Back up and automate Agents
Agents stores its configuration, agents, and conversations in the Mattermost database, not config.json, so a database backup covers it. Automate configuration through /plugins/mattermost-ai/admin/config.
What's stored where​
A regular Mattermost database backup covers everything below. The plugin has no separate data store.
DataLocationNotes
Plugin configuration: services, MCP servers, web search, embedding settings, and every setting in System Console > Plugins > AgentsAgents_ConfigHistoryThe row with Active = true is current. Every save adds a row, and older rows are kept. API keys and other credentials are stored in this JSON, in the active row and in the history.
AgentsAgents_UserAgentsIdentity, instructions, access rules, and tool grants.
Agent version historyAgents_AgentVersionsIncludes past custom instructions.
Skills (custom prompts) and pinsLLM_CustomPrompts, LLM_CustomPromptPins
ConversationsLLM_Conversations, LLM_TurnsMessages, tool calls, and tool results. A conversation is soft-deleted when its post is deleted.
Channel auto-reply settingsAgents_ChannelAutoReply
Migration stateAgents_SystemFlags such as which one-time migrations ran.
Semantic search vectorsllm_posts_embeddingsCan be rebuilt with a Full Reindex. Back it up separately for large deployments to avoid a long reindex.
MCP OAuth tokens, plugin MCP registrationsMattermost plugin key-value store
Access policiesMattermost's access control storeStored by the server, not the plugin.
The PluginSettings.Plugins["mattermost-ai"] entry in the server's configuration is emptied after the one-time migration to the database, and nothing reads it. Editing it does nothing. Use the System Console or the admin API.
Restoring a backup that predates a credential change restores the old credentials. Rotate any key you pasted into the System Console if a database backup or config history might be exposed.
Back up​
  1. Include the Mattermost database in your normal backup. That covers every table above. Agent avatars are profile images, so also back up the Mattermost file store.
  2. For a large semantic search index, snapshot llm_posts_embeddings too.
  3. To restore, restore the database, then enable the plugin. Restoring only config.json doesn't bring back agents or services.
Configuration API​
Use the admin API to read or write plugin settings from scripts. It requires a session or personal access token for a user with the manage_system permission.
# Read
curl -s -H "Authorization: Bearer $MM_TOKEN" \
https://your-mattermost-server/plugins/mattermost-ai/admin/config
# Write (send the whole configuration back)
curl -s -X PUT -H "Authorization: Bearer $MM_TOKEN" -H "Content-Type: application/json" \
--data @config.json \
PUT replaces the configuration, so read it first, change what you need, and send it all back. The response is the saved configuration with any server-assigned IDs. Saves go through the same license and validation checks as the System Console. Invalid MCP configuration, duplicate IDs, bad link domains (when Render AI-generated links is on), and gated changes are rejected.
A trimmed example of the shape:
"services": [
"id": "k3g8sdb1ntbibnyt8u5jmqhc7w",
"name": "OpenAI Service",
"type": "openai",
"apiKey": "sk-...",
"defaultModel": "gpt-4o",
"fallbackServiceID": "z9d4meq7jtrx5nch1u8kwsoa3e"
"defaultBotUserID": "q8n4w7bpstfxjcmk3yr9zhde1a",
"allowUnsafeLinks": false,
"enableChannelMentionToolCalling": false,
"mcp": { "enablePluginServer": false, "servers": [], "idleTimeoutMinutes": 30 },
"webSearch": { "enabled": false }
Service types are openai, anthropic, azure, openaicompatible, bedrock, cohere, north, mistral, gemini, and vertex. Config keys for each System Console setting are in the settings table.
  • Service IDs are 26-character Mattermost IDs. Leave id empty on a new service and the server assigns one. Configurations from before this format used UUIDs and were rewritten once on upgrade. A write that carries a UUID service ID is rejected.
  • Default and transcript agents are chosen by bot user ID in defaultBotUserID and transcriptBotUserID, so renaming an agent doesn't change the selection. defaultBotUserID is the agent used by features that don't name one, such as meeting summaries. transcriptBotUserID selects the agent whose OpenAI, OpenAI Compatible, or Azure service transcribes call recordings through the /post/{postid}/transcribe/file/{fileid} route. The Create meeting summary button doesn't use it. The older defaultBotName and transcriptBackend username fields are read only when the ID field is empty. On startup and on every save, the plugin replaces a username with the matching bot user ID. A username no agent holds stays in place and is logged as a warning. Automation should write the ID fields and set the legacy fields to "".
  • Legacy bots. Configurations that stored agents in bots are migrated into the database on startup, then bots is cleared. See Upgrade from Agents 1.x.
Agent API​
Agents have REST routes under /plugins/mattermost-ai/agents: POST to create, GET to list, and GET, PUT, and DELETE on /{agentid}. They also have /{agentid}/avatar, /{agentid}/versions, and /{agentid}/access_policy. These routes enforce the same permissions and license limits as the Agents page. PUT is a full-document save. Send every field. Send mcpDynamicToolLoading explicitly on create and update, because omitting it stores false.
Every state-changing call except skill pins is written to the audit log. See Monitor Agents.
High availability​
Agent and configuration changes propagate to every node in a cluster by cluster event, within seconds. License changes are picked up on every node without a restart. If a node misses an event, a config save or plugin reload on it forces a fresh load from the database.
