofollow_stats" : [{"name" : "autofollow-rule","pattern" : "posts*","num_success_start_replication" : 2,"num_failed_start_replication" : 0,"num_failed_leader_calls" : 0,"failed_indices" : [ ],"last_execution_time" : 1737699113927}]}
Next, set up replication for the other indices:
curl -XPUT -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/channels/_start?pretty' -d '{"leader_alias": "<LEADER_ALIAS>","leader_index": "channels","use_roles":{"leader_cluster_role": "all_access","follower_cluster_role": "all_access"}}'curl -XPUT -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/users/_start?pretty' -d '{"leader_alias": "<LEADER_ALIAS>","leader_index": "users","use_roles":{"leader_cluster_role": "all_access","follower_cluster_role": "all_access"}}'curl -XPUT -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/files/_start?pretty' -d '{"leader_alias": "<LEADER_ALIAS>","leader_index": "files","use_roles":{"leader_cluster_role": "all_access","follower_cluster_role": "all_access"}}'
Check the status of the replication rules:
curl -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/channels/_status?pretty'curl -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/files/_status?pretty'curl -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/users/_status?pretty'curl -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/posts_<DATE>/_status?pretty'Sample output:{"status" : "SYNCING","reason" : "User initiated","leader_alias" : "<LEADER_ALIAS>","leader_index" : "<INDEX>","follower_index" : "<INDEX>","syncing_details" : {"leader_checkpoint" : 16,"follower_checkpoint" : 16,"seq_no" : 17}}
Check for indices. You should be able to see all the indices from the primary domain in the secondary domain:
curl -s -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_cat/indices?pretty'
Replicate job servers
If the job scheduler is left running in the secondary region, it will pick up jobs and start running them. Follow these steps to manage it correctly. See the RunScheduler configuration setting documentation for details.
- Precondition: Set
JobSettings.RunSchedulertofalseon all nodes in the secondary region before enabling that region. - On failover: Set
JobSettings.RunSchedulertotrueon all nodes in the new primary region. - Immediately after: Set
JobSettings.RunSchedulertofalseon all nodes in the new secondary region. - Verify: Confirm that jobs execute only in the active region. Submit a test job (for example, trigger an index rebuild) and check the job logs to ensure it runs on the new primary, not the secondary.
Test the secondary region
With the above steps complete, you have a fully functioning secondary region. You can replicate the same setup of nodes and a proxy server like the primary region. The app nodes in the secondary region won't be able to come up the first time because Mattermost will try to run some DDL statements which are not allowed with write-forwarding. So it will be stuck in a loop trying to connect. Once you fail over the region, it will start working. The primary region will still be readable, and any periodic writes will be forwarded to the secondary (now primary).
Failover RDS to secondary
To perform the failover, go to the RDS global cluster, and under Actions, select Switchover or Failover global database, and then select switchover to switch over without any data loss (which will take more time to complete). Alternatively, you can choose failover for a quicker failover at the expense of data-loss. If the entire region is unavailable anyways, then failover is no worse than switchover.
After this is done, the app nodes which were stuck trying to connect should move forward and everything should be functional. You can read/write, upload images and everything should be replicated. Everything except OpenSearch data.
Failover ES/OS to secondary
ES/OS does not allow multi-writer for a single index. You can only write to 1 index at one time. Therefore, you need to perform some manual steps to reverse the replication direction, and start replicating from secondary to primary.
For simplicity, let's say site1 is primary, and site2 is secondary. Therefore, OS in site1 is the leader domain, and in site2 is the follower. The follower pulls from the leader. To switch the direction where site2 becomes leader, and site1 becomes follower.
- Remove the rule from
site1>site2in AWS Console. This will auto-pause the replication, but the indices insite2will still be read-only. Remove the replication rules for that. - Remove auto-follow rule:
curl -XDELETE -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/_autofollow?pretty' -d '{"leader_alias" : "<LEADER_ALIAS>","name": "autofollow-rule"}'
- Check the status of the auto-follow rule as mentioned before.
- Remove replication rules:
curl -XPOST -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/channels/_stop?pretty' -d '{}'curl -XPOST -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/files/_stop?pretty' -d '{}'curl -XPOST -H 'Content-Type: application/json' -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_plugins/_replication/users/_stop?pretty' -d '{}'
- Check the status of replication rules as mentioned before.
- Now indices will become writable
- Add rule from
site2>site1in AWS console. - In
site1, make all the indices as followers. You must delete all indices first:
curl -XDELETE -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/posts*?pretty'curl -XDELETE -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/channels?pretty'curl -XDELETE -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/files?pretty'curl -XDELETE -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/users?pretty'
- Refresh indices:
curl -XPOST -u '<USERNAME>:<PASSWORD>' 'https://<HOSTNAME>/_refresh?pretty'
- Confirm that everything is deleted:
- Add the auto-follow rule add replication rules. Follow the same steps as before.
- List the indices again to confirm that replication has started and indices are available.
Testing end to end
Once the failover has happened, and the ES/OS replication direction has been swapped, the new site can be used normally.
This becomes the final architecture:
You can use DNS to easily switch between PRIMARY to SECONDARY during a failover.
The S3 bucket is replicated bi-directionally while the database and ES/OS is replicated uni-directionally.
Restore to primary data center
When the disaster event is resolved and you are ready to restore normal operations, perform the same failover steps in reverse to return traffic to the original primary data center:
- Perform an RDS switchover back to the original primary region using the Switchover or Failover global database option in the RDS console.
- Reverse the ES/OS replication direction by following the same steps in the Failover ES/OS to secondary section, swapping the roles of
site1andsite2. - Update DNS to redirect traffic back to the original primary data center.
- Re-enable
JobSettings.RunScheduleron the original primary nodes and disable it on the secondary nodes. - Roll over app nodes gradually to move websocket connections back to the primary data center.
