SAML Single Sign-On: technical documentation
Security Assertion Markup Language (SAML) is an open standard that allows identity providers (IdP), like OneLogin, to pass authorization credentials to service providers (SP), like Mattermost.
In simpler terms, it means you can use one set of credentials to log in to many different sites. With a SAML identity provider account, you can log in to Mattermost and other sites securely with the same account.
The main benefit is that it helps administrators centralize user management by controlling which sites users have access to with their SAML identity provider credentials.
Mattermost supports using a single metadata URL to retrieve configuration information for the Identity Provider using your single sign-on URL to generate an IdP metadata URL. The IdP metadata XML file contains the IdP certificate, the entity ID, the redirect URL, and the logout URL.
Using this URL populates the SAML SSO URL and the Identity Provider Issuer URL fields in the configuration process automatically and the Identity Provider Public Certificate is also downloaded from the server and set locally.
This is currently supported for Okta and Microsoft ADFS server 2012 and 2016.
For detailed steps, view the Configure SAML with Okta, Configure SAML with Microsoft ADFS for Windows Server 2012, and Configure SAML with Microsoft ADFS using Microsoft Windows Server 2016 documentation. See the supported SAML encryption methods in the authentication configuration settings documentation.
SAML providers​
Identity Providers (IdP): An identity provider performs the authentication. When a user clicks to log in, the identity provider confirms who the user is, and sends data to the service provider with the proper authorization to access the site.
Examples: OneLogin, Okta, Microsoft Active Directory (ADFS) or Azure.
Service Providers (SP): A service provider gets authentication and authorization information from an IdP. Once received, it gives the user access to the system and logs the user in.
Examples: Mattermost, Zendesk, Zoom, Salesforce.
SAML request (AuthNRequest)​
When Mattermost initiates an SP-initiated SAML request flow, it generates a HTTP-Redirect binding request to the IdP that contains an XML payload as a base64 string
bM441nuRIzAjKeMM8RhegMFjZ4L4xPBHhAfHYqgnYDQnSxC++Qn5IocWuzuBGz7JQmT9C57nxjxgbFIatiqUCQN17aYrLn/mWE09C5mJMYlcV68ibEkbR/JKUQ+2u/N+mSD4/C/QvFvuB6BcJaXaz0h7NwGhHROUte6MoGJKMPE=
AuthNRequests can also be signed by Mattermost, in which case the XML payload is similar to:
<samlp:AuthnRequest xmlns:samlp="urn:oasis:names:tc:SAML:2.0:protocol" xmlns:saml="urn:oasis:names:tc:SAML:2.0:assertion" xmlns:samlsig="https://www.w3.org/2000/09/xmldsig#" ID="_u5mpjadp1fdozfih4cj8ap4brh" Version="2.0" ProtocolBinding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" AssertionConsumerServiceURL="http://localhost:8065/login/sso/saml" IssueInstant="2019-06-08T16:00:31Z">
<saml:Issuer xmlns:saml="urn:oasis:names:tc:SAML:2.0:assertion">https://www.okta.com/exkoxukx1D8OIfY03356</saml:Issuer>
<samlsig:Signature Id="Signature1">
<samlsig:SignedInfo>
<samlsig:CanonicalizationMethod Algorithm="https://www.w3.org/2001/10/xml-exc-c14n#"></samlsig:CanonicalizationMethod>
<samlsig:SignatureMethod Algorithm="https://www.w3.org/2000/09/xmldsig#rsa-sha256"></samlsig:SignatureMethod>
<samlsig:Reference URI="#_u5mpjadp1fdozfih4cj8ap4brh">
<samlsig:Transforms>
<samlsig:Transform Algorithm="https://www.w3.org/2000/09/xmldsig#enveloped-signature"></samlsig:Transform>
</samlsig:Transforms>
<samlsig:DigestMethod Algorithm="https://www.w3.org/2000/09/xmldsig#sha256"></samlsig:DigestMethod>
<samlsig:DigestValue></samlsig:DigestValue>
</samlsig:Reference>
</samlsig:SignedInfo>
<samlsig:SignatureValue></samlsig:SignatureValue>
<samlsig:KeyInfo>
<samlsig:X509Data>
<samlsig:X509Certificate>MIIFmzCCA4OgAwIBAgIJAIusvV3gZIwiMA0GCSqGSIb3DQEBCwUAMGIxCzAJBgNVBAYTAlVTMRIwEAYDVQQHDAlQYWxvIEFsdG8xEzARBgNVBAoMCk1hdHRlcm1vc3QxDzANBgNVBAsMBkRldk9wczEZMBcGA1UEAwwQYmFzZS5leGFtcGxlLmNvbTAeFw0xOTA2MDcxMjQ0MTdaFw0yOTA2MDQxMjQ0MTdaMGIxCzAJBgNVBAYTAlVTMRIwEAYDVQQHDAlQYWxvIEFsdG8xEzARBgNVBAoMCk1hdHRlcm1vc3QxDzANBgNVBAsMBkRldk9wczEZMBcGA1UEAwwQYmFzZS5leGFtcGxlLmNvbTCCAiIwDQYJKoZIhvcNAQEBBQADggIPADCCAgoCggIBALAfDj+RyByszTOPRL4b+cilNF/3PB1I0CG3TNzgllgy5CwRGHLKn5/t8rPsJoWLKOUGenzVdXWuoVi3jyl5FZ1N60CBbXfmSWk20dSIkcYCcYEgs1BTBqKKYFw2dV4M0oppzNtlq7A0Glpg/gpaR/2TXEPAhOsUfORC2qAdJt9ev0AQjp5V0TkIKMZz8oo33Coi38TG5r/LG+ihRbpWzO7j9Rc2S5I6bczvG4wOg7nVKG+B5XBvuU9PjSqgxpd/F/fYf+ggAEru58E+VM4veCRV8vSPbBqDG4FMPV6DiA+tH/70n6zuPCS3soxX00kjKtP80QD6UgzvM2NN7PHiNlf0Zj6VCU3VdjEnypg7dzlHJuyyaAaTD5nSfkecamEoJpq7kaUB7uTmBHELRUhOOy24f54HnP72vnxicZL8cWsOkJwQAqIGzBxQ7J0uX4Os71WrV2YIur8QVk6KN6MBPxfiCh3xO/R+cycgx0aMrWZoyzOzP7NCTM5MNE41C48xeGviyCtUID4xiBow+xo6IDUaiCoUVJhz579ore8ic70a19DD0qHy4SpBvrUwCO54kvkgn6HjYlLC/k8nFM9F9W9wVAQD/QwIjd7EtLZLGgbU61Jv3q4kZxxq270hogCRY0lmI3RxkedGHhetF7kaizrikW5zJQEeido/ir37HhX5AgMBAAGjVDBSMBIGA1UdEwEB/wQIMAYBAf8CAQAwPAYDVR0RBDUwM4IQbG9ncy5leGFtcGxlLmNvbYITbWV0cmljcy5leGFtcGxlLmNvbYcEwKgAAYcEfwAAATANBgkqhkiG9w0BAQsFAAOCAgEAH1O91BABHXZjrU7v1OwG+GbU/4TYZqBXXNxax++OFSRCkEEoNKGg49R6J7lY4lrm12zBlw+oGSyjIOerzi39/dcxDkKpzyhGvEN4mExbDlybmdCVrHPeWgZl7uwqn4Bj1xiu97M6eMthgxJE7KVNDGDHthGL0/fTlONIh3qS7Far33hLHJJKy3+lC1MDB8cNltV3mf/ctHCx5Wa0bfZId0MJgd/seP0WU1HCf3kIxhnhsnOYs32xu7EGiM4/lgnquVd/q/f99ueSaDSHrep373/w2ce9iF3U0qcLd2iP8ayF/daGeW1dVPL9R10Oe4BpRjMkjlLwhZdjJeKSg9GBa2GXUEn1Ru9vpSw/C10no3Qx/6ZHweYbSmJ6hBg4T0nDBp6iVS1eQULNXxDuDWb26U0ESOO5jK8ATywuc45o0bqdvD1XOrGYGfGnofx7ofRWwKHWfltvxurnbsyo2vH6nM6K41K2DpVdyQOKAGvKe/oCWfdi+WyBQJGWcIp2OTC1XyWHv7JsY3lo04+islkHEcqJyd8Rf8GWmRHdXz0WzGiZbxWzAuvRRWnzM31VAws8kQBHTBwIJlJoGX4AXfEvPi+NTxkntf8cQdJucK9ZZbP4ycXHULO4LneyJoJ9Q7nxX11xWv7BDWxxclOXy6tyUkg9Fjb7pQ/HCVvGhRzilVU=</samlsig:X509Certificate>
</samlsig:X509Data>
</samlsig:KeyInfo>
</samlsig:Signature>
</samlp:AuthnRequest>
SAML responses​
There are different types of SAML responses sent by the IdP to the SP. The response contains the Assertion with the NameID and attributes of a user.
Below is a table of the different types of responses. Each response type is fully supported except when the SAML assertion is signed while the SAML response itself is not:
Signed SAML ResponseSigned SAML AssertionEncrypted SAML AssertionSupported by Mattermost
YesYesYesYes
YesYesNoYes
YesNoYesYes
YesNoNoYes
NoYesYesPartially, validation of assertion signature not supported
NoYesNoPartially, validation of assertion signature not supported
NoNoYesYes
NoNoNoYes
For example XML responses for each type, see the OneLogin SAML response examples.
Technical description of SAML synchronization with AD/LDAP​
When enabled, SAML synchronization with AD/LDAP occurs in phases:
  1. Get all the current LDAP users from the Mattermost database who have Users.AuthService set to ldap. This is a SQL query issued against the Mattermost database: SELECT * FROM Users WHERE AuthService = 'ldap'.
  2. Get all the current SAML users from the Mattermost database who have Users.AuthService set to saml. This is a SQL query issued against the Mattermost database: SELECT * FROM Users WHERE AuthService = 'saml'.
  3. Get all the current LDAP users from the LDAP server as defined by LdapSettings.UserFilter. This is an LDAP query issued against the LDAP server. Users are retrieved in batches as defined by LdapSettings.MaxPageSize.
  4. Update LDAP attributes. For each existing Mattermost user retrieved in step 1, attempt to find a match against the list of LDAP users from step 3. To find matches, Users.AuthData field of the Mattermost user is compared against the LdapSettings.IdAttribute LDAP setting.
  • If any attribute of the user has changed, that attribute is copied from the LDAP server and the user is marked as updated.
  • If the corresponding LdapSettings.IdAttribute is not found, the user is assumed to be deleted from the LDAP server, and deactivated from Mattermost by setting the Users.DeleteAt field to a valid timestamp.
  1. Update SAML attributes. For each existing Mattermost user retrieved in step 2, attempt to find a match against the list of LDAP users from step 3. To find matches, SamlSettings.Email is compared against the LdapSettings.EmailAttribute LDAP setting.
  • If the corresponding LdapSettings.EmailAttribute is not found, the user is assumed to be deleted from the LDAP server, and deactivated from Mattermost by setting the Users.DeleteAt field to a valid timestamp.
Frequently Asked Questions​
How can I obtain a SAML metadata XML file consumed by Mattermost?​
You can obtain the XML file by calling the Mattermost RESTful API endpoint at /api/v4/saml/metadata.
For other useful SAML API calls, see the API reference.
Can I update user attributes using the API?​
No. When Mattermost is configured to use SAML for user authentication, the following user attribute changes can't be made through the API: first name, last name, position, nickname, email, profile image, or username. SAML must be the authoritative source for these user attributes.
Why does the ObjectGUID of a user in Mattermost differ from what I'm seeing in ADFS?​
The Active Directory Object-Guid attribute (LDAP display name objectGUID) is a 16 byte array which can be displayed in different ways. However, only Microsoft changes the encoding of the ObjectGUID. All the others keep it the same except for the different base (octal, decimal, hex), as follows:
  1. The ldapsearch linux command displays it as base 64: Hrz/HqNKnU+lCNTYHx9Ycw==. This is also the format used in LDIF files.
  2. The LDAP Golang package Mattermost uses emits the value as hexidecimal (base 16) array, with each byte separated by a backslash: \1e\bc\ff\1e\a3\4a\9d\4f\a5\08\d4\d8\1f\1f\58\73
  • You can remove the backslashes (1ebcff1ea34a9d4fa508d4d81f1f5873) and parse it with Golang like this. The snippets prints the base 10 representation of each value: [30 188 255 30 163 74 157 79 165 8 212 216 31 31 88 115]
  1. Windows Powershell displays the value like this: 1effbc1e-4aa3-4f9d-a508-d4d81f1f5873
Does relaystate need to be passed back to the client from the identity provider?​
Yes. If you're integrating Mattermost with a provider that doesn't already do so by default, ensure that relaystate is enabled. See the PingIdentity SAML RelayState documentation for details.
How can I troubleshoot the SAML logon process?​
The most useful tool that we've found for troubleshooting SAML connection issues is the SAML Chrome Panel Chrome extension. We're not aware of similar tools for other browsers, but this tool justifies installing Chrome!
