Automated PostgreSQL migration
Migrating databases can be a daunting task, and it can be easy to overlook or misinterpret some of the required steps if you haven't performed a migration before. Our migration-assist tool provides an efficient, error-free migration experience that automates the tasks to be executed, even in air-gapped deployment environments.
Not sure this tool is right for your Mattermost deployment? Mattermost customers looking for tailored guidance based on their Mattermost deployment can contact a Mattermost Expert.
Install​
Download the Mattermost migration-assist tool from the GitHub repository releases page.
While you can run the migration-assist tool on the same server as your Mattermost deployment, we recommend running the tool in a virtual machine on the same network as your Mattermost server instead. The tool itself is lightweight and does not require a large server. A server with 2 CPU cores and 16 GB of RAM should be sufficient. If preferred, you can download and compile the migration-assist tool yourself.
You'll also need to install the pgloader tool to migrate your data from MySQL to PostgreSQL. We recommend running pgloader in a virtual machine on the same network as your Mattermost server, using our official Mattermost Docker image for pgloader (mattermost/mattermost-pgloader:latest). You can also build the image yourself from the mattermost-pgloader-docker repository. If you run into authentication errors, see Unsupported authentication for MySQL. See the pgloader installation documentation for details.
Usage​
Step 1 - Check the MySQL database schema​
Run the following command to check the MySQL database schema:
migration-assist mysql "<MYSQL_DSN>" # example DSN: "user:password@tcp(address:3306)/db_name"
This command outputs the readiness status and prints required fixes for common issues. The flags for fixes are as follows (you can combine all of them):
--fix-artifacts Removes the artifacts from older versions of Mattermost
--fix-unicode Strips unsupported Unicode characters from MySQL tables
--fix-varchar Removes rows exceeding column lengths
Step 2 - Create the PostgreSQL database schema​
Before running migrations, ensure the public schema is owned by your migration user:
sudo -u postgres psql -d mattermost -c "ALTER SCHEMA public OWNER TO mmuser; GRANT ALL ON SCHEMA public TO mmuser;"
Then run:
migration-assist postgres "<POSTGRES_DSN>" \
--run-migrations \
--mattermost-version="<MATTERMOST_VERSION>"
  • <POSTGRES_DSN> example: postgres://user:password@address:5432/db_name
  • <MATTERMOST_VERSION> example: 10.5.4
By default, two pre-checks run before migration:
  • --check-schema-owner=true
  • --check-tables-empty=true
To disable them:
--check-schema-owner=false \
--check-tables-empty=false
Step 3 - Generate a pgloader configuration​
Run the following command to emit a pgloader configuration file:
migration-assist pgloader \
--mysql="<MYSQL_DSN>" \
--postgres="<POSTGRES_DSN>" \
--remove-null-chars \
> migration.load
  • By default, null characters in text columns are stripped. Disable with --remove-null-chars=false.
  • If you run out of heap, edit migration.load and under the WITH block set:
    prefetch rows = 1000
Step 4 - Run pgloader​
Run pgloader with the generated configuration file:
pgloader migration.load > migration.log
Carefully review migration.log for errors (e.g., duplicate-key or missing-table warnings). Use the mattermost/mattermost-pgloader:latest Docker image to avoid build/auth issues.
Step 5 - Restore full-text indexes & create all indexes​
Run:
migration-assist postgres post-migrate --create-indexes "<POSTGRES_DSN>"
  • The --create-indexes flag rebuilds full-text indexes on Posts and FileInfo, plus all other Mattermost indexes.
  • Omitting that flag only restores full-text indexes for Posts and FileInfo.
See the Restore full-text indexes documentation for details.
Step 6 - Complete plugin migrations​
Generate pgloader configs for Playbooks, Boards, and Calls:
migration-assist pgloader boards \
--postgres="<POSTGRES_DSN>" > boards.load
migration-assist pgloader playbooks \
--postgres="<POSTGRES_DSN>" > playbooks.load
migration-assist pgloader calls \
--postgres="<POSTGRES_DSN>" > calls.load
Run each:
pgloader boards.load > boards_migration.log
pgloader playbooks.load > playbooks_migration.log
pgloader calls.load > calls_migration.log
Skip any plugin you don't use; check logs for JSON or missing-table errors. See the Plugin migrations guide for more.
Step 7 - Configure Mattermost to use PostgreSQL​
In your config.json or via environment variables, update:
"SqlSettings": {
"DriverName": "postgres",
"DataSource": "postgres://mmuser:pass@db:5432/mattermost?sslmode=disable"
If your config was stored in the database, update MM_CONFIG accordingly. See the environment configuration settings documentation for details.
Air-gapped environments​
Follow these steps to migrate within an air-gapped environment:
  1. Verify that the migration-assist binary is the latest version available to benefit from improvements and fixes.
  2. Transfer the latest migration-assist binary into the air-gapped environment (e.g., via secure media).
  3. Generate the MySQL schema+data output using fix flags. This produces mysql.output:
    migration-assist mysql "user:pass@tcp(localhost:3306)/mattermost" \
    --fix-artifacts --fix-unicode --fix-varchar > mysql.output
  4. Apply migrations using the generated output:
    migration-assist postgres \
    "postgres://mmuser:pass@localhost:5432/imported?sslmode=disable" \
    --run-migrations --applied-migrations="./mysql.output"
  5. Continue from Step 3 through Step 7 above to complete data transfer and configuration.
Tool commands​
The migration-assist tool offers 3 core commands:
  1. migration-assist mysql — Checks MySQL schema readiness and offers fixes.
  2. migration-assist postgres — Builds the PostgreSQL schema and applies migrations.
  3. migration-assist pgloader — Generates a pgloader config for data transfer.
Compile the migration-assist tool​
Requires Go ≥ v1.22. Install with:
go install github.com/mattermost/migration-assist/cmd/migration-assist@latest
Troubleshooting​
See troubleshooting errors during migration from MySQL to PostgreSQL.
