Session attributes
From Mattermost v12, permission policies can evaluate session attributes in addition to user attributes. A user attribute describes who someone is. A session attribute describes how they're connecting right now, such as the network they're on, the client they're using, and the state of their device.
This lets you write rules such as "only allow file downloads from a corporate IP range" or "block uploads from jailbroken mobile devices". Session attributes are referenced in policy expressions as user.session.<name>, for example user.session.vpn_active == "true".
How session attributes work
Collection
Session attributes come from two sources:
- Server-derived attributes are measured by the Mattermost server from the request itself: the connection's IP address and the
User-Agentheader. - Client-reported attributes are collected by the Desktop App or mobile app using native operating system APIs and sent to the server in an
X-MM-Session-Attributesrequest header.
Clients only collect what you've enabled. When a client connects, the server tells it which attributes apply to its platform and how often to refresh each one. The server ignores any value it doesn't expect, such as one for a disabled attribute or for an attribute that platform can't support.
Reported values are held in the session's in-memory cache. They aren't written to the database, aren't included in compliance exports, and are discarded when the user logs out or the session is revoked or expires.
Platform availability
Not every client can report every attribute. The Platforms column in the System Console and in the Session attribute reference shows which clients support each one.
- Web browsers can't report device or network attributes such as
os_platform,vpn_active, orclient_ip_address, because a browser can't access the operating system APIs needed to measure them. If you only want to allow managed desktop and mobile clients, this is the desired behavior. If you want to check posture only where it can be measured, write the rule so browser sessions are handled deliberately. - Desktop native device and network collection is only implemented on Windows and macOS. These attributes are absent on desktop sessions on other platforms.
- Mobile users are prompted for location access when
ssidis enabled, because iOS and Android put Wi-Fi network information behind that permission. Mattermost only reads the current network's name and doesn't collect device location, but a user who declines reports no SSID and is denied by any rule that requires it. See Session attribute collection.
TTL and grace period
Each attribute has two timers that control how fresh its value must be:
- TTL (time-to-live): How long a client waits before reporting the attribute again. A short TTL keeps the value current at the cost of slightly larger requests; a long TTL reduces overhead but lets the value go stale.
- Grace period: How long after the TTL elapses Mattermost still uses the last reported value. Once TTL plus grace period passes without a fresh report, the attribute is treated as absent and rules referencing it deny access.
Defaults vary by attribute; see the Session attribute reference. Both timers offer presets of 15 seconds, 30 seconds, 1 minute, 5 minutes, 1 hour, and 24 hours. Server-derived attributes aren't affected by these timers, because Mattermost measures them on every request.
Privacy
Collection is opt-in on the server and on by default in the client. No attribute is collected unless a System Admin enables it.
Desktop App users can stop reporting attributes by clearing Settings > Advanced > Enable session attributes. Previously reported values can remain in use until their TTL and grace period expire. After those values expire, any rule that depends on a client-reported attribute denies that user. While the setting is enabled, the Desktop App shows users every attribute it can collect and the value it currently reports. See Session attribute collection for how to communicate this to your users.
Set up session attributes
Prerequisites
- A Mattermost Enterprise Advanced license.
- Attribute-based access control must be enabled in System Console > System Attributes > Attribute-Based Access.
- Client-reported attributes require Mattermost Desktop App v6.3 or later, or Mattermost mobile app v2.44 or later. Web browsers and older apps can only report a subset of attributes. See Platform availability.
Steps
- Enable the attributes you need. In the System Console, go to System Attributes > Session Attributes. Every attribute is disabled by default. For each attribute you plan to use, select More
, then select Enable.
- Adjust the timers (optional). From the same More menu, you can change how often clients report the attribute and how long a reported value stays usable. See TTL and grace period.
- Add a rule to a permission policy. Create or edit a permission policy and add a rule that uses the attribute. See Write session attribute rules.
- Simulate access. Use Simulate access to check the result for real users on the clients they actually use.
- Save the policy.
Before you write a rule
- A missing attribute denies access. If a rule references an attribute the session doesn't have, the user is denied. This applies whether the attribute was never reported, is disabled, isn't supported on the user's client, or has gone stale past its TTL and grace period. This is deliberate: otherwise a rule such as
user.session.jailbreak_detected != "true"would pass for any client that omits the attribute, including one that omits it on purpose. - Every rule is also a client requirement. Web browsers can't report device or network attributes, so a rule using one of them denies all browser users, including users of the web app. For example:
user.session.os_platform == "windows"denies every browser and mobile session, not just non-Windows desktops.user.session.vpn_active == "false"denies browser sessions, because they never reportvpn_active.user.session.hardware_id != ""denies every mobile and browser session, and any desktop session on a platform without native collection.
- Values are case-sensitive.
user.session.ssid == "corp-wifi"never matches a network namedCorp-WiFi. This matters most for free-text attributes such asssidandclient_fqdn. - Boolean values are strings.
vpn_active,mdm_enrolled, andjailbreak_detectedare reported as the strings"true"and"false", so compare them as strings:user.session.mdm_enrolled == "true". - Disabling an attribute breaks rules that use it. Mattermost blocks saving a policy that references a disabled or unknown attribute, but disabling an attribute that an existing policy already uses doesn't invalidate that policy. The policy then denies everyone.
- Client-reported values are self-attested. Treat them as posture signals rather than proof. See Can users spoof session attributes?.
Simulate access with session attributes
Simulate access evaluates draft policies against selected users before you save. When the rules reference user.session.* and the selected user has no cached session attributes, Mattermost shows a neutral No recent session result instead of allow or deny.
No recent session means there was no session data to evaluate, not that the user would be denied. It usually means the user hasn't connected recently from a client that reports the attributes your rules use. Have the user connect from the client you're targeting, then re-run the simulation.
Enabled session attributes appear in the permission policy editors alongside user attributes. In the simple editor, attributes with a fixed set of values, such as os_platform, vpn_active, and user_agent_browser_name, offer their values in a dropdown. In the Advanced Mode CEL editor, reference them as user.session.<name> and combine them with the usual CEL operators:
user.session.mdm_enrolled == "true" || user.session.os_platform in ["macos", "windows"]
IP range and version conditions
Mattermost provides dedicated operators for matching an IP address against a subnet and for comparing versions. In the simple editor they appear in the operator menu after you select a supported attribute. In the CEL editor, write them as functions on the attribute:
user.session.<name>.<function>("<value>")
| Operator | CEL function | What it checks | Available on |
| in IP range | inCIDR | The IP address falls inside the given CIDR block, such as 10.0.0.0/8. | ip_address, client_ip_address |
| version is | versionEQ | The version is exactly the given version. | os_version, client_version, user_agent_browser_version |
| version is at least | versionGTE | The version is equal to or newer than the given version. | os_version, client_version, user_agent_browser_version |
| version is greater than | versionGT | The version is strictly newer than the given version. | os_version, client_version, user_agent_browser_version |
| version is at most | versionLTE | The version is equal to or older than the given version. | os_version, client_version, user_agent_browser_version |
| version is less than | versionLT | The version is strictly older than the given version. | os_version, client_version, user_agent_browser_version |
For how these functions fit with the rest of a rule, and which operators each attribute type supports, see Session attributes in the access policy expression reference.
To allow several address ranges, join inCIDR checks with ||:
user.session.ip_address.inCIDR("10.0.0.0/8") || user.session.ip_address.inCIDR("192.168.0.0/16")
To require a managed Windows desktop client on a corporate subnet running a supported version:
user.session.os_platform == "windows" && user.session.mdm_enrolled == "true" && user.session.ip_address.inCIDR("10.0.0.0/8") && user.session.client_version.versionGTE("6.3.0")
Keep the following in mind:
- Version comparisons follow semantic versioning, so
6.10.0is newer than6.9.0. A leadingvand shortened versions such as6.3are accepted. Pre-release versions such as6.3.0-rc1sort before the matching release. - Avoid exact-matching
client_version. Different clients format the build number differently, soclient_version == "2.44.0+807"can match one client and deny another that reports the same release as2.44.0+6000807. Use version is at least, or compare against a shortened version such as2.44. - IP family must match. An IPv4 range only matches IPv4 addresses.
client_ip_addressprefers IPv4 but falls back to IPv6 when the device has no usable IPv4 address, andip_addressis whichever family the connection arrived on. On a dual-stack network, cover both families. - An unparseable value denies access. If the attribute doesn't hold a valid IP address or version, the user is denied.
- Select Validate syntax before saving in the CEL editor to catch misspelled function names and malformed CIDR blocks or version strings.
Trusted proxy headers and inCIDR rules
When ServiceSettings.TrustedProxyIPHeader is configured, Mattermost takes ip_address from that header instead of the connection. An inCIDR rule on ip_address is only trustworthy when clients can't reach the Mattermost server directly and your reverse proxy overwrites the header with the real client address on every inbound request. If the proxy appends to a client-supplied value, or a client can bypass the proxy, the address is attacker-controlled and any network rule built on it can be satisfied at will.
VPN detection
vpn_active is determined by the types of network interfaces present on the device, not by inspecting traffic. Mattermost looks for interfaces the operating system reports as VPN or tunnel adapters, such as utun and ipsec interfaces on macOS and iOS, and adapters whose type or name identifies them as VPN or tunnel devices on Windows. This has limits:
- Split-tunnel VPNs may be reported as active even when traffic to Mattermost isn't going through the tunnel, or not reported at all, depending on how the client provisions its interfaces.
- Non-standard VPN implementations that don't present a recognizable tunnel interface aren't detected.
The Session Attributes list in the System Console shows each attribute's name, type, supported platforms, TTL, grace period, and status. Attributes marked Server are measured by the Mattermost server rather than reported by the client.
| Attribute | Description | Platforms | How it's collected | Default TTL / grace |
ip_address | The IP address the request arrived from, as measured by the server, such as 203.0.113.42. | Desktop, mobile, browser | Read from the request connection, or from ServiceSettings.TrustedProxyIPHeader when that setting is configured. See Trusted proxy headers and inCIDR rules. | n/a |
user_agent_platform | Hardware platform. One of Windows, Macintosh, Linux, iPad, iPhone, iPod, BlackBerry, Windows Phone, or Unknown. | Desktop, mobile, browser | Parsed from the User-Agent header. | n/a |
user_agent_os | Operating system. One of Windows, Windows 10, Windows 8.1, Windows 8, Windows 7, Windows Vista, Windows XP x64 Edition, Windows XP, Windows 2000, Windows Phone, Mac OS, iOS, Android, Chrome OS, Linux, BlackBerry, Kindle, webOS, or Unknown. | Desktop, mobile, browser | Parsed from the User-Agent header. | n/a |
user_agent_browser_name | Client name. One of Chrome, Firefox, Safari, Edge, Internet Explorer, Opera, Android, BlackBerry, Desktop App, Mobile App, mmctl, or Unknown. | Desktop, mobile, browser | Parsed from the User-Agent header. | n/a |
user_agent_browser_version | Version of the browser or Mattermost client, such as 130.0.6723. | Desktop, mobile, browser | Parsed from the User-Agent header. | n/a |
client_ip_address | The IP address of the device's own primary network interface, as the device sees it, such as 10.0.12.34. Differs from ip_address when the user is behind NAT or a proxy. | Desktop, mobile | Read from the primary network interface using native OS APIs. IPv4 is used when available; the client falls back to IPv6 when no IPv4 address is present. | 15s / 15s |
network_interface_type | Type of the device's primary network interface. One of wifi, ethernet, cellular, vpn, or other. | Desktop, mobile | macOS: SCNetworkInterface interface type. Windows: IP Helper adapter type. iOS: NWPathMonitor. Android: NetworkCapabilities transport type. | 15s / 15s |
vpn_active | Whether a VPN or tunnel interface is active on the device. true or false. | Desktop, mobile | Detected by inspecting the device's network interfaces for known VPN and tunnel adapter types. See VPN detection for accuracy limitations. | 15s / 15s |
ssid | Name of the Wi-Fi network the device is connected to. Empty when the device isn't on Wi-Fi. | Desktop, mobile | Windows: WLAN API. iOS and Android: platform Wi-Fi APIs, which require the user to grant location access. Not collected on macOS desktop. | 15s / 15s |
mdm_enrolled | Whether the device is enrolled in mobile device management. true or false. | Desktop, mobile | Windows: presence of MDM enrollment registry entries. iOS: managed app configuration. Android: managed profile or managed app restrictions. Always reports false on macOS desktop. | 60s / 60s |
jailbreak_detected | Whether the mobile device appears to be jailbroken or rooted. true or false. | Mobile | Root and jailbreak heuristics provided by the mobile OS integration. | 60s / 60s |
os_platform | The device's operating system family. One of macos, windows, linux, ios, or android. | Desktop, mobile | Reported directly by the client using Electron or React Native APIs. | 60s / 60s |
os_version | The device's operating system version, such as 15.3.1 or 10.0.22631. | Desktop, mobile | Reported directly by the client using Electron or React Native APIs. | 60s / 60s |
client_version | The version of the Mattermost Desktop App or mobile app, such as 6.3.0. | Desktop, mobile | Reported directly by the client using Electron or React Native APIs. | 60s / 60s |
hardware_id | A stable hardware identifier for the device. | Desktop | macOS: IOPlatformUUID. Windows: SMBIOS system UUID. | 300s / 300s |
client_device_id | A per-vendor, per-install device identifier for mobile devices. | Mobile | iOS: identifierForVendor. Android: ANDROID_ID. | 300s / 300s |
tls_device_id | A device identity asserted by your reverse proxy, typically derived from a client TLS certificate. | Desktop, browser | Read from the X-Mattermost-Session-Attribute-Device-Id header, and only when TrustProxyDeviceIdentityHeader is enabled. Any caller that can set that header can set this value, so it's only trustworthy when clients can't bypass your proxy - see Trust proxy device identity header. | 300s / 300s |
server_fqdn | The hostname of the Mattermost server the client is connected to. Useful when a client connects to multiple servers. | Desktop, mobile | Derived by the client from the configured server URL. | 300s / 300s |
client_fqdn | The device's own fully qualified domain name. | Desktop | macOS: local hostname combined with the primary DNS search domain. Windows: GetComputerNameExW. | 300s / 300s |
Configuration settings
Both settings are managed in System Console > System Attributes > Attribute-Based Access and are disabled by default. They're also listed in the configuration settings reference: Trust proxy device identity header and Enforce device ID consistency.
Populates the tls_device_id session attribute from the X-Mattermost-Session-Attribute-Device-Id request header, allowing a reverse proxy that performs mutual TLS to assert a device identity that the client itself can't forge.
config.jsonsetting:"AccessControlSettings.TrustProxyDeviceIdentityHeader": falsewith optionstrueandfalse.- Environment variable:
MM_ACCESSCONTROLSETTINGS_TRUSTPROXYDEVICEIDENTITYHEADER
Revokes a session when the device identity reported on it changes mid-session. Mattermost compares tls_device_id, client_device_id, and hardware_id against the values previously cached for the session. If one of them changes, the session is revoked, the user must log in again, and the revocation is recorded in the audit log. When disabled, a changed device identity overwrites the cached value without revoking the session.
config.jsonsetting:"AccessControlSettings.EnforceDeviceIDConsistency": falsewith optionstrueandfalse.- Environment variable:
MM_ACCESSCONTROLSETTINGS_ENFORCEDEVICEIDCONSISTENCY
This setting mitigates session token theft: a stolen token replayed from a device that reports a different identifier has its session revoked. A replay that reports no device identifier, or one on a session that never cached one, isn't revoked. tls_device_id is only present when Trust proxy device identity header is enabled, and the other two identifiers depend on platform availability. Enable this setting once you've confirmed the identifiers you rely on report stable values across your fleet, since an identifier that legitimately changes will log users out.
Troubleshooting and FAQs
Why is a user denied access when their attributes look correct?
Work through these in order:
- Check the client. Confirm the user is on a client that can report the attribute, using the Platforms column in the Session attribute reference.
- Check the attribute is enabled in System Console > System Attributes > Session Attributes.
- Check value casing. Free-text values such as
ssidmust match exactly what the client reports. - Check freshness. If TTL plus grace period has elapsed without a fresh report, the attribute is treated as absent.
- Check the user's Desktop App setting. If Settings > Advanced > Enable session attributes is cleared, the client reports nothing. When enabled, the table beneath it shows the value the app currently reports for each attribute, which tells you whether the problem is on the client or the server.
- Check location permission for
ssid. Mobile devices only report the Wi-Fi network name when the user has granted location access.
Client-reported attributes are self-attested, so treat them as posture signals rather than cryptographic proof. Mattermost limits the exposure: server-derived attributes are measured from the request rather than accepted from the client; tls_device_id is only accepted from a trusted proxy; incoming values are dropped when they're unknown, disabled, or not valid for the requesting platform; and Enforce device ID consistency revokes sessions whose device identity changes.
For controls that must not be self-attested, use ip_address with inCIDR, or tls_device_id backed by mutual TLS at your proxy. Both depend on your proxy being correctly configured; see Trusted proxy headers and inCIDR rules and Trust proxy device identity header.
Are session attributes collected for bots, personal access tokens, or integrations?
No. Collection is limited to interactive end-user sessions. Personal access token sessions, OAuth app sessions, local mode sessions, and remote cluster tokens collect nothing, not even server-derived attributes. Policies that reference session attributes deny these callers.
Do session attributes work in a high availability cluster?
Yes. Attribute updates are broadcast to all nodes in a high availability cluster, so every node evaluates policies against the same view of a session.
Can I add my own session attributes?
No. The set of session attributes is fixed. You can enable, disable, and tune the TTL and grace period of the built-in attributes, but you can't add, rename, or remove them, or change their types or supported platforms. For organization-specific values, use user attributes instead.
