System-wide attribute-based access policies
Use this guide to create and manage organization-wide attribute-based access policies in the System Console. Policies can be assigned to both channels and teams. For channel-level rules managed by Channel Admins, see Channel-specific access rules. For team membership policies, see Team membership access policies.
Prerequisites
  • Attribute-based access controls (ABAC) require defined user attributes. First configure user attributes in the System Console.
  • Then go to System Console > System Attributes > Attribute-Based Access to enable attribute-based access controls for your Mattermost instance. This functionality requires a Mattermost Enterprise Advanced license.
From Mattermost v10.11, user-managed attributes are excluded from attribute-based access control (ABAC) rules by default for security reasons. This prevents access control policies from being circumvented by users editing their own profile attributes. To include user-managed attributes in ABAC rules, a system admin must explicitly enable the EnableUserManagedAttributes configuration setting. See the user attribute documentation for details on enabling this feature. This configuration setting is available only in Enterprise Edition Advanced and is disabled by default.
Define access control policies
You can add multiple rules to a single policy, and each rule can include multiple attribute values.
  1. In the System Console, go to System Attributes > Attribute-Based Access and select Add Policy.
  2. Enter a unique policy name. Parent access control policy names must be unique; if you enter a name that's already in use, Mattermost displays a user-friendly error message and prevents the policy from being saved until you choose a different name.
  3. Choose whether to automatically add users who match your configured attribute values as new members. Automatic synchronization is disabled by default.
    • True: Automatically maintains channel membership according to the defined rules as user attributes change.
    • False (Default): Only removes members and restricts adding them to the channel if they don’t match defined rules. Users are not automatically added.
    Regardless of whether this configuration setting, users who no longer match the configured attribute values in the future will be removed from the channel after the next channel synchronization.
  4. Define the attribute-based access rules to restrict channel membership.
Simple Mode is ideal for simple and straightforward access control scenarios. Each row is a single condition that must be met for a user to comply with the policy. Simple Mode only supports simple conditions without nested logic or mixed logical operators. All rules are combined with a logical AND operator &&.
  1. Select Add attribute and select the attribute you want to use for access control.
  2. Specify how you want the attribute to match the user profile. You can choose from the following options:
    • Is: The attribute must be an exact match of the value.
    • Is not: The attribute must not contain specified value.
    • In: The attribute must match at least one value.
    • Starts with: The attribute value must start with the specified value.
    • Ends with: The attribute value must end with the specified value.
    • Contains: The attribute value must exist somewhere with the specified value.
    When the selected attribute is a Ranked attribute (an ordered list of values, such as clearance or classification levels), the match options are ordered comparisons instead. These let you match everyone at or above a threshold rather than only an exact value:
    • Is exactly / Is not: The value must exactly match, or must not match, the specified value.
    • Is at least: The value must be equal to or higher than the specified value - for example, clearance is at least Secret matches Secret and every higher level.
    • Is greater than: The value must be higher than the specified value.
    • Is at most: The value must be equal to or lower than the specified value.
    • Is less than: The value must be lower than the specified value.
  3. Specify the attribute values that users must have to be granted access to the channel.
Simulate access
Select Test access rule to test the rule against your user base to return how many users would be granted access to the channel based on the current rule. Test your rules to ensure the intended scope and avoid unexpected access changes.
From Mattermost v11.8.0, you can use Simulate access to preview allowed and denied outcomes for specific users before saving policy changes:
  1. Open the policy editor in the System Console.
  2. Select Simulate access.
  3. Choose the users you want to test.
  4. Review the allowed and denied outcomes by action, such as joining a channel or uploading and downloading files.
  5. Adjust the rules before saving.
Simulation can test draft policy changes before they affect live channel access or file permissions. Detailed rule and attribute information is shown only when the denial comes from the policy or scope you're editing; otherwise, Mattermost may show that access was denied by another policy.
Manage rules
You can apply changes to existing rules or remove rules at any time using either Simple Mode or Advanced Mode. Select Save to save your changes.
Assign policies to channels
From Mattermost v11.8, system-wide policies can be assigned to both private and public channels. Select Add channels to search for and select the channels you want. You can assign the policy to multiple channels at once, or you can assign it to individual channels later. Select Save to save your changes.
The two channel types behave differently under the same policy:
  • Private channels are hard-gated. The policy adds matching users (when auto-add is enabled), removes non-matching members during synchronization, and prevents non-matching users from being added or invited.
  • Public channels are advisory. The policy never removes members and never blocks anyone from joining. With auto-add enabled it automatically adds matching users; with auto-add disabled the channel appears under Browse Channels > Recommended channels for matching users.
Before saving, you'll be prompted to confirm the impact of the change so you can review how it affects each channel type.
Default channels (such as Town Square and Off-Topic), shared channels, and group-synced channels remain ineligible — they are excluded from the channel selector.
Assign policies to teams
From Mattermost v11.10, system-wide policies can also be assigned to teams. Go to System Console > User Management > Teams and open the team you want to configure. In the Team Management section, enable Manage membership with attribute based membership policies — the Membership policies section only appears once this toggle is on. Then link an existing policy and select Save.
Group-synced teams cannot use membership policies, so the toggle is unavailable on them.
The policy behaves differently depending on the team's privacy mode:
  • Private teams — strict enforcement: join is gated, non-qualifying members are removed at sync, and the team is hidden from non-qualifying non-members in Browse Teams.
  • Public teams — advisory: the policy is never a gate. Qualifying non-members see a Recommended chip in Browse Teams; anyone can still join freely.
For a full description of team assignment, custom rules, sync configuration, and end-user surfaces, see Team membership access policies.
Delete policies
To delete a policy, select the Delete button next to the policy you want to remove. Policies that are still assigned to channels cannot be deleted — remove the policy from those channels first.
Team assignments are not checked before deletion, so unlink the policy from every team that uses it before deleting it. Otherwise those teams keep a reference to a policy that no longer exists.
Define access controls per channel
You can assign an existing access control policy to a private or public channel for more granular control over channel membership. This is useful when you need to apply different rules for different channels.
  1. In the System Console, go to User Management > Channels to select the private or public channel you want to configure, and select Edit.
  2. In the Channel Management section, enable the Enable attribute-based channel access option.
  3. Under Access policy, select Link to a policy to select an existing policy.
Once a policy is attached, the channel's privacy can no longer be flipped between public and private until the policy is removed — see Channel-specific access rules.
Remove channel policies
Disable the policy for the channel by selecting Remove Policy. You can then link the channel to a different policy if preferred.
Permission policies
From Mattermost v11.7, System Admins can define attribute-based permission policies that restrict specific user actions in addition to channel membership. Permission policies use the same attribute-based rules as access policies, but they apply to user actions rather than channel access.
Permission policies can be used to restrict the following actions based on user attributes:
  • File upload: Prevent users who don't match the defined attribute rules from uploading file attachments.
  • File download: Prevent users who don't match the defined attribute rules from downloading file attachments.
When a permission policy applies, users who don't match the configured attribute values can't perform the restricted action. Users may see file attachments as unavailable or redacted in messages they would otherwise have access to. See Restricted file attachments for the end-user-facing behavior.
Permission policies follow the same unique-name requirement as access policies: each parent permission policy must have a unique name, and Mattermost surfaces a user-friendly error if a duplicate name is entered.
Attribute value masking
From Mattermost v11.8, when a policy references attribute values that the editing admin doesn't personally hold, those values are hidden in the policy editor. This prevents admins from reading or copying sensitive attribute values they're not authorized to see, while still allowing the policy to enforce access control normally.
Masking only applies to attributes configured with a shared_only or source_only access mode. Attributes with a public access mode are always visible to all admins. See Attribute access modes for details on how each mode controls value visibility.
What you'll see:
  • Masked values appear as -------- in the rule editor instead of the raw value.
  • Rows containing masked values are read-only and cannot be modified.
  • Test rule and Delete actions are disabled for rules that contain masked values.
Enforcement is unaffected: masking applies to the editing UI only. The underlying rules continue to control channel access and permissions as configured.
To edit a masked rule, ask the policy owner or another System Admin who holds the relevant attribute values to make the change.
This behavior applies to both the table editor and the CEL editor, and also to Team Admin and Channel Admin policy editors in Team Settings and Channel Settings. Requires Enterprise Advanced license and the AttributeValueMasking feature flag.
