Channel-specific access rules
Channel and Team Admins can self-manage access controls for their channels directly through the Channel Settings modal, without requiring System Admin intervention. For organization-wide policies created by System Admins, see System-wide attribute-based access policies. For team-scoped policies that apply rules across multiple channels within a team, see Team-level channel membership policies.
From Mattermost v11.8, channel access rules can be applied to both private and public channels. The two channel types behave differently under ABAC:
  • Private channels are hard-gated. Non-matching members are removed during synchronization, and only matching users can be added or invited.
  • Public channels are advisory. Non-matching members are never removed (anyone can still join a public channel by browsing or via a direct link). With auto-add enabled the policy still pulls matching users in; with auto-add disabled the channel surfaces under Browse Channels > Recommended channels for users whose attributes match.
Each ABAC channel access policy has an explicit active state that determines whether the policy will automatically add users who meet the policy's criteria but are not yet channel members. For private channels, the policy's rules are always enforced to remove members who no longer meet the required attribute rules, regardless of the active state. For public channels, no member is ever removed by ABAC — the rules are advisory only.
With channel access rules, Channel and Team Admins can:
  • Create channel-specific access rules using a simple interface.
  • Use rules that are additive to any system policies. For private channels, both must be satisfied for adds and invites. For public channels, the combined rules affect auto-add and recommendations only, and don't block joins or remove members.
  • Automatic member synchronization with immediate feedback.
  • Self-exclusion prevention to avoid locking yourself out (private channels only).
Prerequisites
  • Attribute-Based Access Control (ABAC) must be enabled by a System Admin in System Console > System Attributes > Attribute-Based Access.
  • You need Channel Admin permissions and the manage_channel_access_rules permission.
  • Channel access rules are available for private and public channels, with behavior that varies by channel type. See Public and private channel behavior. Default channels (such as Town Square and Off-Topic), shared channels, and group-synced channels remain ineligible.
Access Channel Settings
  1. In a private or public channel where you have Channel Admin permissions, select the channel name at the top of the center pane.
  2. Select Channel Settings from the dropdown menu.
  3. Navigate to the Membership Policy tab. This tab is only visible for eligible channels when you have the appropriate permissions and ABAC is enabled system-wide. The tab is hidden on default channels, shared channels, and group-synced channels.
Configure access rules
Channel access rules use the same simple interface as system policies, allowing you to create attribute-based conditions without complex syntax.
  1. In the Membership Policy tab, you'll see any inherited system policies at the top in a blue information banner (if applicable).
  2. Use the Add attribute button to create new access conditions:
    • Select attribute: Choose from available user attributes
    • Choose operator: Select how the attribute should match:
      • Is: Exact match with specified value
      • Is not: Must not match specified value
      • In: Must match any of multiple specified values
      • Contains: Attribute value must contain specified text
    • Set values: Enter the required attribute values
  3. Add multiple conditions as needed. All conditions are combined with logical AND (all must be satisfied).
  4. Select Test access rules to preview which users would be granted access based on your current rules.
Auto-sync membership
The Auto-add members based on access rules toggle controls automatic membership management. The behavior differs by channel type:
  • Private channels (hard gate): Membership stays consistently aligned with the rules, similar to how LDAP group channels work.
    • Enabled: Users matching the rules are automatically added. If users temporarily lose attributes and later regain them, they will be automatically re-added.
    • Disabled: Rules act as a gate (preventing unauthorized joins) but don't automatically add qualifying users.
  • Public channels (advisory): ABAC never removes members — anyone can still join a public channel.
    • Enabled: Matching users are automatically added (a convenience, not a gate).
    • Disabled: The channel appears under Browse Channels > Recommended channels for users whose attributes match, surfacing the channel without adding anyone.
Validation and safety
Before saving changes, Mattermost validates your rules to prevent common issues:
  • Required fields: All attribute selections and values must be completed.
  • Self-exclusion prevention: For private channels, you cannot save rules that would remove yourself from the channel. The check is skipped for public channels because they are advisory under ABAC and can't lock anyone out.
  • Conflict detection: Rules that create impossible conditions are identified.
When you save changes that affect membership, a confirmation dialog shows you:
  • How many users will be added or removed.
  • Option to view the specific users affected.
  • Confirmation required before applying changes.
Once a policy is attached to a channel, the channel cannot be converted between public and private until the policy is removed. The two modes have different semantics (advisory vs. hard gate), so a silent conversion would change what an existing policy actually does to its members.
Membership policies behave differently depending on the type of channel they're applied to:
  • Private channels: Membership policies are enforced. Users who match the policy's rules are added, and users who don't match the rules are removed during synchronization.
  • Public channels: Membership policies are advisory. Matching users may be automatically added when auto-add is enabled, but non-matching members are not removed.
  • When auto-add is disabled for a public channel, matching channels are surfaced as recommended rather than enforcing membership.
  • Direct messages and group messages aren't eligible for membership policies.
  • Default channels such as Town Square and Off-Topic are excluded.
Channel-level permission policies
From Mattermost v11.8.0, channel admins can define channel-level permission rules for file upload and file download based on user attributes and channel role. Applicable roles include channel admin, channel member, and channel guest.
For system-wide permission policies that restrict file upload and download actions, see Permission policies.
Simulate access
From Mattermost v11.8.0, admins can use Simulate access in Channel Settings to preview whether selected users can perform actions such as uploading files or downloading files before saving policy changes.
  • Simulation can evaluate draft rules before they're saved, so you can confirm the intended scope without affecting live channel access.
  • Some denied results may indicate that the decision came from another policy. In that case, Mattermost shows that access was denied by another policy without exposing policy details you aren't authorized to see.
Manage team-scoped membership policies in Team Settings
From Mattermost v11.7, Team Admins can create, edit, and delete channel membership policies directly from Team Settings, scoped to channels within their team. This lets teams self-manage attribute-based membership for their own channels without requiring a System Admin to create or modify a system-wide policy.
Prerequisites
  • You need Team Admin permissions for the team and the manage_team_access_rules permission.
  • Team-scoped membership policies can be assigned to both public and private channels within the team.
Team Admin workflow
  1. Open Team Settings from the team menu, and go to the Channel Membership tab. This tab is only visible to Team Admins with the manage_team_access_rules permission when ABAC is enabled system-wide.
  2. Select Add Policy and enter a name for the policy. Parent policy names must be unique; if you enter a name that's already in use, Mattermost displays a user-friendly error and prevents the policy from being saved.
  3. Define the attribute rules that determine which users can be members of channels assigned to this policy. Rules use the same attribute conditions available for channel-specific access rules.
  4. Assign the applicable private channels in the team to the policy.
  5. Select Save to create or update the policy. Team-scoped policies can be edited or deleted from the same tab at any time.
The Channel Membership tab includes a sync status footer that shows:
  • Last sync time: The time of the most recent membership synchronization for policies in this team.
  • Sync now: An on-demand action that triggers an immediate synchronization for the team's policies.
Team-scoped sync is limited to the team admin's team scope. Triggering Sync now from Team Settings does not affect channels or policies outside the current team.
Sync behavior by channel type
Sync behavior for team-scoped membership policies depends on the type of channel the policy is assigned to:
  • Public channels: Sync is advisory and add-only. Users who match the policy's rules are added to the channel, but no users are removed if their attributes change.
  • Private channels: Sync is enforced. Users who match the policy's rules are added to the channel, and users who no longer match the rules are removed during the next synchronization.
Automatic sync on policy changes
Mattermost automatically runs a sync job whenever a team-scoped membership policy is created, or its rules, assigned channels, or active state change. Team Admins don't need to manually trigger Sync now for these updates; the sync runs as part of the change.
Policy inheritance
Channel-level (child) ABAC policies now behave independently and consistently, even when parent system-wide policies exist. Each policy maintains its own active state and configuration.
When both system policies and channel rules are configured:
  1. System policies are displayed in a blue banner at the top (read-only)
  2. Channel rules are managed in the access rules section below
  3. Users must satisfy BOTH system policies and channel rules to access the channel
  4. Channel rules add restrictions but cannot weaken system policies
  5. Auto-add behavior is determined by the individual channel policy, not inherited from parent system-wide policies. System-wide policies can pass down their rules, but auto-add/auto-sync is evaluated per channel.
Use cases and recommendations
Ideal use cases for channel access rules:
  • Project-specific channels: Restrict access to team members working on specific projects
  • Clearance-based discussions: Ensure only users with appropriate security clearance can participate
  • Department communications: Limit channel access to specific organizational units
  • Temporary access: Create rules for short-term project teams or contractor access
Best practices:
  • Start simple: Begin with basic attribute conditions before adding complexity
  • Test before saving: Always use the "Test access rules" feature to verify your intended scope
  • Document changes: Consider posting a message in the channel when access rules change
  • Regular review: Periodically review rules to ensure they remain appropriate
  • Coordinate with IT: Work with System Admins for complex organizational policies
When to use system policies vs. channel rules:
  • System policies: Use for organization-wide standards, compliance requirements, or policies affecting multiple channels
  • Channel rules: Use for channel-specific restrictions, project-based access, or when you need immediate control without IT involvement
End-user experience
When channels have attribute-based access controls applied, users will see clear indicators and experience specific behaviors designed to maintain security while providing transparency.
Visual indicators
Channel Members panel:
  • Information banner at the top explains that attribute-based access is enabled. The message differs by channel type: private channels indicate that access is restricted by user attributes, while public channels indicate that member recommendations are based on user attributes.
  • Displays required attribute values as tags (e.g., "Engineering", "Confidential").
  • Tooltip on hover shows the attribute name for each value.
Add Members modal:
  • Similar information banner and attribute value display.
  • On private channels, users who don't match the access criteria won't appear in search results — only eligible users can be added.
  • On public channels, the full team list is shown and matching users are surfaced with a Recommended tag at the top of the list. Anyone can still be added because public-channel ABAC is advisory.
Browse Channels:
  • A Recommended channels filter is available in the channel-type dropdown when ABAC is enabled. Selecting it lists the public channels whose policies the user matches — useful when auto-add is disabled and the channel is offered as a recommendation rather than auto-joined.
Functional restrictions
When ABAC is enabled for a private channel:
  • Search limitations: Users who don't match access criteria don't appear in member search results.
  • Invitation restrictions: Only users meeting attribute requirements can be added to the channel.
  • Guest user exclusions: Private channels with ABAC policies cannot have guest users invited.
  • Automatic removal: Users who lose required attributes are automatically removed during the next synchronization.
When ABAC is enabled for a public channel:
  • Search results are unfiltered: All eligible team members appear in the Add Members modal so admins can still invite anyone; matching users carry a Recommended tag.
  • Recommendations: With auto-add disabled, the channel surfaces under Browse Channels > Recommended channels for matching users.
  • Auto-add (when enabled): Matching users are added automatically. Members are never removed by ABAC — users can always leave on their own, and joining freely is unaffected because the channel is public.
Troubleshooting and FAQs
Common questions about attribute-based access control implementation and usage.
Permission and access
Why can't I see the Membership Policy tab in Channel Settings?
The Membership Policy tab is only visible when all of these conditions are met:
  • You have Channel Admin role or higher for the channel.
  • The channel is a private or public channel (not a default channel like Town Square or Off-Topic, group message, direct message, shared, or group-synced channel).
  • ABAC is enabled system-wide by a System Admin in System Console > System Attributes > Attribute-Based Access.
  • Your user role includes the manage_channel_access_rules permission.
Can Channel and Team Admins override system policies?
No. Channel rules are always additive to system policies. Users must satisfy both system policies AND channel rules to access the channel. Channel and Team Admins cannot weaken or override restrictions set by System Admins.
What happens if I create rules that would exclude myself?
For private channels, Mattermost prevents this with self-exclusion validation. If your rules would remove you from the channel, you'll see an error message and cannot save the changes until you adjust the rules or reset them.
For public channels, the self-exclusion check is skipped — public-channel ABAC is advisory, the policy can't kick anyone out, and you can always re-join a public channel directly. This lets you author a policy intended for a different team (for example, a Sales admin configuring an Engineering recommendation) without being blocked.
Can I convert a public channel to private (or vice versa) while a policy is attached?
No. The two modes have different semantics — a public-channel policy is advisory while a private-channel policy is a hard gate that removes non-matching members. A silent conversion would change what the existing policy does to its members, so Mattermost requires you to remove the policy first, convert the channel, and re-attach the policy if you still want it.
Rule configuration
Can I use advanced CEL expressions in Channel Settings?
No. Channel Settings only supports Basic Mode with simple attribute conditions. For complex expressions with nested logic or mixed operators, System Admins need to create policies in the System Console.
How do I remove all access rules from a channel?
Delete all attribute conditions from the access rules table. When no rules are configured and no system policies are applied, the channel returns to standard access behavior.
Why is the auto-sync toggle disabled?
The auto-sync toggle is automatically disabled when:
  • No access rules are configured
  • A system policy with auto-sync enabled is applied (Channel and Team Admins cannot disable it)
  • There are validation errors in the current rules
  • The channel's access control policy is not in an active state
Synchronization and membership
How quickly are membership changes applied?
When you save access rules, membership sync job is created and changes are applied as soon as the job is completed. Additionally, Mattermost runs synchronization jobs on a schedule to handle attribute changes from external systems (LDAP, SAML). The interval is set by AccessControlSettings.SyncJobIntervalSeconds and defaults to 3600 seconds (60 minutes). User attributes used for access control evaluation are refreshed on a separate schedule controlled by AccessControlSettings.AttributeRefreshIntervalSeconds, which defaults to 30 seconds.
Will users be notified when they're removed from a channel?
Yes, users receive standard Mattermost notifications when they're removed from channels due to access rule changes, similar to manual removals.
Can I see who was added or removed during synchronization?
Yes, the confirmation modal before saving shows exactly which users will be affected. System Admins can also view detailed synchronization logs in the System Console.
Attribute and data questions
Which user attributes can I use in access rules?
You can use any user attributes either synchronized via LDAP/SAML or manually configured by System Admins in System Console > System Attributes > User Attributes.
What happens if a user attribute changes?
During the next scheduled synchronization (every 60 minutes by default), users who no longer match the access rules will be removed from the channel, and new users who now match will be added (if auto-sync is enabled).
Do guest users work with ABAC channels?
No. Private channels with attribute-based access control cannot have guest users. This ensures strict adherence to access control policies based on organizational attributes.
Can group-sync channels use ABAC?
No. Channels configured with group synchronization cannot use attribute-based access control. Group-sync and ABAC are mutually exclusive features - you must choose one method of access control per channel.
