Deploy Grafana Loki for centralized logging
This guide extends your existing Prometheus and Grafana performance monitoring deployment by adding Grafana Loki for centralized log aggregation. While Prometheus collects metrics (CPU, request latency, goroutine counts), Loki collects logs — giving your operations team the ability to search, filter, and correlate Mattermost application logs across all servers from a single Grafana interface.
With Loki in place you can:
- Search Mattermost logs across all application servers from Grafana.
- Filter by log level, HTTP status code, or free-text search.
- Identify the top recurring errors and warnings.
- Correlate log events with Prometheus metric spikes on the same timeline.
- Optionally collect PostgreSQL database logs alongside application logs.
Architecture overview
The deployment adds two components to your monitoring stack:
- Loki — the log aggregation engine, installed on your existing Grafana/Prometheus monitoring server.
- OpenTelemetry Collector — a versatile, industry-standard agent installed on each Mattermost application server to ship logs.
│ Mattermost App 01 │ │ Mattermost App 02 │
│ /opt/mattermost/ │ │ /opt/mattermost/ │
│ logs/mattermost.log│ │ logs/mattermost.log│
│ [ OTel Col ] │ │ [ OTel Col ] │
│ push (:3100/otlp) │
│ Monitoring Server │
│ [ Prometheus :9090 ] [ Loki :3100 ] │
│ [ Grafana :3000 ] │
│ Metrics + Logs │
Optional: Add the OpenTelemetry Collector on your PostgreSQL server to also
ship database logs to Loki.
Prerequisites
Before starting, confirm the following:
- Prometheus and Grafana are deployed and collecting Mattermost metrics per the performance monitoring guide.
- You have SSH access with sudo privileges to the monitoring server and each Mattermost application server.
- Mattermost is installed at
/opt/mattermost(the default location). If your installation path differs, substitute your path wherever/opt/mattermostappears. - Network connectivity: Each Mattermost server can reach the monitoring server on TCP port 3100 (Loki's HTTP API).
Step 1: Verify Mattermost JSON logging
Mattermost must be writing JSON-formatted file logs for Loki queries to work. This is the default on all plans — verify it on each application server:
tail -1 /opt/mattermost/logs/mattermost.log
A JSON-formatted line looks like:
{"timestamp":"2025-01-15T14:32:01.123Z","level":"info","msg":"Server is listening on [::]:8065","caller":"app/server.go:482"}
If you see plain-text output instead, go to System Console > Environment > Logging and set Output file logs as JSON to true, then restart Mattermost:
sudo systemctl restart mattermost
Step 2: Install Loki on the monitoring server
Install Loki on the same server that runs Grafana and Prometheus. All commands in this section are run on the monitoring server.
Create the Loki user, directories, and download the binary:
# Create a dedicated system usersudo useradd --system --no-create-home --shell /bin/false loki# Create directoriessudo mkdir -p /opt/loki/data /opt/loki/bin# Download and extract Lokisudo apt-get install -y unzipcd /tmpcurl -LO https://github.com/grafana/loki/releases/download/v3.4.2/loki-linux-amd64.zipunzip loki-linux-amd64.zipsudo mv loki-linux-amd64 /opt/loki/bin/lokisudo chmod +x /opt/loki/bin/loki -
Download and install the production configuration file:
sudo cp loki-config.yaml /opt/loki/loki-config.yamlTip
Log retention is set to 14 days by default. To change this, edit
/opt/loki/loki-config.yamland update theretention_periodvalue underlimits_config. Loki requires this value in hours — common values:336h= 14 days (default)720h= 30 days2160h= 90 days8760h= 365 days
Longer retention increases disk usage. As a rough guide, expect 1–3 GB per day for a moderately active Mattermost deployment (varies with log volume). Monitor
/opt/loki/data/after the first week to project storage needs. Thecompactor.retention_enabledsetting must remaintruefor retention enforcement to work. -
Set ownership:
sudo chown -R loki:loki /opt/loki -
Create a systemd service file:
sudo tee /etc/systemd/system/loki.service > /dev/null <<'EOF'[Unit]Description=Grafana Loki Log AggregationDocumentation=https://grafana.com/docs/loki/latest/After=network-online.targetWants=network-online.target[Service]Type=simpleUser=lokiGroup=lokiExecStart=/opt/loki/bin/loki -config.file=/opt/loki/loki-config.yamlRestart=on-failureRestartSec=5LimitNOFILE=65536StandardOutput=journalStandardError=journal[Install]WantedBy=multi-user.targetEOF -
Start Loki:
sudo systemctl daemon-reloadsudo systemctl enable --now loki -
Verify Loki is running:
sudo systemctl status lokicurl -s http://localhost:3100/readyThe
/readyendpoint should returnready. Loki may take 15–20 seconds after startup before it reports ready — this warmup delay is normal.
Step 3: Install OpenTelemetry Collector on each Mattermost server
The OpenTelemetry (OTel) Collector runs on each Mattermost application server and pushes logs to Loki. Repeat these steps on every Mattermost application server.
Install the OTel Collector Contrib distribution:
# Add OTel Collector repository and install# Commands below are for Ubuntu/Debianwget https://github.com/open-telemetry/opentelemetry-collector-releases/releases/download/v0.145.0/otelcol-contrib_0.145.0_linux_amd64.debsudo dpkg -i otelcol-contrib_0.145.0_linux_amd64.debNote
The installation process automatically creates a system user and group named
otelcol-contrib. -
Download and edit the OpenTelemetry Collector configuration:
sudo cp otel-collector-config-mattermost.yaml /etc/otelcol-contrib/config.yamlEdit
/etc/otelcol-contrib/config.yamland replace the placeholders:- Replace
<LOKI_HOST>with your monitoring server's address. - Replace
<HOSTNAME>with this server's hostname. - Replace
<SERVICE_NAME>with the service type (e.g.,mattermost).
sudo vi /etc/otelcol-contrib/config.yaml - Replace
Grant the collector read access to the Mattermost log directory:
# Grant the collector access to read Mattermost logs.# Substitute 'mattermost' for the group that owns your log file.sudo usermod -aG mattermost otelcol-contrib# Ensure logs are group-readablesudo chmod 640 /opt/mattermost/logs/mattermost.logsudo chmod g+rx /opt/mattermost/logs -
Restart the service:
sudo systemctl restart otelcol-contribsudo systemctl enable otelcol-contrib -
Verify the collector is running and shipping logs:
sudo systemctl status otelcol-contribsudo journalctl -u otelcol-contrib -f
Step 4: Add Loki as a data source in Grafana
- Log in to Grafana (default:
http://<monitoring-server>:3000). - Navigate to Administration > Data Sources > Add data source.
- Select Loki from the list.
- Configure the connection:
- Name:
Loki - URL:
http://localhost:3100(since Loki is colocated with Grafana)
- Name:
- Select Save & test. Grafana should confirm the data source is working.
Step 5: Import the Mattermost Loki dashboard
A pre-built Grafana dashboard is recommended for monitoring your logs. This dashboard is provided as a basic example:
The dashboard provides:
- Log Volume by Level — stacked bar chart showing log rates by severity.
- Error / Warning / Total counters — stat panels for the selected time range.
- HTTP 4xx/5xx count — quick visibility into application-level HTTP errors.
- Error Rate Over Time — time series per instance for spotting error spikes.
- Top Error Messages — table ranking the most frequent errors.
- Log Browser — searchable, filterable log panel with level and free-text variables.
To import the dashboard:
- In Grafana, go to Dashboards > New > Import.
- Select Upload JSON file and choose the downloaded
mattermost-loki-logs.jsonfile. - On the import screen, select your Loki data source from the dropdown.
- Select Import.
Step 6: Useful LogQL queries
You can run these queries directly in Grafana Explore (select the Loki data source) or use them to build additional dashboard panels.
Search all Mattermost logs:
{service_name="mattermost"}
Filter by log level:
{service_name="mattermost"} | json | detected_level="error"
Search for all HTTP 4xx responses:
{service_name="mattermost"} | json | status_code >= 400
Search for all HTTP 5xx responses:
{service_name="mattermost"} | json | status_code >= 500
Top 5 error messages over 5-minute windows:
topk(5, sum(count_over_time({service_name="mattermost"} | json | detected_level="error" [5m])) by (msg))
Count errors by message over 5-minute windows:
Free-text search (e.g., plugin errors):
{service_name="mattermost"} |~ "plugin"
Authentication-related log lines:
{service_name="mattermost"} |~ "(?i)(auth|login|token|session)"
Logs from a specific server instance:
{service_name="mattermost", service_instance_id="mm-app-01"}
Optional: Add PostgreSQL log collection
If your PostgreSQL database runs on a dedicated server (not RDS), you can ship its logs to Loki as well. This is useful for correlating slow queries or database errors with Mattermost application events.
Once running, PostgreSQL logs appear in Grafana under the label {service_name="postgres"}:
{service_name="postgres"} | json | detected_level="error"
Verification and troubleshooting
End-to-end verification checklist:
Loki is healthy:
curl -s http://<monitoring-server>:3100/ready# Expected: "ready" -
OpenTelemetry Collector is shipping logs (run on each Mattermost server):
sudo journalctl -u otelcol-contrib -n 100# Look for export successful messages or lack of errors -
Logs are visible in Grafana: Go to Explore, select the Loki data source, and run
{service_name="mattermost"}. You should see recent log lines. -
The dashboard loads: Open the Mattermost Log Aggregation dashboard and confirm panels are populated. (Note: You may need to update dashboard queries to use
service_nameandservice_instance_id).
Common issues:
| Symptom | Resolution |
| OTel Col target shows errors | Verify the file paths in the config match the actual log file location. Check file permissions (otelcol-contrib user must be able to read the file). |
connection refused on port 3100 | Ensure Loki is running (systemctl status loki). Check firewall rules: sudo iptables -L -n | grep 3100 or check your AWS security group allows TCP 3100 from the Mattermost servers. |
| Logs appear in Loki but fields aren't parsed | Confirm Mattermost is writing JSON-formatted logs (see Step 1). Check that the json_parser operator (for Postgres) or OTel processors are correctly configured. |
/ready returns an error | Check Loki logs: sudo journalctl -u loki -f. Common cause: permissions on /opt/loki/data/ — ensure the loki user owns the directory. |
| Old logs are not being deleted | Verify compactor.retention_enabled: true and limits_config.retention_period are both set in the Loki config. The compactor runs on the compaction_interval (default: 10 minutes) and applies a retention_delete_delay (default: 2 hours) before actually removing data. |
| High disk usage on the monitoring server | Review the retention period in the configuration. Consider reducing it or adding more disk. Check du -sh /opt/loki/data/ to see current usage. |
