Advanced permissions: backend infrastructure
This document outlines the backend server infrastructure for permissions in Mattermost and is recommended only for technical Admins or developers looking to make modifications to their installation.
Entity definitions​
Permissions​
A permission describes a permitted action which may be carried out on an object. It describes the action that users may perform in the context in which they have been assigned the role granting the permission.
Roles​
A role is something to which permissions are granted, that is then assigned to users in contexts in order to grant them the assigned permissions in that context. One user may end up with different sets of permissions granted by different roles in different contexts.
Scope​
Permissions live within a given scope. There are three scopes in the Mattermost system: System, Team and Channel. Permissions cascade down the scopes from the context in which they are applied. For example, if a “Channel” scoped permission is applied to a “Team” context, the permission applies to any channels within that team. A permission is considered,
  • System scope if it makes sense only on the system level. For example, manage_oauth.
  • Team scope if it makes sense at the team level and system level. For example, create_public_channel.
  • Channel scope if it makes sense at channel, team and system level. For example, manage_public_channel_properties.
Context​
A context is an instance of a scope. For example, a channel called "Developers Hangout" is an instance of channel scope. Contexts have hierarchical relationships between them that reflect the hierarchical ordering of scopes. Each context has one parent, and may have multiple children, with the ultimate parent context being the system context:
  • A channel context has a parent team context, whose parent is the system context. For example, the "Developers Hangout" channel is the channel context, with parent team context "Contributors Team", with parent system context.
  • A team context has a parent system context and child channel contexts. For example, the "Contributors Team" is the team context, with parent system context, and with children channel contexts such as "Developers Hangout", "Reception" and "Marketing".
When determining whether a user is allowed to carry out a given action in a given context, the union of the permissions of all roles that user has been assigned in the current context and its parent contexts is calculated. This enables permissions to cascade down the scope hierarchy. For example, if a users is granted the manage_public_channel_properties permission in a role in the system context, then the user has permissions to manage public channel properties in all channels, in all teams, of which they are a member.
Schemes​
Schemes describe the default roles applied to users in a context, and all child contexts. Schemes are either defined specifically for a context, or if they are not specified, the relevant parts of the parent context’s scheme are applied, ultimately climbing the hierarchy to the System Scheme, which serves the purpose of providing the system-wide defaults. For example, if Team A does not have a team-scoped scheme defined, the System Scheme will provide the defaults for all contexts in Team A.
Additionally, the lowest-scoped scheme always takes precedence in the context. For example, if Team B has a team-scoped scheme, that scheme takes precedence over the System Scheme defaults for all contexts in Team B.
Data structure​
Permissions​
Permissions in Mattermost are a property of the server code base and are not created or modified dynamically. The current set of permissions are as described in the table below.
Mattermost permissions
Name (i18n)ScopeDescription
invite_userteamInvite users to the team using Send Email Invite or Get Team Invite Link.
add_user_to_teamteamAdd existing server users to the current team.
manage_slash_commandssystemCreate, edit, and delete your own slash commands.
manage_others_slash_commandssystemEdit or delete other users' slash commands.
create_public_channelteamCreate public channels.
create_private_channelteamCreate private channels.
manage_public_channel_memberschannelManage public channel members.
manage_private_channel_memberschannelManage private channel members.
assign_system_admin_rolesystemGrant other users the system admin role.
manage_rolessystemManage other users' system-wide roles.
manage_team_rolesteamAdd and remove team members.
manage_channel_roleschannelAdd and remove channel members.
manage_systemsystemAccess to System Console.
sysconsole_read_usermanagement_system_rolessystemView system roles.
sysconsole_write_usermanagement_system_rolessystemAdd, remove, and assign system roles.
create_direct_channelsystemOpen Direct Message channels.
create_group_channelsystemOpen Group Message channels.
manage_public_channel_propertieschannelEdit public channel name, header, and purpose, as well as create public channel checklists.
manage_private_channel_propertieschannelEdit private channel name, header, and purpose, as well as create private channel checklists.
list_public_teamssystemView public teams listed in the "Join Another Team" menu accessed from the main menu.
join_public_teamssystemJoin public teams listed in the "Join Another Team" menu accessed from the main menu.
list_private_teamssystemView private teams listed in the "Join Another Team" menu accessed from the main menu.
join_private_teamssystemJoin private teams listed in the "Join Another Team" menu accessed from the main menu.
list_team_channelsteamList public channels in a team.
join_public_channelsteamJoin public channels.
delete_public_channelchannelArchive public channels.
delete_private_channelchannelArchive private channels.
edit_other_userssystemEdit values on the user object of other users.
read_channelchannelView posts in a channel.
read_channel_contentschannelRead the contents of a channel.
read_public_channelteamView and access public channels on a team.
add_reactionchannelAdd emoji reactions to posts.
remove_reactionchannelRemove emoji reactions from posts.
remove_others_reactionschannelRemove other users emoji reactions from posts.
permanent_delete_user (deprecated)systemPermanently delete other users.
upload_filechannelUpload file attachments to posts.
get_public_linksystemGet permalink for posts.
manage_incoming_webhooksteamCreate, edit, and delete your own incoming webhooks.
manage_outgoing_webhooksteamCreate, edit, and delete your own outgoing webhooks.
manage_others_webhooks(deprecated)teamEdit and delete other users' incoming or outgoing webhooks.
manage_others_incoming_webhooksteamEdit and delete other users' incoming webhooks.
manage_others_outgoing_webhooksteamEdit and delete other users' outgoing webhooks.
manage_oauthsystemCreate, edit, and delete your own OAuth 2.0 apps.
manage_system_wide_oauthsystemEdit or delete other users' OAuth 2.0 apps.
create_postchannelPost in channels.
create_post_publicchannelCreate a system message within a channel.
create_post_ephermalchannelCreate an ephemeral message within a channel.
edit_postchannelAuthors edit their own posts.
edit_others_postschannelEdit other users' posts.
delete_postchannelAuthors delete their own posts.
delete_others_postschannelDelete other users' posts.
remove_user_from_teamteamRemove users from team.
create_teamsystemCreate teams.
manage_teamteamAccess Team Settings.
view_teamteamRead the Team object.
create_botteamCreate bot accounts.
assign_botteamAssign bots to users other than who created the bot.
read_botteamView own bots created.
read_others_botsteamView bots created by others.
manage_botsteamEdit and delete own bots.
manage_others_botsteamEdit and delete bots created by others.
view_membersteamList all members on the team.
list_users_without_teamsystemList users without a team.
create_user_access_tokensystemCreate user access tokens.
read_user_access_tokensystemRead user access tokens by ID.
revoke_user_access_tokensystemRevoke user access tokens.
manage_jobssystemCreate and cancel jobs.
create_emojisteamCreate custom emoji.
delete_emojisteamDelete own custom emoji.
delete_others_emojisteamDelete custom emoji created by others.
invite_guestsystemInvite guest users via email invite or add existing guests to teams.
promote_guestsystemPromote guests to member users.
demote_to_guestsystemDemote member users to guests.
manage_remote_clusters (deprecated in v5.36) | system | Add, remove, and view remote clusters for shared channels. Deprecated in v5.36; renamed to manage_secure_connections.
manage_shared_channelssystemShare and unshare channels with existing connections to remote servers.
manage_secure_connectionssystemCreate, manage, and remove secure connections to remote servers.
manage_post_bleve_indexes_jobsystemManage the status of a Bleve post indexing job.
manage_data_retention_jobsystemManage the status of a data retention job.
manage_compliance_export_jobsystemManage the status of a compliance export job.
manage_elasticsearch_post_indexing_jobsystemManage the status of an Elasticsearch post indexing job.
manage_elasticsearch_post_aggregation_jobsystemManage the status of an Elasticsearch post aggregation job.
manage_ldap_sync_jobsystemManage the status of an LDAP synchronization job.
add_bookmark_public_channelchannelAdd bookmarks to a public channel.
add_bookmark_private_channelchannelAdd bookmarks to a private channel.
edit_bookmark_public_channelchannelMake changes to bookmarks in a public channel.
edit_bookmark_private_channelchannelMake changes to bookmarks in a private channel.
delete_bookmark_public_channelchannelDelete bookmarks in a public channel.
delete_bookmark_private_channelchannelDelete bookmarks in a private channel.
order_bookmark_public_channelchannelReorder bookmarks in a public channel.
order_bookmark_private_channelchannelReorder bookmarks in a private channel.
manage_channel_bannerchannelManage channel banners.
manage_channel_access_ruleschannelManage attribute-based access control rules for channels.
manage_team_access_rulesteamManage attribute-based team and channel membership policies for a team from Team Settings.
Roles field​
Roles are applied to objects that represents that user’s membership in a context. These are referenced in the Roles field of the User, TeamMember, ChannelMember and Schemes Tables.
In the TeamMember and ChannelMember tables, it's the Roles field that contains custom roles and the SchemeAdmin and SchemeUser booleans that indicate the member object should inherit the respective roles from the relevant scheme, either the default or custom scheme assigned to the relevant team.
Roles table​
Roles are dynamic and user configurable, necessitating a database table with the following fields:
  • Id (Autoincrement, Primary Key)
  • Name (Unique String with Character Constraints, e.g. “team_user”).
  • Display Name (String)
  • Description (String)
  • Permissions (String): Space-separated permissions names
  • Scheme Managed (bool): Indicates whether this role is managed as part of a scheme.
  • BuiltIn (bool): Indicates if this role is built-in to the Mattermost system and not removable by the user.
Built-in roles​
The System Scheme is built-in to the product, and its roles are defined as BuiltIn: true in the Roles table. You can use the Mattermost API to retrieve a list of permissions by role name.
The following built-in roles with default permissions are available:
channel_admin
  • manage_private_channel_members
  • read_public_channel_groups
  • use_channel_mentions
  • create_post
  • use_group_mentions
  • add_reaction
  • read_private_channel_groups
  • remove_reaction
  • manage_public_channel_members
  • manage_channel_roles
  • add_bookmark_public_channel
  • edit_bookmark_public_channel
  • delete_bookmark_public_channel
  • order_bookmark_public_channel
  • add_bookmark_private_channel
  • edit_bookmark_private_channel
  • delete_bookmark_private_channel
  • order_bookmark_private_channel
  • manage_channel_banner
  • manage_channel_access_rules
channel_guest
  • read_channel
  • read_channel_contents
  • add_reaction
  • remove_reaction
  • upload_file
  • edit_post
  • create_post
channel_user
  • manage_public_channel_properties
  • add_reaction
  • delete_private_channel
  • delete_public_channel
  • read_channel
  • delete_post
  • get_public_link
  • remove_reaction
  • upload_file
  • manage_private_channel_properties
  • create_post
  • edit_post
system_admin
  • manage_others_slash_commands
  • sysconsole_write_user_management_permissions
  • edit_brand
  • remove_reaction
  • manage_incoming_webhooks
  • sysconsole_write_user_management_groups
  • create_public_channel
  • sysconsole_write_authentication
  • join_private_teams
  • create_post_ephemeral
  • list_users_without_team
  • sysconsole_write_reporting
  • join_public_channels
  • invite_guest
  • list_private_teams
  • sysconsole_write_user_management_channels
  • manage_others_bots
  • read_user_access_token
  • add_user_to_team
  • view_members
  • edit_post
  • demote_to_guest
  • delete_others_posts
  • sysconsole_write_plugins
  • sysconsole_read_user_management_system_roles
  • sysconsole_read_user_management_users
  • revoke_user_access_token
  • read_others_bots
  • sysconsole_write_user_management_teams
  • sysconsole_write_billing
  • convert_public_channel_to_private
  • remove_user_from_team
  • manage_team
  • add_reaction
  • manage_oauth
  • list_team_channels
  • create_team
  • read_jobs
  • invite_user
  • manage_shared_channels
  • remove_others_reactions
  • manage_secure_connections
  • sysconsole_write_user_management_users
  • sysconsole_read_experimental
  • sysconsole_write_compliance
  • edit_others_posts
  • assign_bot
  • manage_bots
  • manage_others_outgoing_webhooks
  • manage_system_wide_oauth
  • delete_others_emojis
  • manage_others_incoming_webhooks
  • promote_guest
  • sysconsole_write_experimental
  • sysconsole_read_plugins
  • create_group_channel
  • sysconsole_read_environment
  • manage_roles
  • get_public_link
  • sysconsole_read_billing
  • sysconsole_write_integrations
  • download_compliance_export_result
  • manage_slash_commands
  • assign_system_admin_role
  • create_post
  • delete_post
  • create_direct_channel
  • list_public_teams
  • create_post_public
  • sysconsole_read_integrations
  • read_other_users_teams
  • manage_jobs
  • sysconsole_read_site
  • manage_outgoing_webhooks
  • sysconsole_write_environment
  • manage_system
  • sysconsole_read_user_management_permissions
  • sysconsole_write_about
  • sysconsole_write_user_management_system_roles
  • sysconsole_read_reporting
  • upload_file
  • read_channel
  • sysconsole_read_user_management_teams
  • delete_emojis
  • view_team
  • sysconsole_read_user_management_groups
  • create_private_channel
  • create_bot
  • join_public_teams
  • sysconsole_read_about
  • read_bots
  • sysconsole_read_authentication
  • edit_other_users
  • sysconsole_read_user_management_channels
  • convert_private_channel_to_public
  • create_user_access_token
  • sysconsole_write_site
  • manage_team_roles
  • sysconsole_read_compliance
  • create_emojis
  • manage_post_bleve_indexes_job
  • manage_data_retention_job
  • manage_compliance_export_job
  • manage_elasticsearch_post_indexing_job
  • manage_elasticsearch_post_aggregation_job
  • manage_ldap_sync_job
system_custom_group_admin
  • create
  • edit
  • delete
  • manage members
  • restore
system_shared_channel_manager
system_guest
system_manager
  • view_team
  • read_jobs
  • edit_brand
  • add_user_to_team
  • manage_jobs
  • manage_team
  • read_channel
  • list_public_teams
  • manage_team_roles
  • join_public_teams
system_post_all
  • create_post
system_post_all_public
system_read_only_admin
  • read_jobs
  • view_team
  • read_channel
  • list_public_teams
system_user
  • list_public_teams
  • join_public_teams
  • view_members
  • create_team
  • create_emojis
  • delete_emojis
system_user_access_token
system_user_manager
  • read_channel
  • read_jobs
  • view_team
  • join_public_teams
  • manage_team
  • list_public_teams
  • add_user_to_team
  • manage_team_roles
team_admin
  • manage_team_roles
  • manage_team
  • remove_reaction
  • delete_post
  • create_post
  • add_reaction
  • manage_team_access_rules
team_guest
  • view_team
team_post_all
  • create_post
team_post_all_public
team_user
  • invite_user
  • add_user_to_team
  • view_team
Schemes table​
Schemes are dynamic and user configurable, necessitating a database table with the following fields:
  • Name (Unique String with Character Constraints, e.g. “corporate_scheme”)
  • Display Name
  • Scope (String): Team or Channel
  • Team Admin Role (String): Empty if Channel Scope
  • Team User Role (String): Empty if Channel Scope
  • Team Guest Role (String): Empty if Channel Scope
  • Channel Admin Role (String): Always provided
  • Channel User Role (String): Always provided
  • Channel Guest Role (String): Always provided
