Deploy Grafana Loki for centralized logging
This guide extends your existing Prometheus and Grafana performance monitoring deployment by adding Grafana Loki for centralized log aggregation. While Prometheus collects metrics (CPU, request latency, goroutine counts), Loki collects logs — giving your operations team the ability to search, filter, and correlate Mattermost application logs across all servers from a single Grafana interface.
With Loki in place you can:
  • Search Mattermost logs across all application servers from Grafana.
  • Filter by log level, HTTP status code, or free-text search.
  • Identify the top recurring errors and warnings.
  • Correlate log events with Prometheus metric spikes on the same timeline.
  • Optionally collect PostgreSQL database logs alongside application logs.
Architecture overview​
The deployment adds two components to your monitoring stack:
  • Loki — the log aggregation engine, installed on your existing Grafana/Prometheus monitoring server.
  • OpenTelemetry Collector — a versatile, industry-standard agent installed on each Mattermost application server to ship logs.
│ Mattermost App 01 │ │ Mattermost App 02 │
│ /opt/mattermost/ │ │ /opt/mattermost/ │
│ logs/mattermost.log│ │ logs/mattermost.log│
│ [ OTel Col ] │ │ [ OTel Col ] │
│ push (:3100/otlp) │
│ Monitoring Server │
│ [ Prometheus :9090 ] [ Loki :3100 ] │
│ [ Grafana :3000 ] │
│ Metrics + Logs │
Optional: Add the OpenTelemetry Collector on your PostgreSQL server to also
ship database logs to Loki.
Prerequisites​
Before starting, confirm the following:
  • Prometheus and Grafana are deployed and collecting Mattermost metrics per the performance monitoring guide.
  • You have SSH access with sudo privileges to the monitoring server and each Mattermost application server.
  • Mattermost is installed at /opt/mattermost (the default location). If your installation path differs, substitute your path wherever /opt/mattermost appears.
  • Network connectivity: Each Mattermost server can reach the monitoring server on TCP port 3100 (Loki's HTTP API).
Step 1: Verify Mattermost JSON logging​
Mattermost must be writing JSON-formatted file logs for Loki queries to work. This is the default on all plans — verify it on each application server:
tail -1 /opt/mattermost/logs/mattermost.log
A JSON-formatted line looks like:
{"timestamp":"2025-01-15T14:32:01.123Z","level":"info","msg":"Server is listening on [::]:8065","caller":"app/server.go:482"}
If you see plain-text output instead, go to System Console > Environment > Logging and set Output file logs as JSON to true, then restart Mattermost:
sudo systemctl restart mattermost
Step 2: Install Loki on the monitoring server​
Install Loki on the same server that runs Grafana and Prometheus. All commands in this section are run on the monitoring server.
  1. Create the Loki user, directories, and download the binary:
    # Create a dedicated system user
    sudo useradd --system --no-create-home --shell /bin/false loki
    # Create directories
    sudo mkdir -p /opt/loki/data /opt/loki/bin
    # Download and extract Loki
    sudo apt-get install -y unzip
    cd /tmp
    curl -LO https://github.com/grafana/loki/releases/download/v3.4.2/loki-linux-amd64.zip
    unzip loki-linux-amd64.zip
    sudo mv loki-linux-amd64 /opt/loki/bin/loki
    sudo chmod +x /opt/loki/bin/loki
  2. Download and install the production configuration file:
    sudo cp loki-config.yaml /opt/loki/loki-config.yaml
    Tip
    Log retention is set to 14 days by default. To change this, edit /opt/loki/loki-config.yaml and update the retention_period value under limits_config. Loki requires this value in hours — common values:
    • 336h = 14 days (default)
    • 720h = 30 days
    • 2160h = 90 days
    • 8760h = 365 days
    Longer retention increases disk usage. As a rough guide, expect 1–3 GB per day for a moderately active Mattermost deployment (varies with log volume). Monitor /opt/loki/data/ after the first week to project storage needs. The compactor.retention_enabled setting must remain true for retention enforcement to work.
  3. Set ownership:
    sudo chown -R loki:loki /opt/loki
  4. Create a systemd service file:
    sudo tee /etc/systemd/system/loki.service > /dev/null <<'EOF'
    [Unit]
    Description=Grafana Loki Log Aggregation
    Documentation=https://grafana.com/docs/loki/latest/
    After=network-online.target
    Wants=network-online.target
    [Service]
    Type=simple
    User=loki
    Group=loki
    ExecStart=/opt/loki/bin/loki -config.file=/opt/loki/loki-config.yaml
    Restart=on-failure
    RestartSec=5
    LimitNOFILE=65536
    StandardOutput=journal
    StandardError=journal
    [Install]
    WantedBy=multi-user.target
    EOF
  5. Start Loki:
    sudo systemctl daemon-reload
    sudo systemctl enable --now loki
  6. Verify Loki is running:
    sudo systemctl status loki
    curl -s http://localhost:3100/ready
    The /ready endpoint should return ready. Loki may take 15–20 seconds after startup before it reports ready — this warmup delay is normal.
Step 3: Install OpenTelemetry Collector on each Mattermost server​
The OpenTelemetry (OTel) Collector runs on each Mattermost application server and pushes logs to Loki. Repeat these steps on every Mattermost application server.
  1. Install the OTel Collector Contrib distribution:
    # Add OTel Collector repository and install
    # Commands below are for Ubuntu/Debian
    wget https://github.com/open-telemetry/opentelemetry-collector-releases/releases/download/v0.145.0/otelcol-contrib_0.145.0_linux_amd64.deb
    sudo dpkg -i otelcol-contrib_0.145.0_linux_amd64.deb
    Note
    The installation process automatically creates a system user and group named otelcol-contrib.
  2. Download and edit the OpenTelemetry Collector configuration:
    sudo cp otel-collector-config-mattermost.yaml /etc/otelcol-contrib/config.yaml
    Edit /etc/otelcol-contrib/config.yaml and replace the placeholders:
    • Replace <LOKI_HOST> with your monitoring server's address.
    • Replace <HOSTNAME> with this server's hostname.
    • Replace <SERVICE_NAME> with the service type (e.g., mattermost).
    sudo vi /etc/otelcol-contrib/config.yaml
  3. Grant the collector read access to the Mattermost log directory:
    # Grant the collector access to read Mattermost logs.
    # Substitute 'mattermost' for the group that owns your log file.
    sudo usermod -aG mattermost otelcol-contrib
    # Ensure logs are group-readable
    sudo chmod 640 /opt/mattermost/logs/mattermost.log
    sudo chmod g+rx /opt/mattermost/logs
  4. Restart the service:
    sudo systemctl restart otelcol-contrib
    sudo systemctl enable otelcol-contrib
  5. Verify the collector is running and shipping logs:
    sudo systemctl status otelcol-contrib
    sudo journalctl -u otelcol-contrib -f
Step 4: Add Loki as a data source in Grafana​
  1. Log in to Grafana (default: http://<monitoring-server>:3000).
  2. Navigate to Administration > Data Sources > Add data source.
  3. Select Loki from the list.
  4. Configure the connection:
    • Name: Loki
    • URL: http://localhost:3100 (since Loki is colocated with Grafana)
  5. Select Save & test. Grafana should confirm the data source is working.
Step 5: Import the Mattermost Loki dashboard​
A pre-built Grafana dashboard is recommended for monitoring your logs. This dashboard is provided as a basic example:
The dashboard provides:
  • Log Volume by Level — stacked bar chart showing log rates by severity.
  • Error / Warning / Total counters — stat panels for the selected time range.
  • HTTP 4xx/5xx count — quick visibility into application-level HTTP errors.
  • Error Rate Over Time — time series per instance for spotting error spikes.
  • Top Error Messages — table ranking the most frequent errors.
  • Log Browser — searchable, filterable log panel with level and free-text variables.
To import the dashboard:
  1. In Grafana, go to Dashboards > New > Import.
  2. Select Upload JSON file and choose the downloaded mattermost-loki-logs.json file.
  3. On the import screen, select your Loki data source from the dropdown.
  4. Select Import.
Step 6: Useful LogQL queries​
You can run these queries directly in Grafana Explore (select the Loki data source) or use them to build additional dashboard panels.
Search all Mattermost logs:
{service_name="mattermost"}
Filter by log level:
{service_name="mattermost"} | json | detected_level="error"
Search for all HTTP 4xx responses:
{service_name="mattermost"} | json | status_code >= 400
Search for all HTTP 5xx responses:
{service_name="mattermost"} | json | status_code >= 500
Top 5 error messages over 5-minute windows:
topk(5, sum(count_over_time({service_name="mattermost"} | json | detected_level="error" [5m])) by (msg))
Count errors by message over 5-minute windows:
Free-text search (e.g., plugin errors):
{service_name="mattermost"} |~ "plugin"
Authentication-related log lines:
{service_name="mattermost"} |~ "(?i)(auth|login|token|session)"
Logs from a specific server instance:
{service_name="mattermost", service_instance_id="mm-app-01"}
Optional: Add PostgreSQL log collection​
If your PostgreSQL database runs on a dedicated server (not RDS), you can ship its logs to Loki as well. This is useful for correlating slow queries or database errors with Mattermost application events.
Once running, PostgreSQL logs appear in Grafana under the label &#123;service_name="postgres"&#125;:
{service_name="postgres"} | json | detected_level="error"
Verification and troubleshooting​
End-to-end verification checklist:
  1. Loki is healthy:
    curl -s http://<monitoring-server>:3100/ready
    # Expected: "ready"
  2. OpenTelemetry Collector is shipping logs (run on each Mattermost server):
    sudo journalctl -u otelcol-contrib -n 100
    # Look for export successful messages or lack of errors
  3. Logs are visible in Grafana: Go to Explore, select the Loki data source, and run &#123;service_name="mattermost"&#125;. You should see recent log lines.
  4. The dashboard loads: Open the Mattermost Log Aggregation dashboard and confirm panels are populated. (Note: You may need to update dashboard queries to use service_name and service_instance_id).
Common issues:
SymptomResolution
OTel Col target shows errorsVerify the file paths in the config match the actual log file location. Check file permissions (otelcol-contrib user must be able to read the file).
connection refused on port 3100Ensure Loki is running (systemctl status loki). Check firewall rules: sudo iptables -L -n | grep 3100 or check your AWS security group allows TCP 3100 from the Mattermost servers.
Logs appear in Loki but fields aren't parsedConfirm Mattermost is writing JSON-formatted logs (see Step 1). Check that the json_parser operator (for Postgres) or OTel processors are correctly configured.
/ready returns an errorCheck Loki logs: sudo journalctl -u loki -f. Common cause: permissions on /opt/loki/data/ — ensure the loki user owns the directory.
Old logs are not being deletedVerify compactor.retention_enabled: true and limits_config.retention_period are both set in the Loki config. The compactor runs on the compaction_interval (default: 10 minutes) and applies a retention_delete_delay (default: 2 hours) before actually removing data.
High disk usage on the monitoring serverReview the retention period in the configuration. Consider reducing it or adding more disk. Check du -sh /opt/loki/data/ to see current usage.
