Performance monitoring metrics
Mattermost provides the following performance monitoring statistics to integrate with Prometheus and Grafana.
Custom Mattermost metrics​
The following is a list of custom Mattermost metrics that can be used to monitor your system's performance:
API metrics​
  • mattermost_api_time: The total time in seconds to execute a given API handler.
Caching metrics​
  • mattermost_cache_etag_hit_total: The total number of ETag cache hits for a specific cache.
  • mattermost_cache_etag_miss_total: The total number of ETag cache misses for an API call.
  • mattermost_cache_mem_hit_total: The total number of memory cache hits for a specific cache.
  • mattermost_cache_mem_invalidation_total: The total number of memory cache invalidations for a specific cache.
  • mattermost_cache_mem_miss_total: The total number of cache misses for a specific cache.
The above metrics can be used to calculate ETag and memory cache hit rates over time.
Example caching metrics, including Etag hit rate and mem cache hit rate, in a self-hosted Mattermost deployment.
Cluster metrics​
  • mattermost_cluster_cluster_request_duration_seconds: The total duration in seconds of the inter-node cluster requests.
  • mattermost_cluster_cluster_health_score: A score that gives an idea of how well it is meeting the soft-real time requirements of the gossip protocol.
  • mattermost_cluster_cluster_requests_total: The total number of inter-node requests.
  • mattermost_cluster_cluster_event_type_totals: The total number of cluster requests sent for any type.
  • mattermost_cluster_reliable_fallback_tcp: The total length in bytes of the SendBestEffort calls (UDP) that had to fallback to SendReliable (TCP) because of the message length. This is a histogram with 8 buckets, from 32KiB to 4MiB. Ideally, the count of this metric should be always 0, but plugins may be misusing the websocket API and attempting to send large messages via UDP; in that case, plugins should be fixed to set ReliableClusterSend to true.
Database metrics​
  • mattermost_db_active_users: The total number of active users.
  • mattermost_db_cache_time: Time to execute the cache handler.
  • mattermost_db_master_connections_total: The total number of connections to the master database.
  • mattermost_db_read_replica_connections_total: The total number of connections to all the read replica databases.
  • mattermost_db_search_replica_connections_total: The total number of connections to all the search replica databases.
  • mattermost_db_store_time: The total time in seconds to execute a given database store method.
  • mattermost_db_replica_lag_abs: Absolute lag time based on binlog distance/transaction queue length.
  • mattermost_db_replica_lag_time: The time taken for the replica to catch up.
Database connection metrics​
  • go_sql_max_open_connections: Maximum number of open connections to the database.
  • go_sql_open_connections: The number of established connections both in use and idle.
  • go_sql_in_use_connections: The number of connections currently in use.
  • go_sql_idle_connections: The number of idle connections.
  • go_sql_wait_count_total: The total number of connections waited for.
  • go_sql_wait_duration_seconds_total: The total time blocked waiting for a new connection.
  • go_sql_max_idle_closed_total: The total number of connections closed due to SetMaxIdleConns.
  • go_sql_max_idle_time_closed_total: The total number of connections closed due to SetConnMaxIdleTime.
  • go_sql_max_lifetime_closed_total: The total number of connections closed due to SetConnMaxLifetime.
HTTP metrics​
  • mattermost_http_errors_total: The total number of http API errors.
  • mattermost_http_requests_total: The total number of http API requests.
  • mattermost_http_websockets_total: The total number of websocket connections to this server.
Example HTTP metrics, including number of API errors per minute, number of API requests per minute, and mean request time per minute, in a self-hosted Mattermost deployment.
Login and session metrics​
  • mattermost_login_logins_fail_total: The total number of failed logins.
  • mattermost_login_logins_total: The total number of successful logins.
Mattermost channels metrics​
  • mattermost_post_broadcasts_total: The total number of websocket broadcasts sent because a post was created.
  • mattermost_post_emails_sent_total: The total number of emails sent because a post was created.
  • mattermost_post_file_attachments_total: The total number of file attachments created because a post was created.
  • mattermost_post_pushes_sent_total: The total number of mobile push notifications sent because a post was created.
  • mattermost_post_total: The total number of posts created.
  • mattermost_post_webhooks_total: Total number of webhook posts created.
Example Mattermost channels metrics, including messages per minute, broadcasts per minute, emails sent per minute, mobile push notifications per minute, and number of file attachments per minute, in a self-hosted Mattermost deployment.
Process metrics​
  • mattermost_process_cpu_seconds_total: Total user and system CPU time spent in seconds.
  • mattermost_process_max_fds: Maximum number of open file descriptors.
  • mattermost_process_open_fds: Number of open file descriptors.
  • mattermost_process_resident_memory_bytes: Resident memory size in bytes.
  • mattermost_process_start_time_seconds: Start time of the process since unix epoch in seconds.
  • mattermost_process_virtual_memory_bytes: Virtual memory size in bytes.
  • mattermost_process_virtual_memory_max_bytes: Maximum amount of virtual memory available in bytes.
Search metrics​
  • mattermost_search_posts_searches_duration_seconds: The total duration in seconds of post searches.
  • mattermost_search_channel_index_total: The total number of channel indexes carried out.
  • mattermost_search_file_index_total: The total number of files indexes carried out.
  • mattermost_search_files_searches_duration_seconds: The total duration in seconds of file searches.
  • mattermost_search_files_searches_total: The total number of file searches carried out.
  • mattermost_search_post_index_total: The total number of posts indexes carried out.
  • mattermost_search_posts_searches_total: The total number of post searches carried out.
  • mattermost_search_user_index_total: The total number of user indexes carried out.
  • mattermost_search_engine_status: Status of the configured search engine: 1 = healthy or not configured, 0 = configured but unavailable. Use this metric to set up alerts for search engine outages.
WebSocket metrics​
  • mattermost_websocket_broadcast_buffer_size: Number of events in the websocket broadcasts buffer waiting to be processed.
  • mattermost_websocket_broadcast_buffer_users_registered: Number of users registered in a broadcast buffer hub.
  • mattermost_websocket_broadcasts_total: The total number of websocket broadcasts sent for any type.
  • mattermost_websocket_event_total: Total number of websocket events.
  • mattermost_websocket_reconnects_total: Total number of websocket reconnect attempts.
Logging metrics​
  • mattermost_logging_logger_queue_used: Number of records in log target queue.
  • mattermost_logging_logger_logged_total: The total number of records logged.
  • mattermost_logging_logger_error_total: The total number of logger errors.
  • mattermost_logging_logger_dropped_total: The total number of dropped log records.
  • mattermost_logging_logger_blocked_total: The total number of log records that were blocked/delayed.
Debugging metrics - system​
  • mattermost_system_server_start_time: The time the server started.
Use mattermost_system_server_start_time to dynamically add an annotation corresponding to the event.
Example debugging metrics, including number of messages per second, in a self-hosted Mattermost deployment.
Debugging metrics - jobs​
  • mattermost_jobs_active: Number of active jobs.
Use mattermost_jobs_active to display an active jobs chart.
Example debugging metrics, including active jobs, in a self-hosted Mattermost deployment.
Or, use mattermost_jobs_active to dynamically add a range annotation corresponding to jobs being active.
Use annotations to streamline analysis when a job is long running, such as an LDAP synchronization job.
Plugin metrics​
  • mattermost_plugin_api_time: Time to execute plugin API handlers in seconds.
  • mattermost_plugin_hook_time: Time to execute plugin hook handler in seconds.
  • mattermost_plugin_multi_hook_server_time: Time for the server to execute multiple plugin hook handlers in seconds.
  • mattermost_plugin_multi_hook_time: Time to execute multiple plugin hook handler in seconds.
The metrics above are measured by the Mattermost server as it executes plugin code. From Mattermost v11.8.0, plugin-provided Prometheus metrics can also be exposed through the standard Mattermost /metrics endpoint when the AggregatePluginMetrics feature flag is enabled. Aggregated plugin metrics include a plugin_id label, based on the plugin's manifest ID, so admins can identify which plugin produced each metric.
Shared metrics​
  • mattermost_shared_channels_sync_collection_duration_seconds: Duration tasks spend collecting sync data (seconds).
  • mattermost_shared_channels_sync_collection_step_duration_seconds: Duration tasks spend in each step collecting data (seconds).
  • mattermost_shared_channels_sync_count: Count of sync events processed for each remote.
  • mattermost_shared_channels_sync_send_duration_seconds: Duration tasks spend sending sync data (seconds).
  • mattermost_shared_channels_sync_send_step_duration_seconds: Duration tasks spend in each step sending data (seconds).
  • mattermost_shared_channels_task_in_queue_duration_seconds: Duration tasks spend in queue (seconds).
  • mattermost_shared_channels_task_queue_size: Current number of tasks in queue.
Remote cluster metrics​
  • mattermost_remote_cluster_clock_skew: An approximated value for clock skew between clusters.
  • mattermost_remote_cluster_conn_state_change_total: Total number of connection state changes.
  • mattermost_remote_cluster_msg_errors_total: Total number of message errors.
  • mattermost_remote_cluster_msg_received_total: Total number of messages received from the remote cluster.
  • mattermost_remote_cluster_msg_sent_total: Total number of messages sent to the remote cluster.
  • mattermost_remote_cluster_ping_time: The ping roundtrip times to the remote cluster.
Notification metrics​
  • mattermost_notifications_error: Total number of errors that stop the notification flow.
  • mattermost_notifications_not_sent: Total number of notifications the system deliberately did not send.
  • mattermost_notifications_success: Total number of successfully sent notifications.
  • mattermost_notifications_total: Total number of notification events.
  • mattermost_notifications_total_ack: Total number of notification events acknowledged.
  • mattermost_notifications_unsupported: Total number of untrackable notifications due to an unsupported app version.
Mobile app metrics​
  • mattermost_mobileapp_mobile_channel_switch: Duration of the time taken from when a user clicks on a channel name, and the full channel sreen is loaded (seconds).
  • mattermost_mobileapp_mobile_load: Duration of the time taken from when a user opens the app and the app finally loads all relevant information (seconds).
  • mattermost_mobileapp_mobile_team_switch: Duration of the time taken from when a user clicks on a team, and the full categories screen is loaded (seconds).
Web app metrics​
  • mattermost_webapp_channel_switch: Duration of the time taken from when a user clicks on a channel in the LHS to when posts in that channel become visible (seconds).
  • mattermost_webapp_cumulative_layout_shift: Measure of how much a page's content shifts unexpectedly.
  • mattermost_webapp_first_contentful_paint: Duration of how long it takes for any content to be displayed on screen to a user (seconds).
  • mattermost_webapp_global_threads_load: Duration of the time taken from when a user clicks to open Threads in the LHS until when the global threads view becomes visible (milliseconds).
  • mattermost_webapp_interaction_to_next_paint: Measure of how long it takes for a user to see the effects of clicking with a mouse, tapping with a touchscreen, or pressing a key on the keyboard (seconds).
  • mattermost_webapp_largest_contentful_paint: Duration of how long it takes for large content to be displayed on screen to a user (seconds).
  • mattermost_webapp_long_tasks: Counter of the number of times that the browser's main UI thread is blocked for more than 50ms by a single task.
  • mattermost_webapp_page_load: The amount of time from when the browser starts loading the web app until when the web app's load event has finished (seconds).
  • mattermost_webapp_rhs_load: Duration of the time taken from when a user clicks to open a thread in the RHS until when posts in that thread become visible (seconds).
  • mattermost_webapp_team_switch: Duration of the time taken from when a user clicks on a team in the LHS to when posts in that team become visible (seconds).
  • mattermost_webapp_time_to_first_byte: Duration from when a browser starts to request a page from a server until when it starts to receive data in response (seconds).
Standard Go metrics​
The performance monitoring feature provides standard Go metrics for HTTP server runtime profiling data and system monitoring, such as:
  • go_memstats_alloc_bytes for memory usage
  • go_goroutines for number of goroutines
  • go_gc_duration_seconds for garbage collection duration
  • go_memstats_heap_objects for object tracking on the heap
To learn how to set up runtime profiling, see the pprof package Go documentation. You can also visit the ip:port page for a complete list of metrics with descriptions.
If enabled, you can run the profiler by
go tool pprof http://localhost:<port>/debug/pprof/profile?seconds=<duration>
where you can replace localhost with the server name. The profiling reports are available at <ip>:<port>, which include:
  • /debug/pprof/profile?seconds=30 for CPU profiling
  • /debug/pprof/cmdline for command line profiling
  • /debug/pprof/symbol for symbol profiling
  • /debug/pprof/trace for trace profiling
  • /debug/pprof/goroutine for Go routine profiling
  • /debug/pprof/heap for heap profiling
  • /debug/pprof/threadcreate for threads profiling
  • /debug/pprof/block for block profiling
  • /debug/pprof/allocs for past memory allocations
  • /debug/pprof/mutex for logs of the holders of contended mutexes
Example Go metrics for HTTP server runtime profiling data and system monitoring, including memory usage, Go routines, and garbage collection duration, in a self-hosted Mattermost deployment.
Host/system metrics​
From Metrics Plugin v0.7.0, you can pull metrics from node exporter targets to access network-related panels for Mattermost Calls.
Frequently asked questions​
Why are chart labels difficult to distinguish?​
The chart labels used in server filters and legends are based on the hostname of your machines. If the hostnames are similar, then it will be difficult to distinguish the labels.
You can either set more descriptive hostnames for your machines or change the display name with a relabel_config in Prometheus configuration.
