Configure SAML synchronization with AD/LDAP
    If you don’t want to enable AD/LDAP sign-in, go to System Console > Authentication > AD/LDAP wizard, navigate to the Connection Settings section, then set Enable sign-in with AD/LDAP to false.
Once the synchronization with AD/LDAP is enabled, user attributes are synchronized with AD/LDAP based on their email address. If a user with a given email address doesn’t have an AD/LDAP account, they will be deactivated in Mattermost on the next AD/LDAP sync.
To re-activate the account:
Note
  • If a user is deactivated from AD/LDAP, they will be deactivated in Mattermost on the next sync. They will be shown as “Deactivated” in the System Console users list, all of their sessions will expire and they won’t be able to log back in to Mattermost.
  • If a user is deactivated from SAML, their session won’t expire until they’re deactivated from AD/LDAP. However, they won’t be able to log back in to Mattermost.
  • SAML synchronization with AD/LDAP is designed to pull user attributes such as first name and last name from your AD/LDAP, not to control authentication. In particular, the user filter cannot be used to control who can log in to Mattermost, this should be controlled by your SAML service provider’s group permissions.
