Migrate from Rocket.Chat
Overview
Mattermost provides a migration path from Rocket.Chat, bringing your users, channels, messages, threads, direct messages, reactions, and file attachments into a self-hosted Mattermost environment.
Rocket.Chat has no hosted “export workspace” feature. Instead, you export the underlying MongoDB database with mongodump and transform that dump into a Mattermost bulk import file using the mmetl tool. This means the export step is a database operation that typically requires access to the Rocket.Chat server and its MongoDB instance.
The migration is a multi-step process:
  1. Preparations — scope the migration, gather MongoDB and attachment-storage details, and prepare the Mattermost server.
  2. Export your Rocket.Chat data — produce a mongodump of the Rocket.Chat database.
  3. Transform the export — validate with mmetl check rocketchat and convert with mmetl transform rocketchat.
  4. Import into Mattermost — upload and process the archive with mmctl.
  5. Validate, test, and go live.
Note
These instructions describe a best effort migration designed to preserve the majority of your messages, files, and channel structure. Manual adjustments are often required, and larger deployments should plan for multiple trial runs in a staging environment before a production import. Consider talking to a Mattermost expert if your organization needs migration support.
1. Preparations
This guide assumes you already have a Mattermost server deployed and ready to accept your data. If not, review the deployment documentation first.
Scope definition
  • Data history: Decide how much history you need. Because mongodump captures the whole database, scoping is done mainly through what you migrate and validate rather than by trimming the export.
  • Export size: The size of your Rocket.Chat database and attachments directly affects processing and import time. Plan for longer iteration cycles on large deployments.
  • File attachments: Consider excluding very large or non-critical attachments with --skip-attachments for early test runs to speed up iteration.
Rocket.Chat / MongoDB prerequisites
  • You need access to the Rocket.Chat MongoDB instance and the mongodump tool from the MongoDB Database Tools.
  • Identify the database name (commonly meteor) and the connection URI.
  • The transform reads these collections from the dump: users, rocketchat_room, rocketchat_message, and rocketchat_subscription (all required), plus rocketchat_uploads and rocketchat_uploads.chunks (for attachments).
Note
This tool was validated against Rocket.Chat v8.5. Rocket.Chat changes its MongoDB schema between versions, so exports from other versions may parse differently. If you hit unexpected parse errors, check for a newer mmetl release before assuming the export is at fault.
Attachment storage: GridFS vs. FileSystem
Rocket.Chat can store uploaded files in one of two ways. Confirm which your deployment uses (Admin > Settings > File Upload > Storage Type) before you export, because it changes how you run the transform:
  • GridFS (stored inside MongoDB): attachments are captured directly in the mongodump (rocketchat_uploads.chunks.bson) and extracted automatically. No extra flag needed.
  • FileSystem (stored on disk): the mongodump contains only file metadata. You must also copy the Rocket.Chat uploads directory and point --uploads-dir at it during the transform.
Infrastructure considerations
  • Test environment: Always run the migration in a development or staging environment first. Most migrations require several iterations.
  • Operating system: mmetl is supported on Linux and macOS. Windows (including WSL) is not recommended.
  • Storage requirements: Ensure you have room for the mongodump output, the transformed import file, and the extracted attachments. Plan for several times the size of your Rocket.Chat data.
  • File storage: Imports into AWS S3 (or S3-compatible storage) typically complete faster than local or NFS storage for large datasets.
Mattermost server considerations
  • Fresh server: The most reliable imports happen on a fresh installation. If importing into an existing server, never import over an existing team, and back up the database and data directory first.
  • Server version: Run the latest supported version of Mattermost.
  • The target team must already exist in Mattermost, and Allow any user with an account on this server to join this team must be enabled for it.
  • Configuration settings: Before importing, adjust:
    • TeamSettings.MaxChannelsPerTeam and TeamSettings.MaxUsersPerTeam: set well above the number of channels/users you are migrating.
    • EmailSettings.EnableSignUpWithEmail and EmailSettings.EnableSignInWithEmail: both true.
    • FileSettings.MaxFileSize: higher than the largest file in your export.
    • ElasticsearchSettings.EnableIndexing, EnableSearching, and EnableAutocomplete: set to false during the import, then purge and reindex afterward.
Export the Rocket.Chat MongoDB database with mongodump. Replace the URI and database name to match your deployment:
mongodump --uri="mongodb://localhost:3001/meteor" --out=/tmp/rc-dump
This creates a subdirectory named after the database (for example /tmp/rc-dump/meteor) containing the .bson files. That database subdirectory — not the parent — is what you pass to --dump-dir in the next step.
If your deployment uses FileSystem storage for attachments, also copy the Rocket.Chat uploads directory to a known location so you can reference it with --uploads-dir.
3. Transform the export for Mattermost
Download the latest release of mmetl for your OS and architecture. Run mmetl help to learn more about the tool.
Validate the export
Before transforming, check the integrity of the dump:
./mmetl check rocketchat --dump-dir /tmp/rc-dump/meteor
This reports structural issues (for example, missing required collections or invalid records) that would cause the transform or import to fail. Details are written to check-rocketchat.log.
check rocketchat accepts the same --guest-handling flag as the transform, so you can preview how guest users will be treated before running the full transform.
Run the transform
Convert the dump into a Mattermost bulk import file. Replace <TEAM-NAME> with your Mattermost team name, which must be one word and lowercase (a team named My Team becomes my-team):
./mmetl transform rocketchat --team <TEAM-NAME> --dump-dir /tmp/rc-dump/meteor --output mattermost_import.jsonl
For FileSystem attachment storage, add --uploads-dir:
./mmetl transform rocketchat --team <TEAM-NAME> --dump-dir /tmp/rc-dump/meteor --uploads-dir /path/to/rocketchat/uploads --output mattermost_import.jsonl
The tool produces a .jsonl file containing your users, channels, and posts, plus a data folder containing the extracted attachments.
A successful run ends with a summary line in transform-rocketchat.log like:
Transformation succeeded! Users: 152, Public channels: 48, Private channels: 12, Posts: 39184
If the run stops with an error instead — for example, the RocketChat export contains bot users but --bot-owner was not specified — no valid import file is produced. Resolve the error (see the flags below) and re-run.
Tip
Iterate incrementally. Run a small trial first: transform, import into a throwaway team, and confirm a few channels look right before committing to a full production import. Because mmctl import is idempotent, re-running an import with the same data will not create duplicate posts — so repeated trial runs are safe.
Useful transform flags
  • --uploads-dir <PATH>: Path to the Rocket.Chat FileSystem uploads directory. Required when attachments are not stored in GridFS.
  • --bot-owner <USERNAME>: Username of the Mattermost user who will own all imported bots. Required if the export contains any bot users — the transform errors out otherwise.
  • --guest-handling <MODE>: How to migrate Rocket.Chat guest users (default guest):
    • guest — migrate them as Mattermost guests. Highest fidelity, but the destination server must have Guest Accounts licensed (Professional/Enterprise) and enabled (GuestAccountsSettings.Enable); otherwise the accounts won’t behave correctly.
    • user — migrate them as regular Mattermost members. Works everywhere, but grants guests full member permissions.
    • skip — drop guest users entirely, along with their memberships and authored posts.
  • --skip-attachments / -a: Skip extracting file attachments. Useful for faster iteration while testing.
  • --attachments-dir <PATH>: Directory for extracted attachments (default data).
  • --default-email-domain <DOMAIN>: When a user’s email is missing, generate one from their username and this domain (for example example.com).
  • --skip-empty-emails: Allow users with empty emails. Note that this produces invalid import data that must be corrected before importing.
  • --debug: Emit DEBUG-level detail to transform-rocketchat.log to help diagnose slow or failing runs.
Package the .jsonl file and data folder into a single zip:
zip -r mattermost-bulk-import.zip data mattermost_import.jsonl
Validate the archive locally before uploading:
mmctl import validate ./mattermost-bulk-import.zip
Ensure mmctl is installed and authenticated. Then choose an upload method.
Standard upload
For most imports, upload through mmctl:
mmctl import upload ./mattermost-bulk-import.zip
mmctl import list available
Process the import using the name returned by import list available:
mmctl import process <IMPORT FILE NAME>
Check the job status. If it shows pending, wait and re-run. The --json flag is required to see error messages:
mmctl import job show <JOB ID> --json
Large imports (file store method)
For large archives (multiple GB), uploading through mmctl is slow and error-prone. Instead, place the archive directly into the server’s import directory and let the server process it in place:
  1. Copy mattermost-bulk-import.zip (with a unique name) into data/import in the Mattermost file store — the local data directory, or the import prefix of your S3 bucket.
  2. Run mmctl import list available to confirm the server sees the file.
  3. Run mmctl import process <IMPORT FILE NAME> and monitor with mmctl import job show <JOB ID> --json.
This avoids re-uploading gigabytes through the API and is the recommended path for large migrations.
Fixing unread channels and threads
After importing, messages may appear unread for all users. Run the following against the Mattermost database to resolve it:
begin;
UPDATE channelmembers
SET
    msgcount = channels.totalmsgcount,
    lastupdateat = channels.lastpostat,
    lastviewedat = channels.lastpostat,
    msgcountroot = channels.totalmsgcountroot
FROM channels
WHERE channelmembers.channelid = channels.id;
INSERT INTO preferences (UserId, Category, Name, Value)
SELECT
    cm.userid,
    'channel_approximate_view_time',
    cm.channelid,
    cm.lastupdateat
FROM
    channelmembers cm
ON CONFLICT (userid, category, name)
DO UPDATE SET
    Value = EXCLUDED.Value;
update preferences set value = false where category = 'direct_channel_show';
update preferences set value = false where category = 'group_channel_show';
commit;
Placeholder emails and account activation
Mattermost accounts are created from the emails and usernames in the export. Where an email is missing, a placeholder (for example username@local) is generated and must be corrected by a system administrator. Search the final .jsonl file for placeholder emails before importing.
Users activate their accounts through Mattermost’s Password Reset screen using their email address:
  • Imports performed by a system administrator: emails are automatically verified, and users can reset their password immediately.
  • Imports performed by a non-administrator: users must verify their email address before resetting their password.
See how to migrate user authentication to LDAP or SAML if you use SSO.
What migrates and what doesn’t
For core collaboration data — posts, threads, reactions, attachments, users, and channels — you can expect high fidelity. Integrations and Rocket.Chat-specific features do not carry over.
Content type
Migrates?
Notes
Posts and threads
Yes
Rocket.Chat threads become Mattermost threaded replies. Oversized posts are split into continuation replies rather than truncated.
Public channels
Yes
Display name, purpose (description), and header (topic) are preserved.
Private channels
Yes
Discussions
Yes (converted)
Rocket.Chat discussions are converted to standalone Mattermost channels (public or private, matching the discussion’s visibility). The parent-child relationship is not preserved.
1:1 direct messages
Yes
Map directly. Self-DMs are preserved as a direct channel with yourself.
Group DMs (3–8 members)
Yes (converted)
Become Mattermost Group Messages — functionally equivalent, different terminology.
Group DMs (over 8 members)
Converted
Mattermost group messages support at most 8 members, so larger group DMs are converted to private channels.
Reactions
Yes
Emoji skin-tone modifiers are stripped to a default rendering. Custom emoji require matching names (see below).
File attachments
Yes
From GridFS or FileSystem storage. Auto-generated thumbnails are skipped to avoid duplicates.
Users
Yes
Inactive Rocket.Chat users are imported as deactivated accounts.
Bots
Yes
Reassigned to the --bot-owner user.
Channel mentions
Best effort
#channel references are translated to Mattermost ~channel links where the channel exists.
Join / leave / add / remove events
Yes
Converted to Mattermost system messages.
Custom emoji images
No
Reaction names are preserved, but the emoji images are not imported (see below).
Guest users
Configurable
Controlled by --guest-handling (default guest). By default, Rocket.Chat guest accounts are imported as Mattermost guest users — this requires Guest Accounts to be licensed (Professional/Enterprise) and guest access enabled on the target server. Use --guest-handling user to import them as regular members instead (no guest licensing needed), or --guest-handling skip to drop them entirely.
Encrypted (E2E) channels
No
End-to-end encrypted rooms are skipped entirely, including their messages.
Apps, integrations, slash commands, webhooks
No
Recreate using Mattermost integrations.
Avatars, user status, custom profile fields
No
Users update their profiles in Mattermost after import.
Pinned/starred messages, topic-change and mute events
No
These Rocket.Chat-specific records are not migrated.
Custom emoji
Custom emoji images are not imported with your messages — only the emoji names used in reactions are preserved. A reaction is stored as text (:emoji-name:) and resolved at render time:
  • If a custom emoji with the same name exists in Mattermost, the reaction renders correctly.
  • If not, it shows as a placeholder until the emoji is added.
Because resolution happens at render time, you can add custom emoji to Mattermost at any time — before or after the import — and reactions on historical messages will render once a matching name exists. Names must match exactly.
FAQ
Do I need to create users before importing? No. mmetl and the import process handle user creation and ordering automatically.
What happens if I run the same import twice? Nothing harmful. mmctl import is idempotent — duplicate posts are not created — so incremental and repeated trial imports are safe.
Where do all my channels and DMs go? Into the single team you specify with --team. Rocket.Chat has no multi-workspace concept, so there is no team-mapping step.
How are attachments stored, and why do I need ``–uploads-dir``? Rocket.Chat stores files either in MongoDB (GridFS) or on disk (FileSystem). GridFS files are captured in the mongodump automatically; FileSystem files are not, so you point --uploads-dir at the uploads directory. See Attachment storage.
Why are some channels missing after import? End-to-end encrypted rooms are skipped and their messages are not migrated. Check transform-rocketchat.log for skipped rooms.
Do I need to import custom emoji before messages? No. Emoji resolve at render time, so you can add them whenever.
How do I handle a very large import? Use the file store method — copy the archive directly into the server’s data/import directory rather than uploading through mmctl. See Large imports.
I hit a parse error. Is my export broken? Possibly not. Rocket.Chat changes its MongoDB schema between versions (this tool was validated against v8.5). Run mmetl check rocketchat first, and check for a newer mmetl release before assuming the data is at fault.
