Configure SAML with Microsoft Entra ID
This page provides guidance on configuring SAML with Microsoft Entra ID for Mattermost.
Prerequisites​
  • A Microsoft Entra tenant containing applicable user data.
  • A verified custom domain for your tenant. See Microsoft's Add your custom domain name to your tenant documentation for details.
  • A Microsoft Entra ID P1 or P2 license.
  • An account with at least the Application Administrator role in your Entra tenant.
Set up an enterprise app for Mattermost SSO in Entra ID​
  1. Sign in to the Microsoft Entra admin center with an account that has at least the Application Administrator role.
  2. In the left navigation menu, select Entra ID > Enterprise applications.
  3. Select + New application.
  4. Select + Create your own application.
  5. In the What's the name of your app? field, enter Mattermost.
  6. Under What are you looking to do with your application?, select Integrate any other application you don't find in the gallery (Non-gallery).
  7. Select Create. Entra provisions the application; this may take a few seconds.
  8. In the Mattermost enterprise application settings, select Manage > Users and groups, then assign the approved users and/or groups that should have access to Mattermost.
  9. In the Mattermost enterprise application settings, select Manage > Single sign-on, then select SAML under Select a single sign-on method.
  10. Select Edit in the Basic SAML Configuration section, then set the fields below and select Save:
    • Identifier (Entity ID): https://<your-mattermost-url>
    • Reply URL (Assertion Consumer Service URL): https://<your-mattermost-url>/login/sso/saml
    • Sign on URL: https://<your-mattermost-url>/login
  11. Select Edit in the Attributes & Claims section, then configure the required claim and additional claims as described below.
    How Entra claims map to Mattermost
    The SAML assertion Entra sends to Mattermost contains a set of claims — name/value pairs describing the user. Mattermost reads these claims based on the attribute names you configure in System Console > Authentication > SAML 2.0 > Attributes (for example, Email Attribute, Username Attribute, First Name Attribute).
    The Claim name you set in Entra must match the value you enter in the corresponding Mattermost attribute field exactly, character for character. The Value (also called Source attribute) tells Entra which user property to send — for example, user.mail sends the user's email address.
    a. Required claim — Unique User Identifier (Name ID)
    Set the Name identifier format and Source attribute values as required for your environment. The Name ID is part of the SAML assertion, but Mattermost account binding is controlled by the Id Attribute (SAML) setting if you configure it, or by email otherwise. If you want immutable user binding in Mattermost, add a separate Id claim under Additional claims and set its Value (source attribute) to an immutable Entra attribute such as user.objectid. user.userprincipalname is also a common choice for Name ID when a human-readable identifier is preferred, with the trade-off that renames in Entra can orphan the corresponding Mattermost account if you rely on it for identity matching.
    b. Additional claims
    By default, Entra populates this section with four claims using the http://schemas.xmlsoap.org/ws/2005/05/identity/claims/... namespace. These work, but we recommend replacing them with short, readable names that match the attribute fields in Mattermost. To edit a claim, select it, update the Name field (and clear the Namespace field), then save.
    The following claim configuration covers a typical Mattermost setup (using the clear-namespace option):
    Mattermost attribute fieldEntra claim nameEntra source attribute
    Email Attributeemailuser.mail
    Username Attributeusernameuser.mailnickname
    First Name Attributefirstnameuser.givenname
    Last Name Attributelastnameuser.surname
    Position Attributepositionuser.jobtitle
    After editing, your Attributes & Claims page should look similar to the screenshot below:
    Entra Attributes &amp; Claims page showing simplified claim names
    The Guest, Admin, Nickname, and Preferred Language attributes are also configurable in Mattermost if you want to drive them from Entra. Use the same pattern: pick a short claim name in Entra, set its source attribute, and enter the matching claim name in the corresponding Mattermost attribute field.
  12. Select Edit in the SAML Certificates section. Select Sign SAML response and assertion for Signing Option and SHA-256 for Signing Algorithm, then select Save.
  13. Select the Certificate (Base64) Download link in the SAML Certificates section. This is the Identity Provider Public Certificate to be uploaded to Mattermost.
  14. In the Mattermost enterprise application settings, select Security > Token encryption. Select Import Certificate to import the Service Provider certificate. If you used the Bash script referenced in the Before you begin section, this is the mattermost-x509.crt file. The Import dialog says to upload a certificate with a file extension .cer, but .crt files are also accepted. Upload the file then select Add.
  15. Select the ... to the right of the imported certificate details, select Activate token encryption certificate, then select Yes to activate.
  16. Copy the Tenant ID for use in the Mattermost SAML 2.0 URL settings.
    To find the Tenant ID, select Entra ID from the admin center home, then locate the Tenant ID value in the Basic information panel on the Overview page.
    Where to find the Tenant ID
  17. Copy the Application ID for use in the Identity Provider Metadata URL setting in the Mattermost SAML 2.0 settings.
    To find the Application ID, select Entra ID > Enterprise applications from the left navigation menu, select the Mattermost application, then copy the Application ID from the Properties page (shown alongside the Object ID, which is not needed).
Configure SAML Sign-On for Mattermost​
  1. In the Mattermost System Console, select Authentication > SAML 2.0.
  2. Set Enable Login With SAML 2.0 to True.
  3. Set Identity Provider Metadata URL: https://login.microsoftonline.com/<your-tenant-id>/federationmetadata/2007-06/federationmetadata.xml?appid=<your-app-id>
  4. Select Get SAML Metadata From IdP to verify that the SAML metadata can be retrieved successfully.
  5. Set SAML SSO URL: https://login.microsoftonline.com/<your-tenant-id>/saml2
  6. Set Identity Provider Issuer URL (trailing slash is required): https://sts.windows.net/<your-tenant-id>/
  7. Choose the Identity Provider Public Certificate file from step 13 of Set up an enterprise app for Mattermost SSO in Entra ID then upload.
  8. Set Verify Signature to True.
  9. Set Service Provider Login URL: https://<your-mattermost-url>/login/sso/saml
  10. Set Service Provider Identifier: https://<your-mattermost-url>
  11. Set Enable Encryption to True.
  12. Choose your Service Provider Private Key file then upload. If you used the Bash script referenced in the Before you begin section, this is the mattermost-x509.key file.
  13. Choose your Service Provider Public Certificate then upload. If you used the Bash script referenced in the Before you begin section, this is the mattermost-x509.crt file.
  14. Set Sign Request to True if you want Mattermost to sign outbound AuthnRequests sent to Entra ID — this is distinct from Entra signing its SAML responses and assertions (configured in step 12 of the Entra setup). If enabled, set Signature Algorithm to RSAwithSHA256 (Entra ID requires RSA-SHA256 for signed requests) and upload Mattermost's public certificate to Entra ID for request verification: in the enterprise application, select SAML Certificates, then upload the mattermost-x509.crt file under Verification certificates.
  1. Set attribute settings to match the attributes configured in step 11 of the Set up an enterprise app for Mattermost SSO in Entra ID section. Each value must match the full claim name sent in the assertion, including the namespace, exactly. See the important note under step 11 for details and a common failure mode.
  2. Set the Login Button Text to suit your environment.
  3. Select the Save button.
To re-activate the account:
Override SAML data with AD/LDAP data​
What encryption options are supported for SAML?​
How to bind authentication to Id attribute instead of email​
Why does login fail with "one of the attributes is incorrect" / "<attribute> attribute is missing"?​
To resolve this:
Can SAML via Microsoft ADFS be configured with Integrated Windows Authentication (IWA)?​
Can I provision and deprovision users who log in via SAML?​
How do I migrate users from one authentication method (e.g. email) to SAML?​
How is SAML different from OAuth 2.0 and OpenId Connect?​
