RTCD Setup and Configuration
This guide provides detailed instructions for setting up, configuring, and validating a Mattermost Calls deployment using the dedicated RTCD service.
Prerequisites​
Before deploying RTCD, ensure you have:
  • A Mattermost Enterprise license
  • A server or VM with sufficient CPU and network capacity (see the Performance baselines section for sizing guidance)
Network Requirements​
The following network connectivity is required:
ServicePortsProtocolsSourceTargetPurpose
API (Calls plugin)80,443TCP (incoming)Mattermost clients (web/desktop/mobile)Mattermost instance (Calls plugin)To allow for HTTP and WebSocket connectivity from clients to Calls plugin. This API is exposed on the same connection as Mattermost, so there's likely no need to change anything.
RTC (Calls plugin or rtcd)8443UDP (incoming)Mattermost clients (Web/Desktop/Mobile) and calls-offloaderMattermost instance or rtcd serviceTo allow clients to establish connections that transport calls related media (e.g. audio, video). This should be open on any network component (e.g. NAT, firewalls) in between the instance running the plugin (or rtcd) and the clients joining calls so that UDP traffic is correctly routed both ways (from/to clients).
RTC (Calls plugin or rtcd)8443TCP (incoming)Mattermost clients (Web/Desktop/Mobile) and calls-offloaderMattermost instance or rtcd serviceTo allow clients to establish connections that transport calls related media (e.g. audio, video). This should be open on any network component (e.g. NAT, firewalls) in between the instance running the plugin (or rtcd) and the clients joining calls so that TCP traffic is correctly routed both ways (from/to clients). This can be used as a backup channel in case clients are unable to connect using UDP. It requires rtcd version >= v0.11 and Calls version >= v0.17.
API (rtcd)8045TCP (incoming)Mattermost instance(s) (Calls plugin)rtcd serviceTo allow for HTTP/WebSocket connectivity from Calls plugin to rtcd service. Can be exposed internally as the service only needs to be reachable by the instance(s) running the Mattermost server.
STUN (Calls plugin or rtcd)3478UDP (outgoing)Mattermost Instance(s) (Calls plugin) or rtcd serviceConfigured STUN servers(Optional) To allow for either Calls plugin or rtcd service to discover their instance public IP. Only needed if configuring STUN/TURN servers. This requirement does not apply when manually setting an IP or hostname through the ICE Host Override config option.
Installation and Deployment​
There are multiple ways to deploy RTCD, depending on your environment. We recommend the following order based on production readiness and operational control:
This is the recommended deployment method for non-Kubernetes production environments, as it provides the best performance and operational control. For Kubernetes deployments, see the Calls Deployment on Kubernetes guide.
  1. Download and install the RTCD binary:
    Download the latest release from the RTCD GitHub repository:
    # Create the RTCD directory structure
    sudo mkdir -p /opt/rtcd
    # Download the latest RTCD binary (adjust URL for your architecture)
    # For Linux x86_64:
    wget https://github.com/mattermost/rtcd/releases/latest/download/rtcd-linux-amd64
    # Make the binary executable and move it to the installation directory
    chmod +x rtcd-linux-amd64
    sudo mv rtcd-linux-amd64 /opt/rtcd/rtcd
  2. Create a configuration file (/opt/rtcd/rtcd.toml):
    Mattermost recommends using the official config.sample.toml as a starting point. Download this file and use it as your base configuration.
  3. Create a dedicated user for the RTCD service:
    sudo useradd --system --no-create-home --shell /bin/false mattermost
  4. Create the data directory and set ownership:
    sudo mkdir -p /opt/rtcd/data/db
    sudo chown -R mattermost:mattermost /opt/rtcd
  5. Create a systemd service file (/etc/systemd/system/rtcd.service):
    [Unit]
    Description=Mattermost RTCD Server
    After=network.target
    [Service]
    Type=simple
    User=mattermost
    Group=mattermost
    ExecStart=/opt/rtcd/rtcd --config /opt/rtcd/rtcd.toml
    Restart=always
    RestartSec=10
    LimitNOFILE=65536
    [Install]
    WantedBy=multi-user.target
  6. Enable and start the service:
    sudo systemctl daemon-reload
    sudo systemctl enable rtcd
    sudo systemctl start rtcd
  7. Check the service status:
    sudo systemctl status rtcd
Docker Deployment​
Docker deployment is suitable for development, testing, or containerized production environments:
  1. Run the RTCD container with basic configuration:
    docker run -d --name rtcd \
    -e "RTCD_LOGGER_ENABLEFILE=true" \
    -p 8443:8443/udp \
    -p 8443:8443/tcp \
    -p 8045:8045/tcp \
    mattermost/rtcd:latest
  2. For debugging purposes, you can enable more detailed logging:
    -e "RTCD_LOGGER_CONSOLELEVEL=DEBUG" \
    -p 8443:8443/udp \
    -p 8443:8443/tcp \
    -p 8045:8045/tcp \
    To view the logs:
    docker logs -f rtcd
You can also use a mounted configuration file instead of environment variables:
-p 8045:8045 \
-p 8443:8443/udp \
-p 8443:8443/tcp \
-v /path/to/config.toml:/rtcd/config/config.toml \
For a complete sample configuration file, see the RTCD config.sample.toml in the official repository.
Kubernetes Deployment​
For detailed information on deploying RTCD in Kubernetes environments, including Helm chart configurations, resource requirements, and scaling considerations, see the Calls Deployment on Kubernetes guide.
Configuration​
RTCD Configuration File​
The RTCD service uses a TOML configuration file. Mattermost recommends using the official config.sample.toml as your base configuration file.
TURN Configuration​
For clients behind strict firewalls, you may need to configure TURN servers. In the RTCD configuration file, reference your TURN servers as follows:
[rtc]
# TURN server configuration
ice_servers = [
{ urls = ["turn:turn.example.com:3478"], username = "turnuser", credential = "turnpassword" }
We recommend using coturn for your TURN server implementation.
System Tuning​
For high-volume deployments, tune your Linux system:
  1. Add the following to /etc/sysctl.conf:
    # Increase UDP buffer sizes
    net.core.rmem_max = 16777216
    net.core.wmem_max = 16777216
    net.core.optmem_max = 16777216
  2. Apply the settings:
    sudo sysctl -p
Validation and Testing​
After deploying RTCD, validate the installation:
  1. Check service status and version:
    curl http://YOUR_RTCD_SERVER:8045/version
    # Should return a JSON object with service information
    # Example: {"build_hash":"abc123","build_date":"2023-01-15T12:00:00Z","build_version":"0.11.0","goVersion":"go1.20.4"}
  2. Test UDP connectivity:
    Before testing, ensure the RTCD service is stopped, as it binds to the same port.
    sudo systemctl stop rtcd
    On the RTCD server:
    sudo ncat -u -l -k -p 8443 -c '/bin/cat'
    On a client machine:
sudo nmap -sU -p 8443 RTCD_SERVER_IP
If UDP connectivity is working, `nmap` reports as `open`.
Restart RTCD after the test:
```bash
  1. Test TCP connectivity (if enabled):
    Run this check from a client machine:
    nmap -p 8443 RTCD_SERVER_IP
    If TCP fallback is enabled and reachable, nmap reports as open.
  2. Monitor metrics:
    Refer to Calls Metrics and Monitoring for setting up Calls metrics and monitoring.
Horizontal Scaling​
To scale RTCD horizontally:
  1. Deploy multiple RTCD instances:
    Deploy multiple RTCD servers, each with their own unique IP address.
  2. Configure DNS record:
    Set up a DNS record that points to multiple RTCD IP addresses:
    rtcd.example.com. IN A 10.0.0.1
    rtcd.example.com. IN A 10.0.0.2
    rtcd.example.com. IN A 10.0.0.3
  3. Configure health checks:
    Set up health checks to automatically remove unhealthy RTCD instances from DNS.
  4. Configure Mattermost:
    In the Mattermost System Console, set the RTCD Service URL to your DNS name (e.g., rtcd.example.com).
When a call starts, the Mattermost server examines the available RTCD servers (via the configured DNS record) and starts the call on the RTCD server with the lowest CPU usage. All participants in the call will connect to that RTCD server; a single call cannot be shared across multiple servers.
Upgrading RTCD​
RTCD is released and upgraded independently of the Mattermost server. An upgrade consists of replacing the binary or container image and restarting the service. There's no database or schema migration involved. The two things to plan for are preserving the data store and timing the restart so that calls in progress aren't dropped.
Releases are published to the RTCD GitHub repository as rtcd-linux-amd64 and rtcd-linux-arm64 binaries, and to Docker Hub as the mattermost/rtcd image.
Preserve the Data Store​
RTCD keeps a small local store at the path set by data_source in the [store] section of the configuration file, which defaults to /tmp/rtcd_db. It holds the client IDs registered by Mattermost servers along with a bcrypt hash of each client's authentication key. This is the only state RTCD persists, and it has to survive the upgrade:
  • Bare metal or VM. The store lives outside the binary, so replacing the binary in place preserves it. Verify that data_source doesn't point at a location cleared on reboot: the default /tmp/rtcd_db is on a temporary filesystem on many distributions.
  • Docker. The store is inside the container filesystem unless it's mounted, so recreating the container discards it. Mount a volume over the data_source path to keep it across image replacements.
Back the store up by copying its directory while the service is stopped.
Version Compatibility​
The Calls plugin enforces a minimum RTCD version and won't use a server running an older one.
For this reason, upgrade RTCD before upgrading the Mattermost server to a release shipping a newer version of Calls. When the plugin finds a server below the minimum version:
  • On plugin activation, such as after a Mattermost server restart or upgrade, the failed version check prevents the Calls plugin from starting at all. This happens if any of the servers resolved by the RTCD Service URL fails the check, not only if all of them do.
  • On a server discovered through DNS while the plugin is already running, the failure is logged as an error and the server isn't used. Calls continue to be routed to the remaining servers.
This means an RTCD server below the minimum version that's left in the DNS record can prevent Calls from starting the next time the Mattermost server restarts, even if calls are working at the time.
See Important Upgrade Notes for version-specific requirements. To check the version a server is running, query it directly with curl http://YOUR_RTCD_SERVER:8045/version.
How RTCD Shuts Down​
When RTCD receives a SIGTERM or SIGINT signal, it drains instead of exiting immediately: it waits for all active call sessions to end before shutting down. Calls in progress are never force-closed, and there's no drain timeout, so the process waits for as long as the last call lasts.
Two things follow from this behavior:
  • The HTTP and WebSocket API listeners stay open while the service drains, so a draining server can still be assigned new calls. Remove the server from the DNS record before signalling the process; otherwise the plugin can keep sending new calls to it, and the drain may never complete.
  • Any process supervisor that force-kills the service after a timeout cuts off the calls still running on it, and the default timeouts are generally shorter than a call.
systemctl stop rtcd sends SIGTERM to the service, and with the default KillMode=control-group, to every process in the unit's control group. systemd then waits for TimeoutStopSec before escalating to SIGKILL. When that value isn't set explicitly it inherits DefaultTimeoutStopSec, which gives a 90-second timeout on a stock systemd installation, so calls still running when the timeout expires are dropped.
The rolling upgrade below avoids this entirely by draining a server through DNS before stopping it, so the server is already idle by the time the service is stopped and the timeout never comes into play.
Upgrading a Single Server​
With a single RTCD server, an upgrade interrupts the service: no new calls can be started while the process is down, and because the service drains on shutdown, the restart doesn't complete until the existing calls end. There are two options:
  • Wait for the drain to complete. Send SIGTERM and let the service exit after the last call ends. No call is dropped, but the length of the outage depends on how long those calls run, and new calls fail in the meantime. Note that the drain only runs to completion if the process supervisor allows it: with systemd's 90 second default stop timeout, a longer drain is cut short and the remaining calls are dropped.
  • Stop the service at a set time. Notify participants, then force the process down with SIGKILL after a fixed period. Any calls still running are dropped and clients see those calls end.
Scheduling the upgrade for a period of low usage keeps either option short. See Communicate scheduled maintenance for templates to notify your users.
Rolling Upgrade with Multiple Servers​
When horizontal scaling is configured, servers can be upgraded one at a time without dropping calls. For each server in turn:
  1. Remove the server from DNS:
    Remove its IP address from the DNS record that the RTCD Service URL resolves to.
  2. Wait for the plugin to pick up the change:
    The plugin re-resolves the hostname every 10 seconds and flags servers that are no longer advertised. A flagged server is excluded from new calls, while the calls already running on it continue uninterrupted.
  3. Wait for the server to go idle:
    The rtcd_rtc_sessions_total metric reports the number of active RTC sessions per call group (see RTCD Metrics). The server can be restarted safely once the sum across all groups reaches zero.
  4. Stop the service:
    Because the server is already idle at this point, it exits immediately and the stop timeout doesn't come into play.
  5. Install the new version:
    Replace the binary or container image with the new version and start the service again.
  6. Verify the upgrade:
  7. Return the server to DNS:
    Add its IP address back to the DNS record. The plugin picks the server up on its next resolution cycle and starts assigning new calls to it again.
Once the server is back in rotation, repeat the process for the next one.
Upgrading in Kubernetes​
The RTCD Helm chart defaults to a RollingUpdate strategy with maxUnavailable: 1, and sets configuration.terminationGracePeriod to 18000 seconds (5 hours). That value maps to the pod's terminationGracePeriodSeconds, so Kubernetes allows a pod 5 hours to drain its calls before killing it.
Before changing the image, decide how the data store is handled. The chart ships no PersistentVolumeClaim template, and the store defaults to a path inside the container, so each replaced pod starts with an empty store. Since the store is a local embedded database with one instance per pod, a single volume can't be shared across replicas. There are two workable approaches:
  • Let pods re-register. Enable allow_self_registration on a private, access-controlled network, as described in the warning above, and the plugin re-registers against each new pod automatically. This is the simpler option and needs no storage configuration.
  • Give each pod its own storage. With deploymentType: daemonset, one pod runs per node, so a per-node hostPath mounted at the data_source path through configuration.extraVolumes and configuration.extraVolumeMounts gives each pod a store that survives image replacement.
To upgrade, set image.tag to the new version in your values file and apply the chart. Kubernetes sends SIGTERM to each pod it replaces, which starts the drain described above.
The chart doesn't set maxSurge, so a Deployment rollout uses the Kubernetes default and new pods can be created before the draining ones have exited. Expect old and new pods to run side by side for as long as the drains take, and size the node pool accordingly. maxUnavailable: 1 bounds how many pods can be unavailable at once; it doesn't serialize the replacements.
Integration with Mattermost​
Once RTCD is properly set up and validated, configure Mattermost to use it:
  1. Go to System Console > Plugins > Calls
  2. Set the RTCD Service URL to your RTCD service address (either a single server or DNS load-balanced hostname). Ensure you provide any generated credentials formulated in the URI (e.g., http://clientID:authKey@rtcd.local).
  3. Save the configuration
  4. Test by creating a new call in any Mattermost channel
  5. Verify that the call is being routed through RTCD by checking the RTCD logs and metrics
Other Calls Documentation​
For detailed Mattermost Calls configuration options, see the Calls Plugin Configuration Settings documentation.
