Generate a support packet
The Support Packet is used to help customers diagnose and troubleshoot issues. Use the System Console or the mmctl system supportpacket command to generate a zip file that includes configuration information, logs, plugin details, and data on external dependencies across all nodes in a high-availability cluster. Confidential data, such as passwords, are automatically stripped.
Generate​
  1. Go to the System Console, and select Commercial Support from the System Console menu.
    Example of available System Console menu options.
  2. Select Download Support Packet. A zip file is downloaded to the local machine. You'll be notified if any packet files are unavailable during packet generation. See the warning.txt file for details.
Sanitize confidential data​
Please sanitize any confidential data you wish to exclude before sharing the packet with Mattermost.
When present, the following information is automatically sanitized during packet generation: LdapSettings.BindPassword, FileSettings.PublicLinkSalt, FileSettings.AmazonS3SecretAccessKey, EmailSettings.SMTPPassword, GitLabSettings.Secret, GoogleSettings.Secret, Office365Settings.Secret, OpenIdSettings.Secret, SqlSettings.DataSource, SqlSettings.AtRestEncryptKey, ElasticsearchSettings.Password, All SqlSettings.DataSourceReplicas, All SqlSettings.DataSourceSearchReplicas, MessageExportSettings.GlobalRelaySettings.SmtpPassword, ServiceSettings.SplitKey, FileSettings.ExportAmazonS3SecretAccessKey, ServiceSettings.GoogleDeveloperKey, and ServiceSettings.GiphySdkKey (from Mattermost v11.6.0).
Share the packet with Mattermost​
Add the generated Support Packet to a standard support request, or share with with the Mattermost team you're working with.
Contents of a Support Packet​
The contents of a Mattermost Support Packet can differ by server version. Select the tab that corresponds to your Mattermost version to see the files included in the Support Packet.
Cluster-wide files​
The following cluster-wide files are located in the root directory of the Support Packet:
  • metadata.yaml
  • plugins.json (all active and inactive plugins)
  • sanitized_config.json (sanitized copy of the Mattermost configuration)
  • stats.yaml (Mattermost usage statistics)
  • jobs.yaml (last runs of important jobs)
  • diagnostics.yaml (system and plugin diagnostics)
  • permissions.yaml (role and scheme information)
  • postgres_schema_dump.sql (PostgreSQL database schema information including tables, indexes, constraints, and other metadata to assist with database configuration diagnosis)
  • warning.txt (present when issues are encountered during packet generation)
  • tsdb_dump.tar.gz (present when the Metrics plugin is installed and the Performance metrics option is selected when generating the Support Packet)
Node-specific files​
The following node-specific files are located in node subdirectories:
  • <node-id>/mattermost.log (Mattermost logs for each node)
  • <node-id>/audit.log (Mattermost audit logs for each node)
  • <node-id>/ldap.log (AD/LDAP logs for each node)
  • <node-id>/notifications.log (notifications logs for each node)
  • <node-id>/cpu.prof (Go performance metrics for each node)
  • <node-id>/heap.prof (Go performance metrics for each node)
  • <node-id>/goroutines (Go performance metrics for each node)
Diagnostics highlights​
The Support Packet diagnostics.yaml file includes system and plugin diagnostics to support troubleshooting and configuration validation.
Plugin diagnostic data​
The following additional plugin diagnostic data is available when the plugin is enabled and operational:
  • GitHub: /github/diagnostics.yaml
  • GitLab: /com.github.manland.mattermost-plugin-gitlab/diagnostics.yaml
  • Jira: /jira/diagnostics.yaml
  • Calls: /com.mattermost.calls/diagnostics.yaml
  • Boards: /focalboard/diagnostics.yaml
  • Playbooks: /playbooks/diagnostics.yaml
  • MSCalendar: /com.mattermost.mscalendar/diagnostics.yaml
  • Google Calendar: /com.mattermost.gcal/diagnostics.yaml
Metadata​
From Mattermost v9.11, generated Support Packets include a metadata.yaml file that contains the following information.
Field nameRequired/OptionalDescription
Example
versionRequiredVersion of the schema that the current metadata file is compatible with. Current version is 1.1
typeRequiredThe type of the packet. Each type of Support Packet can be mapped to a specific component generating the Support Packet.mattermost
generated_atRequiredThe date and time the packet was created. Value is in epoch (ms).1707473288731
server_versionRequiredVersion of the server that the Support Packet was generated at. Semver is expected.9.1.1
server_idRequiredUnique identifier of the server. Expected to be 26 characters or longer.9qpiszyjr3g8bxda35abcd1234
license_idOptionalUnique identifier of the current server's license. Expected to be 26 characters or longer. This field is empty when there's no license.abcdejisd67yigqhmkz4ho1234
customer_idOptionalThe id of the customer, as defined in the license file. Expected to be 26 characters or longer. Empty when there's no license.a1b2c3d4qbbr5cpkbpbmef123h
extrasOptionalKey/value of any additional information, specific to the plugin/component that generated the file. Can be useful for identifying the contents of the data. Consider adding plugin (or component) versions in order to set expectation regarding the contents of this object.
extras.plugin_idRequired for pluginsThe ID of the plugin.
extras.plugin_versionRequired for pluginsThe version of the plugin.
For example:
version: 1
type: support-packet
generated_at: 1622569200
server_version: 9.1.1
server_id: 8fqk9rti13fmpxdd5934a3xsxh
license_id: 3g3pqn8in3brzjkozcn1kdidgr
customer_id: 74cmws7gf3ykpj31car7zahsny
extras:
plugin_version: 0.1.0
Go performance metrics​
The Support Packet contains 3 go runtime profiling files:
  • cpu.prof contains a 5-second CPU profile
  • heap.prof contains a heap profile
  • goroutines contains a dump of all the running go routines
These files can be read using pprof.
Use go tool pprof -web X to open a visualization of the profile in your browser, replacing X with the profile's file name.
Load metric​
From Mattermost v10.10, the Load Metric field under Product Menu > About Mattermost displays monthly active users relative to the total number of licensed users. This value gives Mattermost support teams a contextual reference point for understanding deployment active usage for troubleshooting and guidance. It isn’t a comprehensive performance monitoring tool or health indicator, but serves as a supplementary data point when traditional diagnostic methods aren’t available.
