Multi-factor authentication
Multi-factor authentication (MFA) is a secondary layer of user authentication applied to your Mattermost server that applies to all users on all teams within your Mattermost workspace.
With MFA enabled, users need to provide a secure one-time code in addition to their username and password in order to log in to Mattermost. MFA is useful in organizations that have specific security and compliance policies. It can also be used in organizations where Mattermost is not behind a firewall and doesn't have access to existing MFA infrastructure.
Mattermost offers a smartphone-based MFA check in addition to email-password or Active Directory/LDAP authentication to log in to the Mattermost server.
Supported devices include iOS, Android, or other devices that are able to install a software-based authenticator such as FreeOTP, Google Authenticator, Microsoft Authenticator, 1Password, LastPass, or a similar app. After the app is installed, the device does not require internet access.
Enabling MFA​
System admins can enable this option by going to System Console > Authentication > MFA, then setting Enable Multi-factor Authentication to true.
Once enabled, users can choose to set up multi-factor authentication on their account by selecting Profile > Security > Multi-factor Authentication from their profile picture.
Disabling MFA​
System admins can disable this option by going to System Console > Authentication > MFA. When Enable Multi-factor Authentication is set to false, users can't opt to use or disable multi-factor authentication on their account via Profile > Security > Multi-factor Authentication.
MFA can be disabled for user accounts using the API. See the Mattermost API Reference for details.
Enforcing MFA​
Admins can fulfill Multi-Factor Authentication (MFA) compliance requirements by enforcing an MFA requirement for login with email and LDAP accounts. Go to System Console > Authentication > MFA, then set Enforce Multi-factor Authentication to true.
When MFA enforcement is set to true, users with email or LDAP authentication who don't have MFA set up will be directed to the MFA setup page when they log in to Mattermost. They will not be able to access the site until MFA setup is complete. Any new users will be required to set up MFA during the sign up process.
Users will not be able to remove MFA from their account while enforcement is on.
