Migrate from GitLab Omnibus to standalone Mattermost
Overview
GitLab has announced the deprecation of Mattermost from the GitLab Omnibus package with GitLab 19.0. As part of this transition, GitLab will continue to support Mattermost up to version 10.11 ESR within the Omnibus installation until the final removal date.
To ensure continuity and long-term support, organizations using Mattermost within GitLab Omnibus should plan to migrate to a standalone Mattermost installation. This approach provides ongoing access to the latest Mattermost releases, security updates, and enterprise capabilities independent of GitLab’s release cycle.
Migrating to a standalone deployment also enables greater flexibility in managing infrastructure, upgrading PostgreSQL, and scaling Mattermost independently to meet performance and compliance requirements.
Prerequisites
Before you begin:
  • Administrative (root or sudo) access to the GitLab Omnibus server.
  • A new standalone PostgreSQL server prepared and accessible.
  • Sufficient disk space for the Mattermost database dump.
  • A planned maintenance window, as Mattermost downtime is required.
  • A current full backup of your Mattermost instance, including database and file storage.
Migration Steps
Follow the steps below to safely migrate from GitLab Omnibus to a standalone Mattermost installation.
Step 1: Create a Database Dump from GitLab Omnibus
Use the GitLab Omnibus PostgreSQL tools to create a dump of the Mattermost database. Run this command on the GitLab server:
sudo gitlab-psql -- /opt/gitlab/embedded/bin/pg_dump -h /var/opt/gitlab/postgresql --no-owner mattermost_production | gzip > mattermost_dbdump_$(date --rfc-3339=date).sql.gz
This will create a compressed SQL dump file of your Mattermost database.
Step 2: Prepare the New PostgreSQL Server
Set up your new PostgreSQL server following the official Mattermost database preparation guidelines. This includes:
  • Installing the correct PostgreSQL version supported by your Mattermost server.
  • Creating a new Mattermost database and user with appropriate permissions.
Step 3: Transfer and Restore the Database Dump
Transfer the database dump file to your new PostgreSQL server, then restore it:
zcat /tmp/mattermost_dbdump.sql.gz | psql -U mmuser -d mattermost
Verify that the database restoration completes successfully without errors.
Step 4: Update Mattermost Configuration
On your standalone Mattermost server, update the config.json file to point to the new PostgreSQL server. Locate the SqlSettings.DataSource parameter and update it as follows:
"SqlSettings": {
"DriverName": "postgres",
"DataSource": "postgres://mmuser:password@new-postgres-server:5432/mattermost?sslmode=disable&connect_timeout=10"
Ensure that credentials, hostnames, and connection settings match your new PostgreSQL configuration.
Step 5: Migrate the Mattermost Application and Data
To move Mattermost application files from the GitLab server to a new standalone server:
  1. Install the same or newer version of Mattermost on the new server. See Deploy the Mattermost server.
  2. Copy your existing configuration and data from the GitLab Omnibus instance:
    # On the GitLab server
    sudo cp /var/opt/gitlab/mattermost/config/config.json /tmp/
    sudo cp -r /var/opt/gitlab/mattermost/data /tmp/mattermost_data
    # Transfer to new Mattermost server
    scp /tmp/config.json mattermost@new-server:/opt/mattermost/config/
    scp -r /tmp/mattermost_data mattermost@new-server:/opt/mattermost/data/
  3. Ensure permissions are correctly set on the new server:
Step 6: Start Mattermost
Start the Mattermost service on your new standalone installation:
sudo systemctl start mattermost
Mattermost will now connect to your standalone PostgreSQL database.
Step 7: Verify the Migration
After starting Mattermost, perform the following checks:
  • Confirm that Mattermost starts successfully with no database connection errors.
  • Review server logs for any startup or connection issues.
  • Log into Mattermost and verify that all teams, channels, and users are present.
  • Post test messages and upload files to confirm functionality.
  • Validate user authentication and permissions.
  • Confirm that database queries are directed to the new PostgreSQL server.
Important Considerations
  • Always maintain a full backup of your Mattermost database before migration.
  • Schedule a maintenance window to minimize user disruption.
  • Validate performance and monitoring configurations post-migration.
  • Ensure that your new PostgreSQL server follows Mattermost’s security and tuning best practices.
Troubleshooting
If you encounter errors during the migration:
  • Review PostgreSQL logs for permission or connection issues.
  • Verify that the Mattermost PostgreSQL user has full access to the restored database.
  • Ensure that the config.json file contains the correct database connection string.
  • Restart the Mattermost service and check mattermost.log for detailed errors.
