Configure SAML synchronization with AD/LDAP
- Mattermost queries AD/LDAP for relevant account information and updates SAML accounts based on changes to attributes (first name, last name, and nickname)
- Accounts disabled in AD/LDAP are deactivated in Mattermost, and their active sessions are revoked once Mattermost synchronizes attributes.
Go to System Console > Authentication > SAML 2.0, then set Enable Synchronizing SAML Accounts With AD/LDAP to true.
Go to System Console > Authentication > AD/LDAP to open the AD/LDAP wizard, navigate to the Connection Settings section, then set Enable Synchronization with AD/LDAP to true.
To ignore guest users when sychronizing, go to System Console > Authentication > SAML 2.0, then set Ignore Guest Users when Synchronizing with AD/LDAP to true.
Set the rest of the AD/LDAP settings based on configuration settings documentation to connect Mattermost with your AD/LDAP server.
To specify how often Mattermost synchronizes SAML user accounts with AD/LDAP, go to System Console > Authentication > AD/LDAP wizard, navigate to the Sync Performance section, then set a Synchronization Interval in minutes. The default setting is 60 minutes. If you want to synchronize immediately after disabling an account, go to the Sync History section and select AD/LDAP Synchronize Now.
To confirm that Mattermost can successfully connect to your AD/LDAP server, go to System Console > Authentication > AD/LDAP wizard, navigate to the Connection Settings section, then select Test Connection.
To re-activate the account:
- Add the user to your AD/LDAP server.
- Purge all caches in Mattermost by going to System Console > Environment > Web Server, then select Purge All Caches.
- Run AD/LDAP synchronization by going to System Console > Authentication > AD/LDAP wizard, navigating to the Sync History section, then select AD/LDAP Synchronize Now.
- Purge all caches again in Mattermost by going to System Console > Environment > Web Server, then select Purge All Caches again. This re-activates the account in Mattermost.
- Set the SAML
Id Attributeby going to System Console > Authentication > SAML 2.0 > Id Attribute. - Set System Console > Authentication > SAML 2.0 > Override SAML bind data with AD/LDAP information to true.
- Set System Console > Authentication > SAML 2.0 > Enable Synchronizing SAML Accounts With AD/LDAP to true.
- Run AD/LDAP sync by going to System Console > Authentication > AD/LDAP wizard, navigating to the Sync History section, then select AD/LDAP Synchronize Now.
