Delegated granular administration
Mattermost supports the creation and customization of system administration roles with specific granular permissions and System Console access. This allows senior administrators in large organizations to delegate and de-centralize specialized administration and administrative tasks with specific admin roles.
These admin roles permit granular access to specific areas of the System Console and related API endpoints. These roles enable users to perform certain administrative tasks without requiring access to all system administration areas. These system roles never supersede the user's original role or the user's permissions configured by the Permissions scheme.
Available roles​
A system admin can configure the following delegated granular administration roles in the System Console. Each role has a set of default permissions, which can be adjusted as needed.
  • System Manager: This role can be configured to have read/write permissions in different management areas.
  • User Manager: This role can be configured to have read/write to all the user management areas and to authentication
  • Custom Group Manager This role has permissions to create, edit, restore, and delete custom user groups. This role can be used to assign individual users the ability to manage custom groups when Custom Groups permissions are removed for All Members via System Console > Permissions > Edit Scheme > Custom Groups.
  • Shared Channel Manager This role has the manage_shared_channels permission, allowing assigned users to share and unshare channels with existing connections to remote servers.
  • Viewer: The Viewer role can view all areas of the System Console, and can be configured with write access where needed.
When a user is assigned a system role, they have role-based access to the System Console and the underlying API endpoints. Each role has a different set of default permissions, and what users can access or view depends on the role they've been assigned.
The table below lists the default permissions for each role. Admins should carefully review and configure these settings to align with their organization's needs. Particular caution should be exercised with Permissions write access, as it enables modifications to the permissions of any role, except for the delegated granular administrator roles.
System roleRead/Write accessRead Only access
System Manager
  • User Management
    • Groups
    • Teams
    • Channels
    • Permissions
  • Environment
  • Site Configuration
  • Integrations
  • Edition/License
  • Reporting
  • Authentication
  • Plugins
User Manager
  • User Management
    • Groups
    • Teams
    • Channels
  • (User Management) Permissions
  • Authentication
Custom Group ManagerCustom User GroupsN/A
Shared Channel ManagerShared ChannelsN/A
ViewerN/A
  • All pages within the System Console
Assign admin roles​
There are two ways to assign roles:
  1. In the System Console under User Management > Delegated Granular Administration.
  2. Using the mmctl tool. This can be done either locally or remotely.
You want toUsing the System ConsoleUsing mmctl
Assign rolesGo to System Console > User Management > Delegated Granular Administration > Assigned Peoplemmctl permissions role assign [role_name] [username...]
Grant the System Manager role to a user
  1. Go to System Console > User Management > Delegated Granular Administration, then select the System Manager role.
  2. Under Assigned People, select Add People.
  3. Search for and select the user name, then select Add to grant the System Manager role to that user.
mmctl permissions role assign system_manager user-name
Grant the User Manager role to two users
  1. Go to System Console > User Management > Delegated Granular Administration, then select the User Manager role.
  3. Search for and select the two users, then select Add to grant the User Manager role to those users.
mmctl permissions role assign system_user_manager user-name1 user-name2
Grant the Viewer role to a user
  1. Go to System Console > User Management > Delegated Granular Administration, then select the Viewer role.
  3. Search for and select the user name, then select Add to grant the Viewer role to that user.
mmctl permissions role assign system_read_only_admin user-name
Grant the Custom Group Manager role to two users
  1. Go to System Console > User Management > Delegated Granular Administration, then select the Custom Group Manager role.
  3. Search for and select the two users, then select Add to grant the Custom Group Manager role to those users.
  4. All users have the ability to create custom user groups by default. When you assign users to the Custom Group Manager role, you must manually remove these permissions from all users by going to System Console > User Management > Permissions > Edit Scheme. Under All Members, clear all of the Custom Groups permissions, including Create, Manage members, Edit, and Delete.
mmctl permissions role assign system_custom_group_admin user-name1 user-name2
Grant the Shared Channel Manager role to a user
  1. Go to System Console > User Management > Delegated Granular Administration, then select the Shared Channel Manager role.
  3. Search for and select the user name, then select Add to grant the Shared Channel Manager role to that user.
mmctl permissions role assign system_shared_channel_manager user-name
Remove the System Manager role from a single user
  2. Under Assigned People, search for the user, then select Remove.
mmctl permissions role unassign system_manager bob-smith
Edit privileges of admin roles (advanced)​
System admins can grant read/write access to other areas of the System Console, as well as remove read/write access (including default access), for all system roles except the Custom Group Manager and Shared Channel Manager roles.
Edit role privileges
  1. Go to System Console > User Management > Delegated Granular Administration, then select the System Manager, User Manager, or Viewer role.
  2. For each set of privileges, select the access level as Can edit, Read only, or No access.
If you set privilege subsections to different access levels, then the privilege access level displays as Mixed Access.
mmctl permissions add [role_name] [permission...] mmctl permissions reset system_read_only_admin
Grant write access to the Authentication section of the System Console for all users with the User Manager role
  2. Under Privileges > Authentication select Can edit, then select Save.
mmctl permissions add system_user_manager sysconsole_write_authentication
Grant read-only access to the Authentication section of the System Console for all users with the User Manager role
  1. Go to System Console > User Management > Delegated Granular Administration. then select the User Manager role.
  2. Under Privileges > Authentication select Read only, then select Save.
mmctl permissions remove system_user_manager sysconsole_read_authentication
Remove write access to the Authentication section of the System Console for all users with the User Manager role
  2. Under Privileges > Authentication select No access, then choose Save.
mmctl permissions remove system_user_manager sysconsole_write_authentication
Reset a role to its default set of permissionsThis is completed using the mmctl tool only.mmctl permissions reset [role_name] For example, to reset the permissions of the system_read_only_admin role: mmctl permissions reset system_read_only_admin
Admin roles and privileges​
Roles​
  • system_manager
  • system_user_manager
  • system_custom_group_admin
  • system_shared_channel_manager
  • system_read_only_admin
Privileges​
System Console sectionPermissions
About
  • PERMISSION_SYSCONSOLE_READ_ABOUT_EDITION_AND_LICENSE
  • PERMISSION_SYSCONSOLE_WRITE_ABOUT_EDITION_AND_LICENSE
Reporting
System Statistics
  • PERMISSION_SYSCONSOLE_READ_REPORTING_SITE_STATISTICS
  • PERMISSION_SYSCONSOLE_WRITE_REPORTING_SITE_STATISTICS
Team Statistics
  • PERMISSION_SYSCONSOLE_READ_REPORTING_TEAM_STATISTICS
  • PERMISSION_SYSCONSOLE_WRITE_REPORTING_TEAM_STATISTICS
Server Logs
  • PERMISSION_SYSCONSOLE_READ_REPORTING_SERVER_LOGS
  • PERMISSION_SYSCONSOLE_WRITE_REPORTING_SERVER_LOGS
User Management
Users
  • PERMISSION_SYSCONSOLE_READ_USERMANAGEMENT_USERS
  • PERMISSION_SYSCONSOLE_WRITE_USERMANAGEMENT_USERS
Groups
  • PERMISSION_SYSCONSOLE_READ_USERMANAGEMENT_GROUPS
  • PERMISSION_SYSCONSOLE_WRITE_USERMANAGEMENT_GROUPS
Teams
  • PERMISSION_SYSCONSOLE_READ_USERMANAGEMENT_TEAMS
  • PERMISSION_SYSCONSOLE_WRITE_USERMANAGEMENT_TEAMS
Channels
  • PERMISSION_SYSCONSOLE_READ_USERMANAGEMENT_CHANNELS
  • PERMISSION_SYSCONSOLE_WRITE_USERMANAGEMENT_CHANNELS
Permissions
  • PERMISSION_SYSCONSOLE_READ_USERMANAGEMENT_PERMISSIONS
  • PERMISSION_SYSCONSOLE_WRITE_USERMANAGEMENT_PERMISSIONS
Environment
Web Server
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_WEB_SERVER
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_WEB_SERVER
Database
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_DATABASE
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_DATABASE
Elasticsearch
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_ELASTICSEARCH
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_ELASTICSEARCH
File Storage
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_FILE_STORAGE
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_FILE_STORAGE
Image Proxy
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_IMAGE_PROXY
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_IMAGE_PROXY
SMTP
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_SMTP
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_SMTP
Push Notification Server
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_PUSH_NOTIFICATION_SERVER
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_PUSH_NOTIFICATION_SERVER
High Availability
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_HIGH_AVAILABILITY
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_HIGH_AVAILABILITY
Rate Limiting
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_RATE_LIMITING
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_RATE_LIMITING
Logging
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_LOGGING
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_LOGGING
Session Lengths
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_SESSION_LENGTHS
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_SESSION_LENGTHS
Performance Monitoring
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_PERFORMANCE_MONITORING
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_PERFORMANCE_MONITORING
Developer
  • PERMISSION_SYSCONSOLE_READ_ENVIRONMENT_DEVELOPER
  • PERMISSION_SYSCONSOLE_WRITE_ENVIRONMENT_DEVELOPER
Site Configuration
Customization
  • PERMISSION_SYSCONSOLE_READ_SITE_CUSTOMIZATION
  • PERMISSION_SYSCONSOLE_WRITE_SITE_CUSTOMIZATION
Localization
  • PERMISSION_SYSCONSOLE_READ_SITE_LOCALIZATION
  • PERMISSION_SYSCONSOLE_WRITE_SITE_LOCALIZATION
Users and Teams
  • PERMISSION_SYSCONSOLE_READ_SITE_USERS_AND_TEAMS
  • PERMISSION_SYSCONSOLE_WRITE_SITE_USERS_AND_TEAMS
Notifications
  • PERMISSION_SYSCONSOLE_READ_SITE_NOTIFICATIONS
  • PERMISSION_SYSCONSOLE_WRITE_SITE_NOTIFICATIONS
Announcement Banner
  • PERMISSION_SYSCONSOLE_READ_SITE_ANNOUNCEMENT_BANNER
  • PERMISSION_SYSCONSOLE_WRITE_SITE_ANNOUNCEMENT_BANNER
Emoji
  • PERMISSION_SYSCONSOLE_READ_SITE_EMOJI
  • PERMISSION_SYSCONSOLE_WRITE_SITE_EMOJI
Posts
  • PERMISSION_SYSCONSOLE_READ_SITE_POSTS
  • PERMISSION_SYSCONSOLE_WRITE_SITE_POSTS
File Sharing and Downloads
  • PERMISSION_SYSCONSOLE_READ_SITE_FILE_SHARING_AND_DOWNLOADS
  • PERMISSION_SYSCONSOLE_WRITE_SITE_FILE_SHARING_AND_DOWNLOADS
Public Links
  • PERMISSION_SYSCONSOLE_READ_SITE_PUBLIC_LINKS
  • PERMISSION_SYSCONSOLE_WRITE_SITE_PUBLIC_LINKS
Notices
  • PERMISSION_SYSCONSOLE_READ_SITE_NOTICES
  • PERMISSION_SYSCONSOLE_WRITE_SITE_NOTICES
Authentication
Signup
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_SIGNUP
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_SIGNUP
Email
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_EMAIL
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_EMAIL
Password
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_PASSWORD
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_PASSWORD
MFA
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_MFA
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_MFA
AD/LDAP
SAML 2.0
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_SAML
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_SAML
OpenID Connect
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_OPENID
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_OPENID
Guest Access
  • PERMISSION_SYSCONSOLE_READ_AUTHENTICATION_GUEST_ACCESS
  • PERMISSION_SYSCONSOLE_WRITE_AUTHENTICATION_GUEST_ACCESS
Plugin
  • PERMISSION_SYSCONSOLE_READ_PLUGINS
  • PERMISSION_SYSCONSOLE_WRITE_PLUGINS
Integrations
Integration Management
  • PERMISSION_SYSCONSOLE_READ_INTEGRATIONS_INTEGRATION_MANAGEMENT
  • PERMISSION_SYSCONSOLE_WRITE_INTEGRATIONS_INTEGRATION_MANAGEMENT
Bot Accounts
  • PERMISSION_SYSCONSOLE_READ_INTEGRATIONS_BOT_ACCOUNTS
  • PERMISSION_SYSCONSOLE_WRITE_INTEGRATIONS_BOT_ACCOUNTS
GIF (Beta)
  • PERMISSION_SYSCONSOLE_READ_INTEGRATIONS_GIF
  • PERMISSION_SYSCONSOLE_WRITE_INTEGRATIONS_GIF
CORS
  • PERMISSION_SYSCONSOLE_READ_INTEGRATIONS_CORS
  • PERMISSION_SYSCONSOLE_WRITE_INTEGRATIONS_CORS
Compliance
Data Retention Policy
  • PERMISSION_SYSCONSOLE_READ_COMPLIANCE_DATA_RETENTION_POLICY
  • PERMISSION_SYSCONSOLE_WRITE_COMPLIANCE_DATA_RETENTION_POLICY
Compliance Export
  • PERMISSION_SYSCONSOLE_READ_COMPLIANCE_COMPLIANCE_EXPORT
  • PERMISSION_SYSCONSOLE_WRITE_COMPLIANCE_COMPLIANCE_EXPORT
Compliance Monitoring
  • PERMISSION_SYSCONSOLE_READ_COMPLIANCE_COMPLIANCE_MONITORING
  • PERMISSION_SYSCONSOLE_WRITE_COMPLIANCE_COMPLIANCE_MONITORING
Custom Terms of Service
  • PERMISSION_SYSCONSOLE_READ_COMPLIANCE_CUSTOM_TERMS_OF_SERVICE
  • PERMISSION_SYSCONSOLE_WRITE_COMPLIANCE_CUSTOM_TERMS_OF_SERVICE
Experimental
Features
  • PERMISSION_SYSCONSOLE_READ_EXPERIMENTAL_FEATURES
  • PERMISSION_SYSCONSOLE_WRITE_EXPERIMENTAL_FEATURES
Feature Flags
  • PERMISSION_SYSCONSOLE_READ_EXPERIMENTAL_FEATURE_FLAGS
  • PERMISSION_SYSCONSOLE_WRITE_EXPERIMENTAL_FEATURE_FLAGS
Bleve
  • PERMISSION_SYSCONSOLE_READ_EXPERIMENTAL_BLEVE
  • PERMISSION_SYSCONSOLE_WRITE_EXPERIMENTAL_BLEVE
Frequently Asked Questions​
Can a User Manager or System Manager reset an administrator’s email or password without their knowledge?​
This is not possible with the default privileges of these roles. The ability to reset passwords or email addresses of administrators is limited to system admins.
Can a User Manager or System Manager access the configuration file?​
Yes. However, they will only have access to read actual values and modify values in accordance with their permissions. If appropriate read permissions do not exist, the default key values will be displayed.
Are all actions of admin roles logged?​
Every change made by any admin is included in the audit log.
Can a System Manager change their own permissions or elevate their role?​
No. System Managers can't elevate their role, and aren't able to elevate other members' roles.
No, password information is only visible to system admins and is obfuscated for other roles.
Only roles that are explicitly granted access to System Console > Compliance have access to download compliance reports.
Can any of the new roles force-join Private channels?​
Yes at this time they can, however, we will be improving on this behavior in the future with a prompt that lets them know they are entering a private channel. We are also planning on adding a permission which would remove the ability to access Private channels.
Can I create a new role or clone an existing role?​
No, but we are actively seeking feedback on this capability.
Can I use an LDAP filter to assign these roles?​
No, but we are considering this functionality for a future enhancement.
Can I rename the roles?​
This is being considered for future development.
Can a System Manager or User Manager demote or deactivate another Admin or Manager?​
A System or User Manager can demote or deactivate another System or User Manager, but can't demote or deactivate a system admin.
Can a System Manager or User Manager assign or unassign admin roles?​
Only the system admin has access to edit system roles.
