Set server connection details
  1. (Optional) Enter Server Username used to access the enterprise search server.
  2. (Optional) Enter Server Password associated with the username.
  3. Set Enable Cluster Sniffing (Optional). Sniffing finds and connects to all data nodes in your cluster automatically.
Warning
Do not enable cluster sniffing when using cloud-hosted search providers such as Elastic Cloud or Amazon OpenSearch Service. Cloud providers typically hide search cluster nodes behind a proxy, so sniffed node addresses may be unreachable from your network. The provider handles connection pooling for you, making sniffing unnecessary and potentially disruptive.
  1. Optional CA and client certificate configuration settings are available for use with basic authentication credentials or to replace them. See the Enterprise search configuration settings documentation for details.
  2. Select Test Connection and then select Save. If the server connection is unsuccessful you won’t be able to save the configuration or enable searching with Elasticsearch or AWS OpenSearch.
Note
From Mattermost v11, enterprise search server connections are tested during Support Packet generation. Any connection errors encountered during Support Packet generation are automatically included in the packet to help diagnose configuration issues.
Build the post index of existing messages
Select Index Now. This process can take up to a few hours depending on the size of the post database and number of messages. The progress percentage can be seen as the index is created. To avoid downtime, set Enable Elasticsearch for search queries to false so that database search is available during the indexing process.
