GitLab Single Sign-On
Configuring GitLab as a Single Sign-On (SSO) service​
Follow these steps to configure Mattermost to use GitLab as a Single Sign-on (SSO) service for team creation, account creation, and user login.
Step 1: Add a Mattermost application to your GitLab account​
  1. Log in to your GitLab account, then go to https://{gitlab-site-name}/profile/applications. For {gitlab-site-name} use the name of your GitLab instance. If you're using GitLab itself as your service provider, use gitlab.com.
  2. Add a new application:
  1. In the Name field, enter Mattermost.
  2. In the Redirect URI field, add the following two lines using your own value for {mattermost-site-name}.
https://{mattermost-site-name}/login/gitlab/complete
https://{mattermost-site-name}/signup/gitlab/complete
If your GitLab instance is not set up to use SSL, your URIs must begin with http:// instead of https://.
  1. Select scopes.
    • For Mattermost Team Edition, select read_user.
    • For Mattermost Enterprise, select read_user, openid, profile, and email.
  1. Select Save application.
  2. Keep the GitLab window open. You need the Application Id and Application Secret Key when you configure Mattermost.
Step 2: Configure Mattermost for GitLab SSO​
  1. Log in to Mattermost, then go to System Console > Authentication > OpenID Connect.
  2. Select GitLab as the service provider.
  3. Enter the GitLab Site URL of your GitLab instance. If your GitLab instance is not set up to use SSL, start the URL with http:// instead of https://. If you are using GitLab itself as your provider, use gitlab.com.
  4. The Discovery Endpoint for OpenID Connect with GitLab is prepopulated with https://gitlab.com/.well-known/openid-configuration.
  5. Paste the Application ID from GitLab as the Client ID in Mattermost.
  6. Paste the Application Secret Key from GitLab as the Client Secret in Mattermost.
  7. Update the config.json file and specify the scopes you selected in GitLab under the GitLabSettings property. At a minimum, openid is a required scope for Mattermost Enterprise and Professional, and read_user is a required scope for Mattermost Team Edition. Mattermost Team Edition does not work with scopes other than read_user. Changes to this setting require a server restart before taking effect.
  8. Select Save.
(Optional) Step 3: Force users to sign up using SSO only​
To force all users to sign-up with SSO only, set System Console > Authentication > Email > Enable sign-in with email to false Users must change their login method before they can log in to Mattermost with GitLab.
Frequently Asked Questions​
How can I use LDAP attributes or Groups with OpenID?​
At this time, LDAP data isn't compatible with OpenID. If you currently rely on LDAP to manage your users' teams, channels, groups, or attributes, you won't be able to do this automatically with users who have logged in with OpenID. If you need LDAP synced to each user, we suggest using SAML or LDAP as the login provider. Some OpenID providers can use SAML instead, like Keycloak.
