Mattermost Calls Deployment Guide
This guide walks System Administrators step-by-step through deploying Mattermost Calls, from preparation and network readiness through to pilot testing and production rollout. You'll find clear decision points, verification checks, and troubleshooting tips to help you confirm each phase of the deployment is working before you move on.
No prior experience with Mattermost Calls is required - this guide assumes you're starting fresh and will introduce essential concepts and best practices.
Calls Overview​
Mattermost Calls offers self-hosted audio calling and screen sharing, enabling sovereign real-time collaboration fully contained within your infrastructure. This means no call media or metadata traverses third-party systems.
Calls is uniquely suited for mission-critical operations across defense, intelligence, security and critical infrastructure - where data sovereignty, control, and compliance are non-negotiable. It is designed to function in isolated networks without internet access, supporting deployments that demand full airgap compliance.
Functionality includes:
  • 1:1 and Group Calling: Initiate real-time voice communication between two or more participants.
  • Screen Sharing: Share your screen during calls to collaborate visually on tasks, review documents, or troubleshoot live issues.
  • Call Recording and Transcription: Record voice sessions for asynchronous review. (Enterprise, Enterprise Advanced)
  • Live Captioning: Generate real-time subtitles for accessibility. (Enterprise, Enterprise Advanced)
Deployment Overview​
This guide is organized into sequential deployment phases with numbered steps. Each phase begins with prerequisites and ends with verification checks. Before you begin any phase, make sure the listed prerequisites are met, then move to the next phase only after the verification checks are passing. This structure helps you catch and fix issues early, when they are easiest to isolate.
Deployment Phases:
  1. Preparation and Networking
    Choose your deployment architecture, make networking decisions, provision required servers, and confirm the required network ports and paths are open before deployment.
  2. Install and Configure Calls
    Complete the installation and configuration for the deployment architecture you selected in Phase 1. You will only follow one path:
    • Path A: Configure Integrated Calls
      Use the built-in Calls service on the Mattermost server for simpler deployment at small scale.
    • Path B: Install and Configure RTCD (Optional)
      Use the RTCD (Real-Time Communication Daemon) service for larger scale production deployments. RTCD offloads media processing tasks from the Mattermost server for optimized performance and scalability.
  3. Install and Configure Recording (Optional)
    Calls Offloader is a service required to deliver recording, transcription and live captions.
  4. Pilot Rollout
    Expand testing to a small group of pilot users to watch for client, network, and environment-specific issues under real usage.
  5. Production Rollout
    Rollout to all users in controlled waves with appropriate communication and monitoring, and be ready to pause or roll back if needed.
Deployment Prerequisites​
Use this checklist to confirm you have the infrastructure, skills, and access required before you begin deploying Calls. Completing these prerequisites now helps prevent delays caused by missing dependencies later in the deployment process.
Deployment Infrastructure Requirements​
  • You have a running Mattermost server on v10.0+.
    See View system information to check your Mattermost edition and version.
  • Your Mattermost server is configured to use HTTPS.
    See Configure TLS if you need to set up HTTPS.
  • You know how many active users you have in your current Mattermost deployment
    See Site Statistics to access usage metrics.
  • You can provision at least one dedicated Linux server or VM if you plan to use the RTCD service.
    See Infrastructure Decisions (Step 1.2) if you're unsure if you need RTCD.
  • You can provision a dedicated Linux server or VM for the calls-offloader service if you need recording, transcription, or live captions.
  • You are prepared to deploy a TURN server if your users cannot reliably reach the media service on UDP or TCP 8443.
    See Networking Decisions (Step 1.3) if you're unsure if you need a TURN server.
  • You have the appropriate Mattermost edition and license for the features you need:
    • Mattermost Entry or Team Edition: 1-1 calling and screen sharing (Up to 40 minutes)
    • Mattermost Professional: Group calling and screen sharing (No time limit)
    • Mattermost Enterprise or Enterprise Advanced: Required for:
      • RTCD service for scale (50+ users) and production reliability.
      • Recording, transcription, or live captions.
Skills and Access Requirements​
  • You are comfortable with basic Linux administration, or you have someone available who is. You will need to connect to servers over SSH, edit configuration files, manage systemd services, inspect logs, and run shell commands.
  • You have System Admin access to your Mattermost server.
    See Mattermost roles to learn about roles and permissions.
Networking Requirements​
  • You know how end users will connect to Calls (From private networks, VPN, or from the public internet)
    This impacts your networking decisions (Step 1.3)
  • You can open the required inbound and outbound firewall rules, or you can engage the network or security team that manages them.
Validation Resources​
  • You have two test accounts available for smoke testing during Calls installation and configuration.
  • You have a small pilot group (5-10 users) available for validation across the client types and networks you care about.
Contacting Support​
Phase 1: Preparation and Networking​
1.1 Prerequisites​
Before you start, confirm the following:
  • You know how many active users you have in your current Mattermost deployment.
  • You know whether recording, transcription, or live captions are required for your deployment.
  • You can provision additional servers if your chosen architecture requires RTCD or Recording services.
  • You can open inbound and outbound network ports on the servers involved in your deployment.
    If a network or security team manages your firewalls, you'll need to involve them before continuing.
1.2 Infrastructure Decisions​
Here you will make two important infrastructure decisions: First you'll choose your media processing architecture, then decide whether you need recording. Reference topology for each architecture is provided.
Media Service: RTCD or Integrated​
Integrated
This is the simplest deployment model, since you do not need to provision a separate service to handle media processing. In Integrated mode, the Calls plugin runs its built-in media service directly on the Mattermost server.
RTCD
RTCD is a dedicated real-time communications service for Mattermost Calls that processes call media outside the main Mattermost server. In most production deployments, RTCD is the recommended deployment model because it improves performance, scalability, and stability by isolating call traffic and reducing load on the Mattermost server.
To determine if you'll need RTCD, start by answering the following questions about your deployment:
  • Are you deploying Calls on Kubernetes?
    • Yes: You'll need to deploy RTCD as it's the only supported way to run Calls. See the Kubernetes Calls deployment guide for details.
    • No: Continue to the next question.
  • What is the Total User count of your existing Mattermost deployment? (Check Site Statistics)
    • Up to 50: You can use the Integrated deployment model.
    • More than 50: You'll need to deploy RTCD to avoid impacting messaging performance of the Mattermost server.
Use the tabs below to view the reference architecture for each deployment model:
An Integrated deployment does not require any additional infrastructure:
Integrated Calls deployment
When to use it
  • You are evaluating Calls for the first time.
  • You expect fewer than 50 people to use Calls.
  • You want the simplest possible deployment.
Components
  • Mattermost server: Calls plugin is pre-installed, and no additional infrastructure is needed.
License
  • Mattermost Entry: 1:1 Calls + Screen Sharing (Up to 40 minutes)
  • Mattermost Professional, Enterprise, or Enterprise Advanced: Group Calls + Screen Sharing (No time limit)
Recording​
The Recording service (calls-offloader) can optionally be added to an Integrated Calls deployment if you need to enable recording, transcription, and live captions.
Reference architecture when using the Recording service with Integrated Calls:
Calls deployment with Integrated Calls and recording
Components
  • Mattermost server: Calls plugin is pre-installed.
  • Calls Offloader: Job service that manages recording, transcription and live captions.
License
1.3 Networking Decisions​
1.3.1 STUN for Public IP Discovery​
STUN is a protocol that helps the media server discover its public IP address automatically so remote clients can connect to Calls.
Mattermost provides a default STUN server (stun.global.calls.mattermost.com). No call media or signaling traffic is sent through this service; it is used only for STUN lookups. Use this decision tree to determine if you need to allow outbound access from your media server to the Mattermost global STUN service for public IP discovery.
STUN Decision Tree
  1. Are all users and your media server in the same private network, VPN, or air-gapped environment, with no outside clients?
    • Yes: You do not need STUN for public IP discovery. You will use the private address of your media server for configuration in Phase 2.
  2. Does your media server have a stable public IP address or DNS name that clients on the public internet can reach?
    • Yes: You do not need STUN for public IP discovery. You will use the stable public address of your media server for configuration in Phase 2.
    • No: You will need STUN. You must open outbound UDP 3478 from your media server to stun.global.calls.mattermost.com.
If your deployment requires STUN for public IP discovery, note that now so you can include it when opening ports in Step 1.5.
1.3.2 TURN Server​
TURN is a relay service used only when clients cannot reach the Calls media service directly. If STUN helps clients discover where to connect, TURN acts as a backup route when direct connectivity is not possible.
Provisioning a TURN server is necessary if both of these conditions are true:
  • Clients are on networks that cannot directly reach the RTCD Server or Calls plugin over UDP (preferred) on port 8443 for media traffic.
  • Clients are on networks that cannot directly reach the RTCD Server or Calls plugin over TCP (fallback) on port 8443 for media traffic.
TURN is typically a last resort as it adds latency and infrastructure complexity. Only plan to deploy TURN if your answers indicate that you cannot rely on UDP or TCP for media, and users need an alternative route.
1.4 Provision Infrastructure​
Now you'll provision the servers or VMs required to support your Calls deployment. You are only preparing infrastructure here; software installation and service configuration happen in later phases. This step matters because you need the IP addresses or DNS names of these servers before you can finish the networking configurations in the next step.
Infrastructure requirements depend on the deployment infrastructure you selected in Step 1.2. If you provision additional hardware, write down the IP addresses or DNS names now because you will use them in Step 1.5:
Integrated
Since the Mattermost server is handling all media processing, you can skip this step and proceed to network configuration in Step 1.5.
RTCD
You will need to provision a new server for RTCD. Use the performance baselines for benchmark examples of hardware sizing. The RTCD service supports horizontal scaling, but we recommend starting with one server and then scaling out if your expected workload requires it.
Recording
You will need to provision a new server for the calls-offloader service. The recommended starting point is 8 vCPU / 16 GB RAM, or you can use these performance benchmarks to estimate recording capacity and transcription load.
TURN Server
If you've determined in Step 1.3.2 that your users cannot reliably reach the media server over UDP or TCP 8443, you will need to provision your TURN server now.
Mattermost recommends installing coturn.
Before moving to Step 1.5, confirm the following:
  • Every required server or VM has been created.
  • Every required server has the IP address or DNS name you plan to use later in configuration.
  • You have administrative access to every required server. (validate with ssh <user>@<SERVER_IP>)
1.5 Network Configuration​
This section lists the network ports that must be opened for each server involved in your Calls deployment. The server instances must exist before you can configure these rules, which is why provisioning in Step 1.4 comes first.
How you open ports depends on your environment:
  • Cloud deployments (AWS, Azure, GCP): Configure inbound and outbound rules in your cloud console security group or network ACL for each instance.
  • On-premises or self-managed VMs: Use firewalld (RHEL, Rocky Linux, AlmaLinux) or ufw (Ubuntu/Debian) commands directly on each server.
  • Centrally managed firewall: If a network team manages your firewall, share the tables below with them and request the rules before proceeding.
Work through one server at a time so you can verify nothing is missed before moving on.
Only open the ports relevant for your chosen deployment architecture (Integrated or RTCD):
Mattermost server ports​
PortProtocolDirectionSourceDestinationNotes
443TCPInboundMattermost clientsMattermost serverHTTPS and WebSocket signaling.
8443UDPInboundMattermost clientsMattermost serverMedia traffic (Integrated mode).
8443TCPInboundMattermost clientsMattermost serverMedia traffic fallback (Integrated mode).
3478UDPOutboundMattermost serverstun.global.calls.mattermost.com(Optional - Step 1.3.1) Public IP discovery using STUN.
Recording server ports​
If you deployed a calls-offloader server in Step 1.4, open these ports:
4545TCPInboundMattermost servercalls-offloader serverJob service API (Internal only. Restrict this rule to the Mattermost server or approved application subnet only.)
8443UDPOutboundcalls-offloader serverMattermost serverRecorder and transcriber jobs connect to the media service as call participants.
8443TCPOutboundcalls-offloader serverMattermost serverMedia traffic fallback.
443TCPOutboundcalls-offloader serverMattermost serverRecorder and transcriber jobs post results back to Mattermost.
TURN server ports​
If you deployed a TURN server in Step 1.4, open only the ports required by the transports you actually configure. If you are using coturn, these are common defaults:
3478UDP / TCPInboundMattermost clientsTURN serverTURN relay.
5349TCPInboundMattermost clientsTURN server(Optional) If you configure TURN over TLS. Do not open this port unless you are explicitly using it.
49152-65535UDPInboundMattermost clientsTURN serverTURN relay port range required to relay media.
1.6 Networking Checks​
These checks validate firewall rules and network reachability. They do not require the production Calls, RTCD, or calls-offloader services to be installed yet. To get reliable results before those services exist, start a temporary listener on the target host before each applicable scan below. This is especially important for UDP checks, where a blocked port and an allowed-but-idle port can otherwise look the same.
First, install nmap on each source machine or client you will run checks from, and install ncat on each target host where you will start a temporary listener. For example:
  • Ubuntu or Debian: sudo apt install nmap ncat
  • RHEL, Rocky Linux, or AlmaLinux: sudo dnf install nmap nmap-ncat
When you execute each check below, nmap returns open, closed, or filtered.
Pass:
  • open: Port is reachable, and the target host was able to bind a temporary listener on that port.
Fail:
  • closed: Traffic reached the target host, but nothing is listening on that port. Confirm the temporary listener is still running, the port is correct, and the port was not already in use by another process.
  • filtered: Firewall is blocking the port. Revisit your networking configuration in Step 1.5 before continuing.
Integrated deployments
Start the temporary listeners on the Mattermost Server, then run nmap from any client machine on the same network as your users:
CheckCommandTARGET_IPDescription
1.6.1Mattermost Server: sudo ncat -u -l -k -p 8443 -c '/bin/cat'
Client: sudo nmap -sU -p 8443 TARGET_IP
Mattermost server IPClients can send UDP media to the Mattermost server
1.6.2Mattermost Server: sudo ncat -l -k -p 8443
Client: nmap -p 8443 TARGET_IP
Mattermost server IPClients can reach the Mattermost server for TCP media fallback
RTCD deployments
Start the temporary listeners on the RTCD Server, then run nmap from any client machine on the same network as your users:
1.6.3RTCD Server: sudo ncat -u -l -k -p 8443 -c '/bin/cat'
RTCD server IPClients can send UDP media to the RTCD server
1.6.4RTCD Server: sudo ncat -l -k -p 8443
RTCD server IPClients can reach the RTCD server for TCP media fallback
Start the temporary listener on the RTCD Server, then run nmap from the Mattermost server:
1.6.5RTCD Server: sudo ncat -l -k -p 8045
Mattermost Server: nmap -p 8045 TARGET_IP
RTCD server IPMattermost can reach the RTCD API
Recording deployments
Start the temporary listener on the Recording Server (calls-offloader), then run nmap from the Mattermost server:
1.6.6Recording Server: sudo ncat -l -k -p 4545
Mattermost Server: nmap -p 4545 TARGET_IP
calls-offloader server IPMattermost can reach the calls-offloader API
Start the temporary listeners on the media server (RTCD or Mattermost server if using Integrated mode), then run nmap from the Recording server (calls-offloader):
1.6.7RTCD or Mattermost Server: sudo ncat -u -l -k -p 8443 -c '/bin/cat'
Recording Server: sudo nmap -sU -p 8443 TARGET_IP
RTCD server IP (or Mattermost server IP if using Integrated mode)Calls Offloader can send UDP media to the media service to join calls for recording
1.6.8RTCD or Mattermost Server: sudo ncat -l -k -p 8443
Recording Server: nmap -p 8443 TARGET_IP
RTCD server IP (or Mattermost server IP if using Integrated mode)Calls Offloader can reach the media service for TCP media fallback
For the next check, use the existing HTTPS listener on your running Mattermost server instead of starting a temporary ncat listener:
1.6.9Recording Server: nmap -p 443 TARGET_IPMattermost server IPCalls Offloader can post recordings back to Mattermost
TURN deployments
Start the temporary listeners on the TURN Server, then run nmap from any client machine on the same network as your users:
1.6.10TURN Server: sudo ncat -u -l -k -p 3478 -c '/bin/cat'
Client: sudo nmap -sU -p 3478 TARGET_IP
TURN server IPClients can reach the TURN server on UDP 3478
1.6.11TURN Server: sudo ncat -l -k -p 3478
Client: nmap -p 3478 TARGET_IP
TURN server IPClients can reach the TURN server on TCP 3478
1.6.12TURN Server: sudo ncat -u -l -k -p 49152 -c '/bin/cat'
Client: sudo nmap -sU -p 49152 TARGET_IP
TURN server IPSpot check of the TURN relay port range
1.7 Verification Checks​
Before proceeding to Phase 2, confirm all of the following:
  • You have chosen your deployment architecture and provisioned the required servers.
  • You have confirmed your Mattermost license supports the architecture and features you plan to deploy.
  • Every required firewall rule and network path for your chosen architecture has been opened.
  • Every relevant network check in Step 1.6 returned the expected result (open, but not closed or filtered).
  • If you need STUN, outbound UDP 3478 is allowed to stun.global.calls.mattermost.com.
Phase 2: Install and Configure Calls​
Now you will configure Calls following the relevant path for your deployment architecture. Do not complete both paths for the same deployment.
  • Path A if you are using the Integrated Calls deployment model.
  • Path B if you are using the RTCD Calls deployment model.
Select your path in the tab below to follow the appropriate installation and configuration instructions:
Path A: Configure Integrated Calls​
2A.1 Prerequisites​
  • Phase 1 verification checks passed
  • Integrated is the base architecture you selected in Step 1.2
  • Two test accounts on your Mattermost server
  • System Admin permissions on your Mattermost server
2A.2 Configure the Calls plugin​
The Calls plugin is prepackaged with Mattermost self-hosted deployments. Go to System Console > Plugins > Calls > Settings and complete the following steps:
2A.2.1: Enable the plugin
Set Enable Plugin to true. This enables editing for the rest of the configuration settings on the page.
2A.2.2: Enable test mode
Set Test mode to on, so Calls stays restricted during initial validation. In this mode, System Admins control where Calls is available and can enable it in specific channels for testing.
2A.2.3: Configure the host media address
Set ICE Host Override to the IP address or DNS name clients will use to reach the media service. ICE (Interactive Connectivity Establishment) is the protocol your users' devices use to find a path to the media server. The ICE Host Override tells Calls which address to advertise to them. Base this value on the STUN decision tree from Step 1.3.1.
  • If your users are in a private network, VPN, or air-gapped environment, set it to the private address of the Mattermost server they can reach.
  • If your Mattermost server has a stable public IP, set it to that IP.
  • Otherwise, leave it empty for automatic public address discovery using STUN.
2A.2.4: Configure TURN Servers
If TURN is being used, replace or extend the ICE server configurations array with your TURN server details:
"urls": ["turn:turn.example.com:3478"],
"username": "<USERNAME>",
"credential": "<PASSWORD>"
If your TURN deployment uses short-lived generated credentials, also set TURN Static Auth Secret and TURN Credentials Expiration.
2A.2.5: Save configuration
Click Save on the Calls settings page. It is also recommended that you restart the plugin after changing media server settings:
  1. Go to System Console > Plugins > Plugin Management.
  2. Disable Calls and wait a few seconds.
  3. Enable Calls again.
2A.3 Verification Checks​
Now smoke test your Calls deployment with your test accounts:
  • Create a test channel such as calls-test.
  • Open the Channel menu, then select Enable calls.
  • Invite your test users into the channel so you can validate a real call.
CheckActionPass criteria
2A.3.1Start a call from the test channel with a second userBoth users are in the call
2A.3.2Speak during the callBoth users can hear each other clearly
2A.3.3Share your screen from a desktop app or supported browserScreen sharing is visible to the other user
2A.3.4End the callThe call indicator disappears from the channel
Phase 3: Install and Configure Recording​
Now we will install and configure the calls-offloader job service that handles call recording, transcription, and live captions.
You can skip this phase if you do not need recording, transcription, or live captions.
3.1 Prerequisites​
  • calls-offloader server is provisioned (1.4) and relevant networking checks passed (1.6.6-1.6.9)
  • If you are using Integrated mode: Phase 2A verification checks passed (2A.3.1-2A.3.4).
  • If you are using RTCD: Phase 2B verification checks passed (2B.5.1-2B.5.4).
  • Mattermost Enterprise or Enterprise Advanced license is active on your server
3.2 Install calls-offloader​
Follow the Calls Offloader Setup and Configuration guide for installation. The guide covers:
  • Binary installation
  • config.toml configuration
  • Systemd service setup
  • Docker-backed jobs
  • Private network overrides
  • Air-gapped installation
Before proceeding, run these checks from the Mattermost server to confirm calls-offloader is running and reachable:
CheckCommandPass criteria
3.2.1nmap -p 4545 YOUR_OFFLOADER_SERVERopen - calls-offloader is running and accepting connections.
3.2.2curl http://YOUR_OFFLOADER_SERVER:4545/versionReturns a JSON version string
3.3 Connect calls-offloader to Mattermost​
  1. Go to System Console > Plugins > Calls > Settings.
  2. Set Job Service URL to the calls-offloader address, for example http://calls-offloader.internal:4545 on a trusted internal network.
  3. Enable Call Recordings if needed.
  4. Enable Call Transcriptions if needed. Transcriptions require recordings to be enabled.
  5. Enable Live Captions if needed. Live captions require both recordings and transcriptions to be enabled.
  6. Click Save and restart the Calls plugin so the change takes effect.
3.4 Verification Checks​
Now smoke test recording-related features with your test accounts:
3.4.1Start recording as a call hostRecording starts without error.
3.4.2End the call or stop the recordingAn MP4 file appears in the call thread after processing completes.
3.4.3With transcription enabled, end a recorded callAn MP4 file and transcript file appear in the call thread after processing completes.
3.4.4With live captions enabled, start a recorded callCaptions appear during the call within 1-3 seconds after participants speak.
If a recording-related check fails, isolate the problem before retrying:
  • 3.4.1 or 3.4.2 fails: Confirm the Job Service URL is correct, the calls-offloader service is running, and the Mattermost server can reach port 4545.
  • 3.4.3 fails: Confirm recordings are enabled first, then confirm transcription is enabled.
  • 3.4.4 fails: Confirm both recordings and transcriptions are enabled before testing live captions.
Phase 4: Pilot Rollout​
Now that the technical configuration is complete and validated, run a small pilot with real users before broad rollout. The goal is to confirm Calls works reliably across the clients and locations your organization uses, and that your servers stay healthy under normal usage.
4.1 Prerequisites​
  • If using Integrated mode: Phase 2A verification checks passed (2A.3.1-2A.3.4)
  • If using RTCD: Phase 2B verification checks passed (2B.5.1-2B.5.4)
  • If using Recording: Phase 3 verification checks passed (3.4.1-3.4.4)
  • 5 to 10 volunteer pilot users from different locations
  • Access to the metrics dashboard and logs on your Calls infrastructure
  • Pilot users have current Mattermost desktop and mobile apps
4.2 Preparation and Communication​
For a successful pilot, make sure pilot users know what to test, how to start a call, and how to report problems.
After inviting your pilot users into the calls-test channel, post a short message there so everyone is testing the same things. A template is provided below:
Pilot user communication template
## Mattermost Calls pilot
Thank you for volunteering to test Mattermost Calls before a wider rollout. After 3-5 days of pilot testing, we will ask everyone to share their findings and experiences. Please keep track of any issues or feedback so you can summarize them when requested.
**How to start**
Calls is enabled in this channel for pilot testing. You can select **Start call** in the channel header to begin, or join an existing call if one is already started.
You can learn more about Mattermost Calls in the [documentation](https://docs.mattermost.com/end-user-guide/collaborate/make-calls.html).
**Test Cases**
| Test | Action | Pass criteria | Client Types |
| T1 | Group call with 3-5 participants | All participants can hear each other clearly | Web, Desktop, Mobile |
| T2 | Group call lasting 15 minutes or longer | No unexpected drops or audio degradation | Web, Desktop, Mobile |
| T3 | Participants join calls from outside the main office network | Call quality is acceptable from that network | Web, Desktop, Mobile |
| T4 | Participants share screen during a call | Screen sharing works and is visible to all participants | Desktop, Web |
| T5 | Record a group call, if recording is enabled | MP4 and transcription file appear in the call thread after processing completes | Web, Desktop, Mobile |
| T6 | Enable Live Captions during a group call, if captions are enabled | Captions appear during the call within 1-3 seconds after participants speak | Web, Desktop |
**Reporting Issues**
If you encounter an issue, please report it by posting in this channel and including:
- Test number
- Reproduction steps
- What you expected to happen
- What actually happened (with screenshots)
- Your client type (desktop, browser, or mobile)
4.3 Verification Checks​
Monitoring
4.3.1Check your metrics dashboard during a pilot callActive sessions and participants are visible and counted correctly
4.3.2If using RTCD, check RTCD error metrics after pilot calls (rtcd_rtc_errors_total)No elevated error counts
4.3.3If using RTCD, check CPU and memory metrics during a pilot call (rtcd_process_cpu_seconds_total, rtcd_process_resident_memory_bytes)No CPU or memory spikes observed
4.3.4Review Mattermost logs, plus RTCD and calls-offloader logs if those services are deployedNo recurring ERROR lines, and no unexpected WARN patterns
Production readiness
Collect feedback from your pilot users after 3-5 business days and use it to evaluate production readiness:
CheckRequirement
4.3.5Audio quality rated acceptable by 80%+ of pilot users
4.3.6No blocking issues found in the pilot test cases
4.3.7All pilot users confirm readiness for production rollout
If the pilot users find issues, do not expand the rollout yet:
  • Fix the issue in the smallest possible scope.
  • Repeat the affected pilot test case.
  • Stay in pilot until the failing scenario is consistently passing.
You can also run /call stats in the Mattermost message area after a failed test for additional diagnostic clues.
Phase 5: Production Rollout​
Now you will execute a broader rollout to all users in production.
5.1 Prerequisites​
  • Phase 4 production readiness checks passed (4.3.1-4.3.7)
  • Rollback plan documented and understood
5.2 Rollback plan​
You should be familiar with your rollback options before you begin the staged production rollout. If something goes wrong, choose the smallest rollback that solves the problem:
Per-channel rollback
Disables Calls in specific channels.
  1. Navigate to the impacted channel.
  2. Select the Channel menu, then select Disable calls.
Test mode rollback
Restricts Calls to channels where it has been enabled by a System Admin.
  2. Set Test Mode to on.
Full rollback
Disables Calls completely for everyone.
  2. Disable the Calls plugin.
If you have an existing conferencing tool, keep it available until Calls is stable in production.
5.3 Preparation and Communication​
Before announcing Calls to users, create a calls-support public channel. This gives users a clear place to report issues and gives your admins a single place to track rollout problems.
Also prepare a short announcement to share in an all-hands channel or similar high-visibility location. A template is provided below:
Production rollout communication template
## Mattermost Calls rollout
We're enabling Mattermost Calls across this server. Starting today, you can start audio calls in select channels directly within Mattermost - no need to switch to a separate tool.
We're rolling out gradually, starting with a select set of channels before expanding to everyone.
**Calls features**
- Start or join 1:1 and group audio calls
- Share your screen from the desktop app or browser
- Record calls and generate transcripts, if enabled
- Use live captions during recorded calls, if enabled
**How to start a call**
Select **Start call** in the channel header. Anyone in the channel can join.
**Things to know**
- We recommend updating your [desktop and mobile apps](https://mattermost.com/apps/) to the latest version
- Your browser or desktop app may ask for microphone permission the first time you join a call.
- Screen sharing may also require a screen capture permission prompt.
**Need help?**
Post in `~calls-support` and include what you were trying to do, what happened, and a screenshot if possible.
5.4 Rollout Stages​
We recommend enabling Calls in stages instead of enabling it everywhere at once. This way you can watch real usage, catch problems early, and rollback cleanly if needed.
StageChannels / departmentsSuggested timelineRollback approach
Stage 1IT and Admin channelsDays 1-3Per-channel rollback
Stage 2Engineering or power user channelsDays 4-7Per-channel rollback
Stage 3Full organizationDay 8+Test mode (if issues are isolated) or full rollback
If a rollout stage introduces problems, pause the rollout, use the rollback option listed for that stage, fix the issue, and repeat the same stage before moving to the next one.
5.5 Monitor and optimize​
Once Calls is live, monitor it actively for the first two weeks and tune based on what you see.
5.5.1: Watch server health during peak call hours
Monitor CPU and memory on the media server (RTCD or Mattermost server) daily during peak usage. If CPU utilization consistently exceeds 70%, consider increasing hardware specs, or adding RTCD nodes before the next rollout stage.
5.5.2: Review logs daily
Check Mattermost, RTCD, and calls-offloader logs each day for recurring ERROR or WARN lines. Address any patterns before they become user-facing problems.
5.5.3: Tune Max Call Participants
If you see resource pressure during large calls, lower Max Call Participants in System Console > Plugins > Calls. By default, there is no participant limit (configured as 0, which means unlimited). A practical ceiling for most deployments is 50.
5.5.4: Track user-reported issues
Monitor ~calls-support for recurring complaints.
Check Appendix A: Troubleshooting for common issues and fixes.
Appendix A: Troubleshooting​
A.1 The call button is missing​
CauseFix
The Calls plugin is disabledGo to System Console > Plugins > Plugin Management and enable Calls
The deployment is in test modeGo to System Console > Plugins > Calls > Settings and check the deployment state - Calls must be enabled in specific channels by System Admins in test mode
Calls is not enabled for the channelWhen test mode is enabled, open the channel menu and select Enable calls
The user is on an older clientAsk the user to update to the current Mattermost desktop or mobile app
A.2 Calls start but audio does not work​
CauseFix
UDP 8443 is blockedRepeat the UDP connectivity check from Phase 1 (check 1.6.1 or 1.6.3) and confirm the firewall rule is applied
TCP 8443 is also blocked and fallback is failingRepeat the TCP check (1.6.2 or 1.6.4) - clients need at least one path to the media service
The wrong media address is being advertisedRe-check ICE Host Override in Phase 2A (Integrated) or ice_host_override in rtcd.toml in Phase 2B (RTCD) - the address must be reachable by clients
Browser or desktop microphone permissions were deniedAsk the user to check browser or OS microphone permissions and reload the app
A.3 Remote users cannot join from outside the network​
CauseFix
External firewall rules are blocking UDP 8443Confirm external reachability to UDP 8443 on the media server - cloud security groups and on-prem firewalls both need to allow inbound traffic from the internet
The advertised media address is a private IPSet ICE Host Override (Integrated) or ice_host_override in rtcd.toml to the correct public IP or use STUN (1.3.1)
Client networks are too restrictive for direct UDP or TCPDeploy a TURN server and add it to ICE server configurations
A.4 Recording, transcription, or captions are failing​
CauseFix
calls-offloader is not runningRun nmap -p 4545 YOUR_OFFLOADER_SERVER from the Mattermost server - if the result is closed, the service is not running; check the systemd service logs
Mattermost cannot reach the Job Service URLRun curl http://YOUR_OFFLOADER_SERVER:4545/version from the Mattermost server and confirm it returns a version string
The offloader service account cannot use DockerConfirm the service account is in the docker group on the calls-offloader server
