Use tools and approve actions
Approve or reject an agent's tool calls, share or hide results in channels, and connect your accounts to MCP tool providers. Your admin decides which tools exist and which need your approval.
Where tools run
- Direct messages and the Agents pane: tools are available by default.
- Channels: tools are off unless your admin turned on Enable Channel Mention Tool Calling. When it's off and you ask for something that needs a tool, the agent tells you to use a direct message or the Agents pane.
- Which tools: Mattermost tools, tools from remote MCP servers your admin connected, and tools from Mattermost plugins that register with Agents. Availability also depends on your permissions and on whether your account is connected to each provider.
Mattermost tools run as you. External MCP tools use your OAuth token, or the server's configured headers for servers without OAuth, unless the agent uses a shared service account.
Approve or reject a tool call
When a tool needs your approval, the agent's reply shows a card with the tool name, its arguments, and Accept and Reject buttons. Nothing runs until you choose.
- If several tools wait at once, use Accept all or Reject all, or decide each one.
- A reply can mix tools that ran automatically and tools that wait. Automatic ones show an Auto-approved badge. The others keep their buttons.
- Only the person who started the conversation can approve. Other people in a channel see the tool name but not its arguments, and they can't approve.
- An unanswered call stays pending. It never approves itself.
Share or keep private (channels only)
In a channel, a second step follows a tool call that ran after your approval. After the tool returns, you choose what happens to the result:
- Share: the agent uses the result in its reply, and everyone in the channel sees the tool's arguments and result.
- Keep private: the result stays with you. The agent writes its channel reply without that content.
You can't take back a Share. Tools your admin set to run automatically everywhere skip this step, and their results are shared right away.
In a direct message or the Agents pane there's no second step, because only you can see the conversation.
Connect your account to a tool provider
Some MCP servers need you to sign in with your own account before their tools appear.
From the conversation. When you ask for something that needs a provider you haven't connected, the agent shows a Connect card that explains why. Select Connect and sign in in the window that opens. The agent continues automatically when you're done. Select Skip to continue without it. If you close the window early, select Connect again. If your session with a provider expires partway through a conversation, the agent shows the card again.
From the Tools menu. In the Agents pane, start a new chat and open Tools. The menu lists the providers the selected agent can use.
- Select Connect or Disconnect next to a provider that uses OAuth.
- Turn providers on or off for yourself. Your choices are saved to your account.
- Select Refresh tool providers to rediscover tools after an admin changes providers or you connect one.
Use web or desktop to connect. The mobile apps can't start MCP OAuth.
Agents that use a service account
For an agent your admin set to use a shared service account, you're never asked to connect and the Tools menu isn't shown. External tools act as the shared account, not as you, so ask your admin what the agent can reach.
When a tool fails
The agent can recover from a failed call, for example by trying another approach or explaining the failure. After three failed tool calls in a row, it stops calling tools, describes the latest error, and asks you for what's missing. A successful call resets the count. If failures repeat, check that you've connected the provider and that you can access the thing the tool targets.
After a set number of tool rounds (30 unless your admin changed it), the agent stops calling tools and answers with what it has.
Ask the agent a question back
When the agent needs a decision before it continues, it asks a multiple-choice question in the conversation. Select an option, type your own answer under Something else…, or select Skip.
